Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Water damage or faulty digitizer?
I’ve been all through the forums, so forgive me if this has been answered.
Our iPad mini 2 (I know, it’s super old) fell into water. I immediately shut it off, opened it up, and pulled everything out. There wasn’t much water inside, but the digitizer connector did have a droplet of water in it.
Meanwhile, I cracked the LCD. Left the iPad open to dry and ordered a new LCD. It works perfectly. But the touch screen no longer works. There is no visible sign of water damage.
Is the digitizer likely damaged by water? Is there any point in ordering a new digitizer? I didn’t damage the digitizer when I opened it, I don’t think.
This is my son’s iPad and he uses it for school, so I’m pretty eager for it to work. We can’t afford a new one, so thanks for any advice.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Выбранное решение
Usually it comes down to two things:
  • Missing pins on the touch screen connector on the logic board, this will be obvious when inspecting them for missing pins
  • Crushed digitizer cable, the cable bends in a way that it does not get crushed by the housing on the iPad between the glass. When closing it up there is a spot where it can get squished which ruins the digitizer cable.
If it is the latter the screen will need to be replaced.
iPad Mini 2 LTE Front Panel Replacement
iPad mini 1/2 Screen Digitizer
Replace a screen digitizer compatible with the 1st or 2nd gen iPad mini models A1432, A1454, A1455, A1489, A1490. Part #820-3291-A, 821-3291. Home Button and Digitizer Cable included. Изображение
Продукт
$34.99
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Heather Hicks будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 5
За последние 30 дней: 12
За всё время: 259
