Google Pixel 7 Pro Motherboard Replacement
Выберете то, что вам нужно
  1. Google Pixel 7 Pro Motherboard Replacement, Safety precautions: шаг 1, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Safety precautions: шаг 1, изображение 2 из 2
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
  2. Google Pixel 7 Pro Motherboard Replacement, Screen removal information: шаг 2, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Screen removal information: шаг 2, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Screen removal information: шаг 2, изображение 3 из 3
    • The screen of the Google Pixel 7 Pro is held in place by plastic clips and adhesive. Note the following:
    • Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
    • Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
    • During the removal procedure, make sure to insert your opening picks in the right position to avoid separating the screen from its safety frame.
    • Only insert the pick up to ~3.5 mm during the removal procedure to avoid damaging the internals and to avoid interfering with the plastic clips.
    • There are several plastic clips around the whole screen. If your opening pick gets blocked during the screen removal procedure, you've inserted your pick too deep underneath the screen.
  3. Google Pixel 7 Pro Motherboard Replacement, Anti-Clamp instructions: шаг 3, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Anti-Clamp instructions: шаг 3, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Anti-Clamp instructions: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Anti-Clamp
    $24.95
    Купить
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. Google Pixel 7 Pro Motherboard Replacement: шаг 4, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement: шаг 4, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement: шаг 4, изображение 3 из 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. Google Pixel 7 Pro Motherboard Replacement: шаг 5, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement: шаг 5, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement: шаг 5, изображение 3 из 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  6. Google Pixel 7 Pro Motherboard Replacement, Loosen the display adhesive: шаг 6, изображение 1 из 1
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to the touch.
  7. Google Pixel 7 Pro Motherboard Replacement, Insert an opening pick: шаг 7, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Insert an opening pick: шаг 7, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Insert an opening pick: шаг 7, изображение 3 из 3
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the bottom edge and try again.
    • Insert an opening pick into the gap.
  8. Google Pixel 7 Pro Motherboard Replacement, Prevent damage to your phone: шаг 8, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Prevent damage to your phone: шаг 8, изображение 2 из 2
    • To avoid damaging your phone, don't insert your pick more than ~2.5 mm as you separate the screen adhesive. Note the following areas:
    • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
    • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
  9. Google Pixel 7 Pro Motherboard Replacement, Slice the bottom edge adhesive: шаг 9, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Slice the bottom edge adhesive: шаг 9, изображение 2 из 2
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  10. Google Pixel 7 Pro Motherboard Replacement: шаг 10, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement: шаг 10, изображение 2 из 2
    • Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
    • There's a plastic clip in the bottom left corner that will block your opening pick. Only use the tip of the opening pick (~1 mm) to work your way around it.
  11. Google Pixel 7 Pro Motherboard Replacement, Release the left clips: шаг 11, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Release the left clips: шаг 11, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Release the left clips: шаг 11, изображение 3 из 3
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive and to release the plastic clips.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  12. Google Pixel 7 Pro Motherboard Replacement, Slice the top edge adhesive: шаг 12, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Slice the top edge adhesive: шаг 12, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Slice the top edge adhesive: шаг 12, изображение 3 из 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (~2.5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  13. Google Pixel 7 Pro Motherboard Replacement, Release the right clips: шаг 13, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Release the right clips: шаг 13, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Release the right clips: шаг 13, изображение 3 из 3
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive and release the right plastic clips.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly by a flex cable.
  14. Google Pixel 7 Pro Motherboard Replacement, Open up the phone: шаг 14, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Open up the phone: шаг 14, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Open up the phone: шаг 14, изображение 3 из 3
    • Lift the right edge of the screen up and towards the left side of the device, like opening a book.
    • Don't twist the screen or move it too far away from the frame to avoid straining or damaging the flex cable.
    • Rest the screen upside down and parallel to the frame.
