Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Huawei Mate 20 Pro Battery Replacement
Dominik Schnabelrauch
Последнее обновление June 29, 2021
1 - 2 часы
Средне
Предлагаемое руководство
Use this guide to replace a worn-out or dead battery in your Huawei Mate 20 Pro.
Opening the Huawei Mate 20 Pro will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally but will lose its water-protection.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Although it is possible to remove the battery without removing the main flex cable with the charging port, we recommend to do so to avoid damage to surrounding components.
You’ll need replacement adhesive to reattach components when reassembling the device.
Выберете то, что вам нужно
Запчасти
Инструменты
Показать больше…
  1. Huawei Mate 20 Pro Battery Replacement, Rear Glass: шаг 1, изображение 1 из 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
  2. Huawei Mate 20 Pro Battery Replacement: шаг 2, изображение 1 из 3 Huawei Mate 20 Pro Battery Replacement: шаг 2, изображение 2 из 3 Huawei Mate 20 Pro Battery Replacement: шаг 2, изображение 3 из 3
    • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner.
  3. Huawei Mate 20 Pro Battery Replacement: шаг 3, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement: шаг 3, изображение 2 из 2
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Huawei Mate 20 Pro Battery Replacement: шаг 4, изображение 1 из 3 Huawei Mate 20 Pro Battery Replacement: шаг 4, изображение 2 из 3 Huawei Mate 20 Pro Battery Replacement: шаг 4, изображение 3 из 3
    • Insert a third opening pick at the bottom left corner.
    • Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Huawei Mate 20 Pro Battery Replacement: шаг 5, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement: шаг 5, изображение 2 из 2
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the back cover.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Huawei Mate 20 Pro Battery Replacement: шаг 6, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement: шаг 6, изображение 2 из 2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
  7. Huawei Mate 20 Pro Battery Replacement: шаг 7, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement: шаг 7, изображение 2 из 2
    • Lift and remove the back cover.
    • Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply pressure for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
  8. Huawei Mate 20 Pro Battery Replacement, Motherboard Cover with NFC & Charging Coil: шаг 8, изображение 1 из 1
    • Remove the eight Phillips #00 screws (4.3 mm length).
  9. Huawei Mate 20 Pro Battery Replacement: шаг 9, изображение 1 из 3 Huawei Mate 20 Pro Battery Replacement: шаг 9, изображение 2 из 3 Huawei Mate 20 Pro Battery Replacement: шаг 9, изображение 3 из 3
    • Slide an opening pick under the black adhesive at the bottom left of the charging coil.
    • Carefully slide the opening from the left to the right side to loosen the adhesive.
  10. Huawei Mate 20 Pro Battery Replacement: шаг 10, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement: шаг 10, изображение 2 из 2
    • Insert an opening pick under the bottom left corner of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
    • Do not try to remove the motherboard cover all the way yet. The flex cable of the flash assembly is still connected to the motherboard.
  11. Huawei Mate 20 Pro Battery Replacement: шаг 11, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement: шаг 11, изображение 2 из 2
    • Carefully fold the motherboard cover in the direction of the battery.
    • Take special care to avoid ripping the flash assembly flex cable as it is still connected to the motherboard.
  12. Huawei Mate 20 Pro Battery Replacement: шаг 12, изображение 1 из 3 Huawei Mate 20 Pro Battery Replacement: шаг 12, изображение 2 из 3 Huawei Mate 20 Pro Battery Replacement: шаг 12, изображение 3 из 3
    • Use a spudger to pry up and disconnect the flash assembly flex cable.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Remove the motherboard cover including the NFC and charging coil.
  13. Huawei Mate 20 Pro Battery Replacement, Battery Disconnect: шаг 13, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement, Battery Disconnect: шаг 13, изображение 2 из 2
    • Use a spudger to pry up and disconnect the battery connector.
  14. Huawei Mate 20 Pro Battery Replacement, Daughterboard Cover: шаг 14, изображение 1 из 1
    • Remove the three Phillips #00 screws (4.3 mm length).
    • If you want to remove or replace the loudspeaker, daughterboard, battery, or the OLED screen, remove the four Phillips #00 screws (4.3 mm length) which hold down the loudspeaker assembly.
  15. Huawei Mate 20 Pro Battery Replacement: шаг 15, изображение 1 из 3 Huawei Mate 20 Pro Battery Replacement: шаг 15, изображение 2 из 3 Huawei Mate 20 Pro Battery Replacement: шаг 15, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Slide an opening pick under the top right corner of the daughterboard cover.
    • Use the opening pick to pry up the daughterboard cover. Remove the daughterboard cover with tweezers.
  16. Huawei Mate 20 Pro Battery Replacement, Loudspeaker & Daughterboard: шаг 16, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement, Loudspeaker & Daughterboard: шаг 16, изображение 2 из 2
    • Use a Spudger to pry up and disconnect the interconnect flex cable from the daughterboard.
  17. Huawei Mate 20 Pro Battery Replacement: шаг 17, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement: шаг 17, изображение 2 из 2
    • Use a Spudger to pry up and disconnect the interconnect flex cable from the motherboard.
