Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
flood of water from bottom of machine
what would cause water to flood out of bottom of my machine
Это хороший вопрос?
Оценка 2
1 Комментарий
My washer is model 110.44422610
And I'm having the same problem.
из
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
Hi @bear10 ,
Have you checked under the machine to see where the water is coming from?
It may be a cracked hose from the the water drain pump for example.
What is the full model number of the washer?
Был ли этот ответ полезен?
Оценка 1
I have a Kenmore 600 series top loader. We had a problem with rodents in the house and they started to chew the drain hoses which caused the same problem. There are two hoses - one short one that goes from the bottom of the fill basin to the pump and the other goes from the pump to wherever your laundry water empties.
These hoses should always have a little water in them since they'll never fully drain.
Оценка 1
Добавьте свой ответ
jerry visconti будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 573
