Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
Вопросов 20 Показать все
After water damage - LCD has no light
Hi,
The phone dropped into a toilet.
And immidiate got out, and been dried with a fan.
It was 1 week ago, and phone works fine but the screen is very dark, and it has no light!
I barely see the icons..
But the incoming/outgoing phonecalls are working, also the touch.
What is responsible for the Light in the screen? That could be damaged?
**Note:
  • Anyway I am going to open the phone now and make a water damage repair (Clean with alcohol etc)
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
jea, clean it and the display connector ! should help very well. if not, you should buy a new display
cost 20 bugs.
Был ли этот ответ полезен?
Оценка 1
9 Комментариев:
in a 3gs it is more likely the backlight coil if a good clean doesn't sort the problem out. that part is a 6r8 which will require soldering...
из
Hi pollytintop,
I didn't understand what is: "backlight coil", and "6r8 which will require soldering"
I took out the LCD, cleaned the connector.. and still no light :/
I checked with another LCD, and the other LCD works fine.
Thank you for helping.
Shai
из
Ok, Did you mean that the problem is in the backlight coil, and in order to fix it, I will have to solder it?
Can you please add a picture that shows where is that backlight coil?
Thanks again man!!!
из
you've answered your own question. another LCD works.. so the problem isn't the backlight coil (which is on the motherboard) clean the LCD flex end and see if that helps. otherwise like ion said you need a new LCD.
из
Yes - Another LCD works.
I did not know the coil is on the MB :-)
So..?
What about some coils/flex cables on the defective LCD? No option o fix it somewho?
Thanks
из
Показать 4 больше комментариев
Добавьте свой ответ
Shai будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 3,573
