Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
HP 15-da0002dx Battery Replacement
Abigail Aron
Abigail Aron и 2 другие участники
Последнее обновление January 10, 2025
10 - 20 минут
Легко
Ненаглядные фото
If the HP 15-da0002dx is not charging correctly or only works when plugged in, follow these to replace the battery.
The battery powers the computer and allows it to be used without a power cord. A faulty battery can lead to improper charging and low battery life. Before replacing the battery, make sure your computer’s software is up to date by visiting the latest Official Hp Website. Also be sure to check if the power adapter being used is the correct power adaptor for your computer. Visit the HP-da0002dx troubleshooting page for more information on software and power adaptor solutions.
Before using this guide, power off the computer and wait for the components to cool. Working over a non-carpeted surface will reduce the risk of ESD damage (electrostatic discharge). A non-carpeted surface should not be able to conduct electricity and is connected to a grounded surface. Another way to reduce the risk of ESD damage is by using a plastic tool when removing the battery as plastic does not conduct electricity.
Выберете то, что вам нужно
Инструменты
  1. HP 15-da0002dx Battery Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Make sure the computer is completely turned off.
  2. HP 15-da0002dx Battery Replacement: шаг 2, изображение 1 из 1
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx Battery Replacement: шаг 3, изображение 1 из 2 HP 15-da0002dx Battery Replacement: шаг 3, изображение 2 из 2
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
  4. HP 15-da0002dx Battery Replacement: шаг 4, изображение 1 из 1
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx Battery Replacement: шаг 5, изображение 1 из 1
    • Carefully flip over the computer so the HP label is now facing the ceiling.
  6. HP 15-da0002dx Battery Replacement: шаг 6, изображение 1 из 2 HP 15-da0002dx Battery Replacement: шаг 6, изображение 2 из 2
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx Battery Replacement: шаг 7, изображение 1 из 1
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
  8. HP 15-da0002dx Battery Replacement, Battery: шаг 8, изображение 1 из 1
    • Remove the screws holding the battery in place using a Phillips #1 screwdriver.
  9. HP 15-da0002dx Battery Replacement: шаг 9, изображение 1 из 2 HP 15-da0002dx Battery Replacement: шаг 9, изображение 2 из 2
    • Using your fingers, tilt the top part of the battery towards you.
    • Continue to pull the rest of the battery away from the mounting tabs to remove.
Заключение
5 человек успешно провели ремонт по этому руководству.
Abigail Aron
Участник с: 09/04/19
1 097 Репутация
Автор 5 руководств
Команду
University of Alabama, Team S2-G8, Bedsole Fall 2019 Участник University of Alabama, Team S2-G8, Bedsole Fall 2019
UA-BEDSOLE-F19S2G8
4 членов
Автор 6 руководств
1Комментарий к руководству
Where to find, buy the same battery spare???
Divya Lekha - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 3
За последние 7 дней: 16
За последние 30 дней: 47
За всё время: 4,520
