Руководства по ремонту HP Compaq 6910p.
DVD ROM removing problem
How to remove the DVD ROM from HP Compaq 6910p
Это хороший вопрос?
Счет 0
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Hi @elishaalfred ,
Here’s a link to the service manual for the laptop.
Scroll to p.54 to view the necessary pre-requisite steps and then the procedure to remove the DVD drive.
Был ли этот ответ полезен?
Счет 1
Most times, it is only one screw on the bottom of the laptop and the DVD/CD drive can be pulled out.
Lay the laptop down on its backside to expose the bottom case. There should be a screw with a symbol next to it that looks similar to a CD or DVD or disc. Remove this screw, press the eject button to the left of the drive, and the DVD drive should eject and slide out easily.
Счет 1
The following is a teardown for your unit:
https://www.youtube.com/watch?v=HP2_-_13...
If you are trying to remove a stuck DVD disc rather than removing the entire DVD drive, most drives include a manual ejection with a paper clip via a small hole on the drive's front panel.
Счет 0
1 Комментарий:
@propman Right on. I wasn't thinking of that. If the disc is stuck, you will need a paper clip to manually eject the disc with the small hole on the front of the drive.
из Поделиться
Добавьте свой ответ
Elisha буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 15
За все время: 1,172