  15. Google Pixel 7 Pro Motherboard Replacement, Release the display cable bracket: шаг 15, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Release the display cable bracket: шаг 15, изображение 2 из 2
    Купить
    • The display cable bracket sits tightly and requires some force to release it.
    • Insert one arm of a pair of tweezers into the opening at the upper end of the display cable bracket.
    • Push the bracket inwards and pry up to release it.
  16. Google Pixel 7 Pro Motherboard Replacement, Remove the display cable bracket: шаг 16, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Remove the display cable bracket: шаг 16, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Remove the display cable bracket: шаг 16, изображение 3 из 3
    • Use a pair of tweezers to remove the display cable bracket by pulling it from underneath the midframe and in direction of the camera.
  17. Google Pixel 7 Pro Motherboard Replacement, Disconnect the display cable: шаг 17, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Disconnect the display cable: шаг 17, изображение 2 из 2
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  18. Google Pixel 7 Pro Motherboard Replacement, Separate the screen: шаг 18, изображение 1 из 1
    • Separate the screen from the phone assembly.
    • During reassembly:
    • Check that all screws are tightened and there are no loose parts.
    • Reconnect the screen and test your phone to make sure it works. Power it back down and continue reassembly.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Follow this guide if you're using custom-cut adhesives for your device.
    • Follow this guide in case you're using a pre-cut adhesive card.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
  19. Google Pixel 7 Pro Motherboard Replacement, Peel off the graphite foil: шаг 19, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Peel off the graphite foil: шаг 19, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Peel off the graphite foil: шаг 19, изображение 3 из 3
    Купить
    • Use a pair of tweezers to carefully peel the graphite foil off the battery and midframe.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • If you're having a hard time peeling off the foil, you can apply a heated iOpener to the back of the device for two minutes to loosen its adhesive.
  20. Google Pixel 7 Pro Motherboard Replacement, Unfasten the charging port bracket screws: шаг 20, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Unfasten the charging port bracket screws: шаг 20, изображение 2 из 2
    • Use a Torx T3 screwdriver to remove the two 5.1 mm-long screws securing the charging port bracket.
  21. Google Pixel 7 Pro Motherboard Replacement, Remove the charging port bracket: шаг 21, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Remove the charging port bracket: шаг 21, изображение 2 из 2
    • Use a pair of tweezers to remove the charging port bracket.
  22. Google Pixel 7 Pro Motherboard Replacement, Unfasten the midframe screws: шаг 22, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Unfasten the midframe screws: шаг 22, изображение 2 из 2
    • Use a Torx T3 screwdriver to remove the six 5.1 mm-long screws securing the midframe.
  23. Google Pixel 7 Pro Motherboard Replacement, Remove the midframe: шаг 23, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Remove the midframe: шаг 23, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Remove the midframe: шаг 23, изображение 3 из 3
    • Use a pair of tweezers to remove the midframe.
    • During reassembly check the condition of the thermal pad. If it's damaged, remove the pad, clean the area with high-concentration (greater than 90%) isopropyl alcohol and a microfiber or lint-free cloth, and apply a new thermal pad.
  24. Google Pixel 7 Pro Motherboard Replacement, Disconnect the battery cable: шаг 24, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Disconnect the battery cable: шаг 24, изображение 2 из 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  25. Google Pixel 7 Pro Motherboard Replacement, Heat the battery's adhesive: шаг 25, изображение 1 из 1
    • Apply a heated iOpener to the back of the device to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
  26. Google Pixel 7 Pro Motherboard Replacement, Separate the battery pull tabs: шаг 26, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Separate the battery pull tabs: шаг 26, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Separate the battery pull tabs: шаг 26, изображение 3 из 3
    Купить
    • Use tweezers, or your fingers, to peel the plastic pull tabs away from the battery.
