Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
The Samsung Galaxy S6 Edge+ is the larger variant of the Galaxy S6 Edge smart phone.
Вопросов 20 Показать все
help me to fix my phone pls
Hello ..
i have samsung s6 edge + ( sm-g928f ) i love this device and been using it since 3 years ..
yesterday i wonted to root it but couldn't so i road about that and i had to turn off the OEM
after root was every thing good until i enable OEM and restart the device ..
it stak in boot screen with red line ( Binary Blocked by FRP Lock on )
i didn't knew what i should do so i try every thing i know to backup the file i couldn't ,,
finally i fleshed a stocked ROM from Sammobiel and plug it in the charging cable and installed every thing i need from store ..
after that Evey time i unplug the phone from phone 10 sec freeze and turn off so i flashed second time another ROM and third from sammobile
if the phone was unplug and i turn it on when i get the phone menu restart immediately
i tried safe mode the same
what i the problem is it from firmware of from device ( ic ,battery , charging port or .. )
Это хороший вопрос?
Оценка 2
Добавить комментарий
Ответов (1)
Выбранное решение
It’s usually either wrong firmware was flashed on the phone or phone was not factory reset in recovery mode after flashing.
SM-G928F, make sure that the firmware is the latest version for your phone as well. Try factory resetting first and see how that goes in recovery mode.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
i downloaded the last firmware but always turn off when i unplug the charger after 10 sec idn what i should do :(
из
Добавьте свой ответ
rimon будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 9
За последние 30 дней: 9
За всё время: 279
