Compaq Evo N400c Backup Battery Replacement
Выберете то, что вам нужно
    1. Compaq Evo N400c Backup Battery Replacement, Disconnect batteries: шаг 1, изображение 1 из 3 Compaq Evo N400c Backup Battery Replacement, Disconnect batteries: шаг 1, изображение 2 из 3 Compaq Evo N400c Backup Battery Replacement, Disconnect batteries: шаг 1, изображение 3 из 3
      • Assuming that you already have your Multimedia Expansion Base detached(if you have it), disconnect both the handle battery(the one that sticks out) and the system battery(again, if you have those)
      • System battery clips
      • Handle battery clips
      Спросите у FixBot
      Добавить комментарий
    2. Compaq Evo N400c Backup Battery Replacement, Remove screws: шаг 2, изображение 1 из 3 Compaq Evo N400c Backup Battery Replacement, Remove screws: шаг 2, изображение 2 из 3 Compaq Evo N400c Backup Battery Replacement, Remove screws: шаг 2, изображение 3 из 3
      • You will need to remove the keyboard and palmrest screws, which require the use of a Torx T8 or flathead screwdriver.
      • If your N400c or N410c still has this screw, then you must use a screwdriver of the aforementioned Torx size.
      • If you find any Philip head screws holding the keyboard and/or palmrest in place instead of the Torx ones, then the system most likely had those screws replaced at one point in time.
      Спросите у FixBot
    3. Compaq Evo N400c Backup Battery Replacement: шаг 3, изображение 1 из 3 Compaq Evo N400c Backup Battery Replacement: шаг 3, изображение 2 из 3 Compaq Evo N400c Backup Battery Replacement: шаг 3, изображение 3 из 3
      • Carefully lift up the front left and right corners,
      • then you will need to use a small plastic opening tool to lift 2 clips on the front. The palmrest should flip open and rest over the keyboard.
      • If you have a N410c, skip this point and go on to the next one. If you have a N400c, disconnect the ribbon cable that connects the trackpoint to its buttons on the palmrest,
      • Lift the palmrest and then you can flip the keyboard over onto the screen, then you can see and disconnect the backup battery.
      Спросите у FixBot
    4. Compaq Evo N400c Backup Battery Replacement, Building your own backup battery: шаг 4, изображение 1 из 1
      • If you bought a pre-made backup battery, you can skip this step and "follow these steps in reverse order".
      • Otherwise, if you have a CR2016, CR2025 or similar size/thickness coin cell, then read for how easy it is to tape the contacts to your battery.
      • cut open the sleeve and carefully rip away the tabs from the old battery.
      • Hold the contacts to the battery as you tape them together.
      • Red = positive | Black = negative
      • Don't put too much tape, but wrap it tightly. Of course don't do it too tight.
      Спросите у FixBot
Заключение
Kevin Bhasi
Участник с: 12/26/14
1 355 Репутация
Автор 9 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 35
За последние 30 дней: 72
За всё время: 2,693