    • Remove the interconnect flex cable.
  18. Huawei Mate 20 Pro Battery Replacement: шаг 18, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement: шаг 18, изображение 2 из 2
    • Use a pair of tweezers to pry up and disconnect the connector of the black coax cable from the daughterboard.
    • Unroute the black coax cable from the metal clip on the daughterboard and fold it to the side.
  19. Huawei Mate 20 Pro Battery Replacement: шаг 19, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement: шаг 19, изображение 2 из 2
    • Slide an opening underneath the top left corner of the loudspeaker cover.
    • Use the opening pick to pry up the loudspeaker and daughterboard assembly.
  20. Huawei Mate 20 Pro Battery Replacement: шаг 20, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement: шаг 20, изображение 2 из 2
    • Remove the loudspeaker and daughterboard assembly.
  21. Huawei Mate 20 Pro Battery Replacement, Charging Port with Main Flex Cable: шаг 21, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement, Charging Port with Main Flex Cable: шаг 21, изображение 2 из 2
    • Use a spudger to pry up and disconnect the main flex cable from the motherboard.
  22. Huawei Mate 20 Pro Battery Replacement: шаг 22, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement: шаг 22, изображение 2 из 2
    • Use a spudger to pry up and disconnect the main flex cable from the left daughterboard.
  23. Huawei Mate 20 Pro Battery Replacement: шаг 23, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement: шаг 23, изображение 2 из 2
    • Slide the flat end of a spudger under the right side of the main flex cable next to the charging port.
    • Use the spudger to pry up the main flex cable and to lever the charging port out of its recess.
  24. Huawei Mate 20 Pro Battery Replacement: шаг 24, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement: шаг 24, изображение 2 из 2
    • Remove the main flex cable including the charging port by lifting it upwards and then pulling it in the direction of the motherboard.
  25. Huawei Mate 20 Pro Battery Replacement, Battery: шаг 25, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement, Battery: шаг 25, изображение 2 из 2
    • Peel the orange adhesive strip labeled with a 1 off the battery. The orange adhesive tape will rip along a small perforated line.
  26. Huawei Mate 20 Pro Battery Replacement: шаг 26, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement: шаг 26, изображение 2 из 2
    • Peel the orange adhesive strip labeled with a 2 off the battery. The orange adhesive tape will rip along a small perforated line.
  27. Huawei Mate 20 Pro Battery Replacement: шаг 27, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement: шаг 27, изображение 2 из 2
    • Peel the orange adhesive strip labeled with a 3 off the battery.
    • Pull up the orange adhesive strip to lift the battery out of its recess.
    • Although these new adhesive tabs are supposed to make the battery removal easier, these may require some force. In case you're having trouble removing the battery, you can apply a heated iOpener to the center of the display, to loosen the adhesive underneath.
  28. Huawei Mate 20 Pro Battery Replacement: шаг 28, изображение 1 из 3 Huawei Mate 20 Pro Battery Replacement: шаг 28, изображение 2 из 3 Huawei Mate 20 Pro Battery Replacement: шаг 28, изображение 3 из 3
    • Swing the battery up to an upright position.
    • Peel the battery off the remaining adhesive.
    • Remove the battery.
    • During re-assembly, temporarily re-connect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
  29. Huawei Mate 20 Pro Battery Replacement: шаг 29, изображение 1 из 2 Huawei Mate 20 Pro Battery Replacement: шаг 29, изображение 2 из 2
    • Peel the battery's adhesive sticker off the midframe.
    • This step is mandatory if you are replacing the screen. However it is highly recommended to use a fresh adhesive sticker as well, when installing a new battery.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
Заключение
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%
15 человек успешно провели ремонт по этому руководству.
Участник с: 11/23/16
229 784 Репутация
Автор 682 руководств
Команду
iFixit Участник iFixit
Staff
119 членов
Автор 19 481 руководств
17 Комментариев
I have tried this with two new batteries now. I believe the device was water damaged by plugging the charger in while there was moisture in the port. The existing battery works but doesn't fast charge and gets very hot when charging, the battery also drains extremely quickly. Everytime insert a new battery the phone just get stuck in a boot loop, bringing up the Huawei powered by android screen before restarting, I have also replaced the charging port in hopes that may of been damaged and was causing the issue but this didn't work either. Any suggestion?
Joel Celnik - Ответить
Excellent Step by step guide thank you
Labony Kitchen - Ответить
Mate 20 battery has a serial number and is locked to the device. Replace it and get bootlooping confirmed on more than 5 devices so far. Don't understand why this isn't more common knowledge. I've had to do battery pcb swaps for a year now.
Alex Jax - Ответить
Battery replacement also results in Bootloop here - factory reset not helping. Safe mode also not working.
Nick Ceo - Ответить
I solved it by reusing the board at the base of the battery body
T,hisa - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 17
За последние 7 дней: 175
За последние 30 дней: 533
За всё время: 33,877