  27. Google Pixel 7 Pro Motherboard Replacement, Separate the battery's adhesive: шаг 27, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Separate the battery's adhesive: шаг 27, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Separate the battery's adhesive: шаг 27, изображение 3 из 3
    • Pull the tabs back and forth in a sawing motion up the length of the battery to separate the adhesive underneath.
    • Work slowly. It's easy to lose your grip and accidentally pull the tab up from under the battery.
    • If you're having difficulty separating the adhesive, apply more heat and wait for the adhesive to loosen.
    • If you lose or tear the release strip, follow the next step for an alternative battery removal method.
  28. Google Pixel 7 Pro Motherboard Replacement, How to remove a stuck battery: шаг 28, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, How to remove a stuck battery: шаг 28, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, How to remove a stuck battery: шаг 28, изображение 3 из 3
    • Follow this step if you couldn't loosen the battery using the battery release strip.
    • Apply a few drops of high concentration (90% or higher) isopropyl alcohol into the gap at the top edge of the battery.
    • Don't apply too much alcohol, or you'll loosen the NFC antenna and charging coil underneath the battery.
    • Wait about one minute for the alcohol solution to weaken the adhesive.
    • Use the flat end of a spudger or an opening pick to gently lift the top edge of the battery until you can grab it with your fingers.
    • Don't use excessive force on the battery. Slow, consistent pressure is all that's required to free it from the frame.
  29. Google Pixel 7 Pro Motherboard Replacement, Remove the battery: шаг 29, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Remove the battery: шаг 29, изображение 2 из 2
    • Tilt the battery out of the device to separate the rest of the adhesive.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • To secure the replacement battery:
    • Apply pre-cut adhesive adhesive or double-sided tape to the battery well at the places where the old adhesive was located, not directly onto the battery.
    • Temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it's seated.
    • Make sure that the battery sits in the center of the battery well and there's an even gap around the battery.
    • Press the new battery firmly into place.
  30. Google Pixel 7 Pro Motherboard Replacement, Unfasten the mmWave antenna bracket screw: шаг 30, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Unfasten the mmWave antenna bracket screw: шаг 30, изображение 2 из 2
    • Use a Torx T3 screwdriver to remove the 5.1 mm-long screw securing the mmWave antenna bracket.
  31. Google Pixel 7 Pro Motherboard Replacement, Remove the mmWave antenna bracket: шаг 31, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Remove the mmWave antenna bracket: шаг 31, изображение 2 из 2
    Купить
    • Use a pair of tweezers to remove the mmWave antenna bracket.
  32. Google Pixel 7 Pro Motherboard Replacement, Disconnect the mmWave antenna cable: шаг 32, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Disconnect the mmWave antenna cable: шаг 32, изображение 2 из 2
    • Use a spudger to disconnect the mmWave antenna cable by prying the connector straight up from its socket.
  33. Google Pixel 7 Pro Motherboard Replacement, Loosen the mmWave antenna cable: шаг 33, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Loosen the mmWave antenna cable: шаг 33, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Loosen the mmWave antenna cable: шаг 33, изображение 3 из 3
    • The mmWave antenna cable is held in place by mild adhesive.
    • Slide an opening pick underneath the mmWave antenna cable starting at its bottom end.
    • Use the opening pick to separate the mmWave antenna cable from the motherboard.
  34. Google Pixel 7 Pro Motherboard Replacement, Remove the mmWave antenna assembly: шаг 34, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Remove the mmWave antenna assembly: шаг 34, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Remove the mmWave antenna assembly: шаг 34, изображение 3 из 3
    • Use a pair of tweezers to lift the mmWave antenna including its cable out of its recess.
    • Remove the mmWave antenna assembly.
  35. Google Pixel 7 Pro Motherboard Replacement, Remove the thermal paste: шаг 35, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Remove the thermal paste: шаг 35, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Remove the thermal paste: шаг 35, изображение 3 из 3
    • Use the flat end of a spudger to scrape the thermal paste off the mmWave antenna.
