Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Help for Samsung televisions with model code LN32D403.
Why my tv screen white light
Whymy tv screen whitem
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
@behailu27567 if you are saying that your TV only shows a white screen, then this manes that your backlight is turning on but you are not getting any video. This can be caused by a bad main board as well as a bad buffer board on the LCD panel itself. WE will need to know your exact model and we will need to see your boards.
Unplug your TV and remove the back cover. Then take a look at all the boards and check for any burned/damaged component. Remove the ribbon cables and check those for tears, rips,corrosion. Take some good pictures of all of those boards and post those with your Question. That way we can see what you see and hopefully guide you further. Here is a guide for that Adding images to an existing question
Verify that your TV is a Samsung LN32D403
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Behailu будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 5
За последние 30 дней: 21
За всё время: 21
