Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Repair guides and support for your LG TV.
Вопросов 20 Показать все
TV won’t turn on
There was a severe thunderstorm in my area a few days ago and my LG Smart tv turned off and won’t turn back on. The red light at the bottom just blinks when I try to power it back on. I’ve unplugged everything from the tv including the cable cord and power and let it sit overnight then only plugged the power cord back in and it still won’t turn back on the red light blinks non stop. Is scheduling a repair appointment best at this stage?
Это хороший вопрос?
Оценка 13
5 Комментариев
Thank you - that was my thought too so I wanted to make sure - appreciate the information!
из
LG 65UH5500 UA, manufactured in May 2016, purchased in Jan 2017. NOW IT WONT TURN ON ANY MORE. Red blinking LED.
Is it possible that power capacitors are blown? Is it possible to replace them? I had similar issue with a Samsung, after replacing a set of capacitors, it worked.
из
The red led will blink 3 times and then nothing.
из
My LG tv won’t turn on. No power at all. I unplugged, I took the batteries out of remote to reset remote. Nothing. What fo I fo now?
из
Hi @barbe1959
What is the model number of the TV?
Have you checked that the wall power outlet (or powerstrip) that the TV is connected to is working OK by testing it with another known working appliance e.g. hair dryer?
из
Добавить комментарий
Ответов (4)
Выбранное решение
Hi Shri,
If the power shut off at your house, it is possible that there was a power spike and it may have fried the power supply on your TV. I would schedule an appointment with a maintenance person or check your manual for information regarding the blinking red light.
Best of Luck,
Drew.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Hi my mother in law has a LG tv am not sure what model it is but red light is on so she presses it and the red light flashed couple of times and the screen is still black we’ve tried all trouble shouting and nothing read on different site it could be the capacitors but also so someone tried that and didn’t work any ideas please
из
Наиболее полезный ответ
You need to count the red light blinks then do a google search. The number of flashes will give you an idea of the problem.
Оценка 4
3 Комментариев:
It blinks non stop when the power cord is plugged in. The blinking doesn't go away nor does the tv turn back on.
из
Same with me. Model LG TV 42LD450
из
Hello, my LG smart television is not loading after it is powered on, it only displays LG and stops. Please help
из
'''++@shri1++'''
if you want to fix this yourself, you will have to give us a model number. Since you already attempted a reset it by keeping it unplugged, you want to go ahead and remove the back from your TV. The constant blinking is usually indicative of a bad power board. Take a look at all of your boards and in particular the power board. Depending on your model there may be a few different fuses on the board. Check those for continuity and if they do check out as good, get a multimeter and check for power on your board. Post a couple of good pictures with your question so that we can see what you see. Use this guide Adding images to an existing question for that. That way we can possibly assist you with further troubleshooting. If you do not want to fix it then proceed with the accepted answer of course.
Оценка 3
3 Комментариев:
Yes it will spark when it will thunder we should plug the switch and set box pin, dish wire then it will not spark
из
My tv flash red light but not turn on and show disply
из
@END GAMER what is the make and model of your TV? What have you checked? What have you tried to fix it?
из
Посмотреть содержание изображения:
Оценка 0
1 Комментарий:
@amirhossei83125 nice picture but it does not tell us anything about any issues your TV may have. Try a little bit more effort and give us more background if you need to repair this TV.
Translation
из
Добавьте свой ответ
Shri Parsons будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 10
За последние 30 дней: 60
За всё время: 140,564
