Why isn't my tablet turning on?
I pushed the power button and nothing happens.
Это хороший вопрос?
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Это хороший вопрос?
Hi @randolphmora123,
Does the tablet show that it is charging when you connect the charger to it?
What % of charge is the battery icon showing when you try to charge the battery only and not switch on the tablet?
If it shows that it is charging allow it to fully charge and then try turning it on.
If it still won’t turn on after it is fully charged, can you start and use the tablet with the charger connected and switched on?
If so, then the battery may be faulty and needs to be replaced.
Был ли этот ответ полезен?
For more information about your XO Tablet please go to the following website: http://xotablet.com/
Also, you can check out the troubleshooting page for this device!
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 2,018
4 Комментариев
my USB/charge port is loose. I know why it won't turn on. I need to know how to get it repaired.
из brobisonus
y is not truinng on
из darius matthews
I push the power button and it doesnt come on.
из randolphmora123
Why my vivitar tablet wont turn on
из Beatricegrace
