Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
Вопросов 20 Показать все
What good GPUs are compatible with iMac late 2009 27 inch?
I am wondering the best possible mxm 3.0 type b GPU compatible with my iMac late 2009 27 inch. I have found a couple of GPUs on eBay such as the 880m and the 980m both with higher cram capacities which I would prefer for games and such. And if those don’t work if someone could comment the best possible one for around 200 preferably under.
Thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
The problem with more modern games is they run these older GPU to hard and burn them out.
While simple card games and low FPS graphical games will run just fine on this older system Doom and anything like it will quickly run the system into the red zone!
I know thats not what you want to hear! I would frankly just get a used 2013 or newer system as they have much better GPU’s.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Oh because I'm trying to restore one that I previously used.
из
So you burnt it out already ;-}
Here's what your system came with:
● ATI Radeon HD 4670 256MB, Apple P/N 661-5314
● ATI Radeon HD 4850 512MB, Apple P/N 661-5315
This is the last series of MXM boards Apple used in the 2011 27" model:
● AMD Radeon HD 6770M 512MB, Apple P/N 661-5967
● AMD Radeon HD 6970M 1GB, Apple P/N 661-5968
● AMD Radeon HD 6970M 2GB, Apple P/N 661-5969
Using just any MXM board which is not flashed with the Apple custom ROM will loose functions like brightness control as well as sleep.
из
Добавьте свой ответ
Reece Clegg будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 593
