Huawei Honor 8 Front Camera Replacement
Введение
Перейти к шагу 1Use this guide to remove and replace a broken or defective front camera in your Huawei Honor 10.
You’ll need replacement adhesive to reattach components when reassembling the device.
Выберете то, что вам нужно
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction cup to create a small gap between the glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner.
Start to slide the tip of the opening pick from the bottom left corner along the side to cut the adhesive.
Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick under the top left corner of the rear glass.
Slide the opening pick along the top edge of the phone to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick at the top right corner of the phone.
Slide the opening pick along the right side to cut the remaining adhesive.
Remove the Phillips #00 screw (2.8 mm length) that secures the metal bracket on top of the fingerprint flex connector.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a pair of tweezers to remove the metal bracket that sits on top of the fingerprint and display flex connectors.
Remove these Phillips #00 screws securing the midframe bezel:
Eight screws with 3.5 mm length
Eight screws with 2.9 mm length
Some screws might be covered with a tamper proof sticker.
Insert an opening pick underneath the top right edge of the midframe bezel.
Use the opening pick to pry up the midframe bezel.
Insert the opening pick underneath the bottom left corner of the bezel and pry it up.
Insert the long edge of an opening pick in the seam between the midframe and the bezel on the left side of the phone.
Slide the opening pick along the left side of the phone to cut the adhesive underneath the midframe bezel.
Repeat the procedure on the right edge of the phone to cut the adhesive underneath the midframe bezel.
Carefully grasp the midframe bezel from the bottom corners and lift it upwards.
Remove the midframe bezel.
Use a spudger to pry up and disconnect the battery flex cable.
Use a spudger to pry up and disconnect the front camera flex cable from its motherboard socket.
Use a pair of tweezers to carefully lift the front camera out of its recess and remove it.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
