Need a Bios password
hello,
Anyone who can help me to fix toshiba tecra m10 1cn bios password
it wont let any other bootable drive to boot at all.
it comes first when putting it on.
Это хороший вопрос?
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
hello,
Это хороший вопрос?
This previous thread should help.
Был ли этот ответ полезен?
If you can open the casing, just remove the CMOS battery for 5-10 secs and reinstall it.
if your problem just boot you can download hirens boot cd put it it will boot automatically
choose boot section then kon-boot programme then choose any device to boot
if you need to clear password bios thats lot of work and you need programmer and bios file and hot air
if you need guide no pb contact me
I guess, you should just remove the CMOS battery for a while and then put it back after 7-8 hours. I recommend you to press the Power button several times so that whole the power from the motherboard is gone and BIOS password will be removed successfully. This is how I’ve removed BIOS password from my PC.
You aren’t able to boot into any device, here’s an guide to clear BIOS password and it might help you in several ways. A friend of mine also removed the battery, and put it back after 7-8 hours. But, in between the time when battery wasn’t on motherboard, he was pressing power button several times, plug in and lug out external devices so that whole the power from a motherboard is gone. You should try this method and I’m sure that it’ll help you a lot.
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 1,821
