Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
replace LED backlight at Dell Latitude 5289
Hello :)
The touchscreen of my dell latitude stays dark. After troubleshooting it tourned out to be the LED backlight. Can I just change the backlight or do I have to chance the whole touchscreen? Until now I have very few experience in repairing electric devices. Answers in english and german are welcome.
Thank you very much!
Kind regards
Katharina
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Hi @beuteltier
The backlights in the screen are LEDs and are a part of the screen assembly and cannot be individually replaced. The complete display assembly would need to be replaced.
Here is the service manual that will help you to replace the display assembly if that is what the trouble is.
It may not be the screen, it could also be a faulty lid sensor or a backlight power fuse or a loose eDP cable connection (video cable).
To try and test the lid sensor, connect an external monitor to the laptop so that you can navigate through the settings and change the lid switch setting to do nothing. Save the changes and restart the laptop and check
It may be better to purchase the schematics for the motherboard to help determine where the problem is first. (I couldn't find a free download - also verify that I've linked the correct motherboard i.e. Compal CAZ30/CAZ40 LA-E111P as printed on motherboard itself).
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Hi @jayeff,
thanks for your fast answer. I will check out all these things and tell how it tourned out.
из
@beuteltier
I updated my answer to include a possible lid switch check
Cheers
из
Добавьте свой ответ
Katharina будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 296
