Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Дата выхода 25 сентября 2015 г. Модель A1688 / A1633. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
Вопросов 20 Показать все
Incorrect password and unable to join
i got 2 iphone 6s that i bought from a person and he said to me they work fine but they don't connect to wifi nettworks.
So i got them i have DFU restored both of them - SAME PROBLEM
I have changed their wifi anntenas - SAME PROBLEM
I have cleaned their motherboard with alcool - SAME PROBLEM
so i decided to ask you guys if you have any knowlege about this problem i know it's motherboard fault but i'm not good and finding problem by myself.
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
The phones are iCloud locked. You’ll need to ask the seller to unlock them if he can’t then return them and get your money back as they are likely stolen!
And No there is no way to unlock them. Think of it this way… You have an egg in your hand without cracking (opening) the shell open can you get whats inside out? Nope!
Same here you can’t get in without breaking the iPhone.
Был ли этот ответ полезен?
Оценка 1
4 Комментариев:
They don't have icloud account open i mentioned that i have restored them with itunes in DFU mode they started like every unlocked iphone
Anyway thanks for your contribution
из
DFU mode does not undo the iCloud lock. All you've done is refreshed the phones firmware if needed
из
So I assume these phones have passed the activation setup page.
Is the Wi-Fi able to turn on? Or is it stuck greyed out off?
из
@danj If you hard reset the iPhone and it has iCloud and find my iPhone on you just can't pass the activation setup page. They passed it as they don't have iCloud lock.
@benjamen50 The WiFi turns on and its range is perfect but in every router that i want to connect even with password or no password the popup just shows up and says "Incorrect password" or "Unable to join network"
из
Help! I have the same issue and my iPhone is brand new from o2 the day they were launched so I know it’s not a knock off!
Оценка 0
2 Комментариев:
Bring your phone to an Apple Store with your sales receipt.
It turns out your phones ID may have been stolen by someone! Basically, they used a utility Apple made available a few years ago to find unused Phone ID's to use on their phone. So when you tried to setup via the activation setup page it won't work!
из
how to get back phones id if u don't have an apple store nearby
из
Добавьте свой ответ
Adrian Zymeri будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 3,733