    • Clean any remaining thermal paste with isopropyl alcohol and either a coffee filter or a lint-free cloth.
    • Repeat the cleaning process for the thermal paste on the mmWave antenna bracket.
    • During reassembly, follow this guide for reapplying thermal paste onto the mmWave antenna.
  36. Google Pixel 7 Pro Motherboard Replacement, Unfasten the rear camera assembly screws: шаг 36, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Unfasten the rear camera assembly screws: шаг 36, изображение 2 из 2
    • Use a Torx T3 screwdriver to remove the two 5.1 mm-long screws securing the rear camera assembly.
  37. Google Pixel 7 Pro Motherboard Replacement, Remove the spring: шаг 37, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Remove the spring: шаг 37, изображение 2 из 2
    • Use a pair of tweezers to remove the spring at the top left corner of the rear camera assembly.
  38. Google Pixel 7 Pro Motherboard Replacement, Disconnect the telephoto camera cable: шаг 38, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Disconnect the telephoto camera cable: шаг 38, изображение 2 из 2
    • Use a spudger to disconnect the telephoto camera cable by prying the connector straight up from its socket.
  39. Google Pixel 7 Pro Motherboard Replacement, Disconnect the front facing camera: шаг 39, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Disconnect the front facing camera: шаг 39, изображение 2 из 2
    • Use a spudger to disconnect the front facing camera cable by prying the connector straight up from its socket.
    • Fold the cable upwards to free the rear camera assembly.
    • Do not fold the cable sharply and only bend it to avoid cable damage.
  40. Google Pixel 7 Pro Motherboard Replacement, Disconnect the wide and ultrawide lens cables: шаг 40, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Disconnect the wide and ultrawide lens cables: шаг 40, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Disconnect the wide and ultrawide lens cables: шаг 40, изображение 3 из 3
    • Use a spudger to disconnect the wide and ultrawide camera cables by prying the connectors straight up from their sockets.
  41. Google Pixel 7 Pro Motherboard Replacement, Remove the rear camera assembly: шаг 41, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Remove the rear camera assembly: шаг 41, изображение 2 из 2
    • Remove the rear camera assembly.
  42. Google Pixel 7 Pro Motherboard Replacement, Unfasten the earpiece speaker screw: шаг 42, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Unfasten the earpiece speaker screw: шаг 42, изображение 2 из 2
    • Use a Torx T3 screwdriver to remove the 3.1 mm-long screw securing the earpiece speaker.
  43. Google Pixel 7 Pro Motherboard Replacement, Loosen the earpiece speaker adhesive: шаг 43, изображение 1 из 1
    • Apply a heated iOpener to the camera glass to loosen the adhesive underneath the earpiece speaker. Apply the iOpener for at least 1 minute.
  44. Google Pixel 7 Pro Motherboard Replacement, Pry up the earpiece speaker: шаг 44, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Pry up the earpiece speaker: шаг 44, изображение 2 из 2
    • Insert the pointed end of a spudger between the top left corner of the earpiece speaker and the frame.
    • Pry upwards to loosen the earpiece speaker.
  45. Google Pixel 7 Pro Motherboard Replacement, Remove the earpiece speaker: шаг 45, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Remove the earpiece speaker: шаг 45, изображение 2 из 2
    • Use a pair of tweezers to remove the earpiece speaker.
  46. Google Pixel 7 Pro Motherboard Replacement, Remove the front facing camera: шаг 46, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Remove the front facing camera: шаг 46, изображение 2 из 2
    • Use a pair of tweezers to remove the front facing camera.
  47. Google Pixel 7 Pro Motherboard Replacement, Disconnect the white antenna cable: шаг 47, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Disconnect the white antenna cable: шаг 47, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Disconnect the white antenna cable: шаг 47, изображение 3 из 3
    • Use tweezers to grasp the white antenna cable connector at the top left corner of the motherboard.
