Google Pixel 7 Pro Screen Replacement
Выберете то, что вам нужно
Видео обзор
  1. Google Pixel 7 Pro Screen Replacement, Safety precautions: шаг 1, изображение 1 из 2 Google Pixel 7 Pro Screen Replacement, Safety precautions: шаг 1, изображение 2 из 2
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
  2. Google Pixel 7 Pro Screen Replacement, Screen removal information: шаг 2, изображение 1 из 3 Google Pixel 7 Pro Screen Replacement, Screen removal information: шаг 2, изображение 2 из 3 Google Pixel 7 Pro Screen Replacement, Screen removal information: шаг 2, изображение 3 из 3
    • The screen of the Google Pixel 7 Pro is held in place by plastic clips and adhesive. Note the following:
    • Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
    • Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
    • During the removal procedure, make sure to insert your opening picks in the right position to avoid separating the screen from its safety frame.
    • Only insert the pick up to ~3.5 mm during the removal procedure to avoid damaging the internals and to avoid interfering with the plastic clips.
    • There are several plastic clips around the whole screen. If your opening pick gets blocked during the screen removal procedure, you've inserted your pick too deep underneath the screen.
  3. Google Pixel 7 Pro Screen Replacement, Anti-Clamp instructions: шаг 3, изображение 1 из 3 Google Pixel 7 Pro Screen Replacement, Anti-Clamp instructions: шаг 3, изображение 2 из 3 Google Pixel 7 Pro Screen Replacement, Anti-Clamp instructions: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. Google Pixel 7 Pro Screen Replacement: шаг 4, изображение 1 из 3 Google Pixel 7 Pro Screen Replacement: шаг 4, изображение 2 из 3 Google Pixel 7 Pro Screen Replacement: шаг 4, изображение 3 из 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. Google Pixel 7 Pro Screen Replacement: шаг 5, изображение 1 из 3 Google Pixel 7 Pro Screen Replacement: шаг 5, изображение 2 из 3 Google Pixel 7 Pro Screen Replacement: шаг 5, изображение 3 из 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  6. Google Pixel 7 Pro Screen Replacement, Loosen the display adhesive: шаг 6, изображение 1 из 1
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to the touch.
  7. Google Pixel 7 Pro Screen Replacement, Insert an opening pick: шаг 7, изображение 1 из 3 Google Pixel 7 Pro Screen Replacement, Insert an opening pick: шаг 7, изображение 2 из 3 Google Pixel 7 Pro Screen Replacement, Insert an opening pick: шаг 7, изображение 3 из 3
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the bottom edge and try again.
    • Insert an opening pick into the gap.
  8. Google Pixel 7 Pro Screen Replacement, Prevent damage to your phone: шаг 8, изображение 1 из 2 Google Pixel 7 Pro Screen Replacement, Prevent damage to your phone: шаг 8, изображение 2 из 2
    • To avoid damaging your phone, don't insert your pick more than ~2.5 mm as you separate the screen adhesive. Note the following areas:
    • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
    • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
  9. Google Pixel 7 Pro Screen Replacement, Slice the bottom edge adhesive: шаг 9, изображение 1 из 2 Google Pixel 7 Pro Screen Replacement, Slice the bottom edge adhesive: шаг 9, изображение 2 из 2
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  10. Google Pixel 7 Pro Screen Replacement: шаг 10, изображение 1 из 2 Google Pixel 7 Pro Screen Replacement: шаг 10, изображение 2 из 2
    • Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
    • There's a plastic clip in the bottom left corner that will block your opening pick. Only use the tip of the opening pick (~1 mm) to work your way around it.
  11. Google Pixel 7 Pro Screen Replacement, Release the left clips: шаг 11, изображение 1 из 3 Google Pixel 7 Pro Screen Replacement, Release the left clips: шаг 11, изображение 2 из 3 Google Pixel 7 Pro Screen Replacement, Release the left clips: шаг 11, изображение 3 из 3
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive and to release the plastic clips.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  12. Google Pixel 7 Pro Screen Replacement, Slice the top edge adhesive: шаг 12, изображение 1 из 3 Google Pixel 7 Pro Screen Replacement, Slice the top edge adhesive: шаг 12, изображение 2 из 3 Google Pixel 7 Pro Screen Replacement, Slice the top edge adhesive: шаг 12, изображение 3 из 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (~2.5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  13. Google Pixel 7 Pro Screen Replacement, Release the right clips: шаг 13, изображение 1 из 3 Google Pixel 7 Pro Screen Replacement, Release the right clips: шаг 13, изображение 2 из 3 Google Pixel 7 Pro Screen Replacement, Release the right clips: шаг 13, изображение 3 из 3
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive and release the right plastic clips.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly by a flex cable.