    • Grasp the cable as close to the connector as possible to avoid damaging the connector.
    • Lift the coaxial connector straight up to disconnect the white antenna cable.
    • Use your tweezers to carefully loosen the cable from the retaining clips.
  48. Google Pixel 7 Pro Motherboard Replacement, Disconnect the black antenna cable on the left: шаг 48, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Disconnect the black antenna cable on the left: шаг 48, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Disconnect the black antenna cable on the left: шаг 48, изображение 3 из 3
    • Slide a pair of tweezers under the black antenna cable at the left antenna board until they're snug against the metal connector.
    • Lift the coaxial connector straight up to disconnect the black antenna cable.
  49. Google Pixel 7 Pro Motherboard Replacement, Disconnect the NFC antenna cable: шаг 49, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Disconnect the NFC antenna cable: шаг 49, изображение 2 из 2
    • Use a spudger to disconnect the NFC antenna cable by prying the connector straight up from its socket.
  50. Google Pixel 7 Pro Motherboard Replacement, Disconnect the antenna and microphone interconnect cable: шаг 50, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Disconnect the antenna and microphone interconnect cable: шаг 50, изображение 2 из 2
    • Use a spudger to disconnect the antenna and microphone interconnect cable by prying the connector straight up from its socket.
  51. Google Pixel 7 Pro Motherboard Replacement, Disconnect the black antenna cable on the right: шаг 51, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Disconnect the black antenna cable on the right: шаг 51, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Disconnect the black antenna cable on the right: шаг 51, изображение 3 из 3
    • Slide a pair of tweezers under the black antenna cable at the right antenna board until they're snug against the metal connector.
  52. Google Pixel 7 Pro Motherboard Replacement, Eject the SIM card tray: шаг 52, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Eject the SIM card tray: шаг 52, изображение 2 из 2
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
  53. Google Pixel 7 Pro Motherboard Replacement, Remove the SIM card tray: шаг 53, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Remove the SIM card tray: шаг 53, изображение 2 из 2
    • Remove the SIM card tray.
  54. Google Pixel 7 Pro Motherboard Replacement, Unfasten the motherboard screws: шаг 54, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Unfasten the motherboard screws: шаг 54, изображение 2 из 2
    • Use a Torx T3 screwdriver to remove the four 3.1 mm-long screws securing the motherboard.
  55. Google Pixel 7 Pro Motherboard Replacement, Pry up the motherboard: шаг 55, изображение 1 из 2 Google Pixel 7 Pro Motherboard Replacement, Pry up the motherboard: шаг 55, изображение 2 из 2
    • Make sure the motherboard isn't blocked or tangled by any cables during this step.
    • Insert a spudger underneath the top edge of the motherboard.
    • Pry upwards to loosen the motherboard until you can grab it with your fingers.
  56. Google Pixel 7 Pro Motherboard Replacement, Remove the motherboard: шаг 56, изображение 1 из 3 Google Pixel 7 Pro Motherboard Replacement, Remove the motherboard: шаг 56, изображение 2 из 3 Google Pixel 7 Pro Motherboard Replacement, Remove the motherboard: шаг 56, изображение 3 из 3
    • Grab the top end of the motherboard with your fingers.
    • Pull the motherboard in direction of the top edge of the frame to free the charging port from its recess.
    • Remove the motherboard.
    • Compare your new replacement part to the original part—you may need to transfer components like the antenna cables to your new motherboard.
Заключение
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 7 Pro answers community for help.
3 участников успешно повторили данное руководство.
Dominik Schnabelrauch
Участник с: 11/23/16
205 055 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 430 руководств
2 Комментариев
Where does one buy a motherboard?
michael wilson - Ответить
Does the microphone of a built-in calls come in the motherboard, or does it come in a single piece?
HUMAM AL-JALILATI - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 8
За последние 7 дней: 96
За последние 30 дней: 384
За всё время: 7,877