  14. Google Pixel 7 Pro Screen Replacement, Open up the phone: шаг 14, изображение 1 из 3 Google Pixel 7 Pro Screen Replacement, Open up the phone: шаг 14, изображение 2 из 3 Google Pixel 7 Pro Screen Replacement, Open up the phone: шаг 14, изображение 3 из 3
    • Lift the right edge of the screen up and towards the left side of the device, like opening a book.
    • Don't twist the screen or move it too far away from the frame to avoid straining or damaging the flex cable.
    • Rest the screen upside down and parallel to the frame.
  15. Google Pixel 7 Pro Screen Replacement, Release the display cable bracket: шаг 15, изображение 1 из 2 Google Pixel 7 Pro Screen Replacement, Release the display cable bracket: шаг 15, изображение 2 из 2
    • The display cable bracket sits tightly and requires some force to release it.
    • Insert one arm of a pair of tweezers into the opening at the upper end of the display cable bracket.
    • Push the bracket inwards and pry up to release it.
  16. Google Pixel 7 Pro Screen Replacement, Remove the display cable bracket: шаг 16, изображение 1 из 3 Google Pixel 7 Pro Screen Replacement, Remove the display cable bracket: шаг 16, изображение 2 из 3 Google Pixel 7 Pro Screen Replacement, Remove the display cable bracket: шаг 16, изображение 3 из 3
    • Use a pair of tweezers to remove the display cable bracket by pulling it from underneath the midframe and in direction of the camera.
  17. Google Pixel 7 Pro Screen Replacement, Disconnect the display cable: шаг 17, изображение 1 из 2 Google Pixel 7 Pro Screen Replacement, Disconnect the display cable: шаг 17, изображение 2 из 2
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  18. Google Pixel 7 Pro Screen Replacement, Screen information: шаг 18, изображение 1 из 1
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  19. Google Pixel 7 Pro Screen Replacement, Separate the screen: шаг 19, изображение 1 из 3 Google Pixel 7 Pro Screen Replacement, Separate the screen: шаг 19, изображение 2 из 3 Google Pixel 7 Pro Screen Replacement, Separate the screen: шаг 19, изображение 3 из 3
    • Remove the screen.
    • During reassembly:
    • If you replaced your screen, check the front-facing camera hole and the sensor cutout on your replacement screen, and remove any remaining liners.
    • Check the frame for deformed grounding springs that stick straight up. These spring contacts should rise at a shallow angle. Use your finger to gently bend any deformed springs downward.
    • Remember to reinstall the display cable bracket.
    • This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone and disconnect the screen.
    • Follow this guide if you're using custom-cut adhesives for your device. Follow this guide in case you're using a pre-cut adhesive card.
    • If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
Заключение
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 7 Pro answers community for help.
131 человек успешно провели ремонт по этому руководству.
Dominik Schnabelrauch
Участник с: 11/23/16
230 712 Репутация
Автор 682 руководств
Команду
iFixit Участник iFixit
Staff
118 членов
Автор 19 632 руководств
99Комментарии к руководству
After doing a few of these, using the fingerprint calibration tool is always needed. https://pixelrepair.withgoogle.com/udfps
I think it should be included in the final steps for completeness.
Also, the plastic bracket on the back of the screen usually is more willing to separate from the screen than from the phone chassis. I think this may lead to confusion for some people who may try to install the new screen over the old plastic. Some mention of this would be helpful.
Chip Needham - Ответить
All guides say we have to recalibrate the fingerprint sensor after a screen replacement by going here https://pixelrepair.withgoogle.com/udfps
Problem is that this does not work anymore. With a Pixel 7 Pro it says software failed to install. Looking at Android and Google forums is seems a common problem that broke this year. Is there another way to install the fingerprint calibration software on the phone without that link above??
Michael Blake -
I never change any mobile phone parts.
Should I try it?
Tulio Gilberto Silva Junior - Ответить
Yes. It worked like a charm. I just followed the steps, and after calibrating the fingerprint sensor, everything was working 100%.
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 214
За последние 7 дней: 1,751
За последние 30 дней: 7,925
За всё время: 211,307
