Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Razer Blade 14" (2014) Screen Assembly Replacement
Sellers Hill
Sellers Hill и 2 другие участники
Последнее обновление April 9, 2019
30 мин.
Средне
Руководство, предоставленное сообществом
Swapping broken Razer Blade screen assembly with working one.
Выберете то, что вам нужно
Запчасти
Инструменты
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  • Phillips #00 Screwdriver
  • Nylon Tipped Tweezers
Показать больше…
  1. Razer Blade 14" (2014) Screen Assembly Replacement, Screen Assembly: шаг 1, изображение 1 из 1
    • Start by making sure your replacement assembly will work with your model. I bought this QHD assembly on eBay. This assembly includes the LCD, webcam, antenna, and touch digitizer. Before embarking, one should make sure that that a new screen assembly is necessary and will fix their problem. In my case, my LCD and touchscreen were fried.
    Could you provide some links for where to buy a replacement screen for the 2016 4k UHD Razer Blade?
    Tiffany Fong - Ответить
    If the screen is still largely functional (no bleed etc), but the glass is cracked - is there a way to repair it without replacing the entire assembly?
    Courtney Renèe Lane - Ответить
    Did you found a solution with that issue?
    I have the same problem
    Pierre Lavoine -
  2. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 2, изображение 1 из 1
    • unscrew the 10 (T5) torx screws to release the back panel. Be sure to fully drain your laptops battery or disconnect the battery before tampering with the internal components.
  3. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 3, изображение 1 из 1
    • Note the LCD Cable (Green), Antenna Cable (Red), Webcam Cable (Blue), and Charging cable (Purple). These all run to the screen assembly.
  4. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 4, изображение 1 из 1
    • Unplug before mentioned connectors. The webcam and charger cable may require a small pry tool. The LCD cable should disconnect with a light pull on the plastic tab. The antenna cables just pop off with some upward pressure.
  5. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 5, изображение 1 из 1
    • Unscrew Phillips head screws holding screen hinge.
  6. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 6, изображение 1 из 1
    • Unscrew right side screws, (you have to lift the charging port out of the case to fully release the hinge)
  7. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 7, изображение 1 из 1
    • After removing screws, work the screen assembly free from the case.
  8. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 8, изображение 1 из 1
    • Old screen.
  9. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 9, изображение 1 из 1
    • Lower case onto replacement screen, Making sure no cables get pinched in the hinge.
  10. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 10, изображение 1 из 1
    • Reconnect cables. (Route these cables in a way that would prevent getting crushed against the bottom cover)
  11. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 11, изображение 1 из 1
    • Replace bottom cover and check for functionality! (Markers are to protect identity of my friends and I)
Финишная черта
2 человек успешно провели ремонт по этому руководству.
Sellers Hill
Участник с: 04/13/17
128 Репутация
1 руководство автора
6 Комментариев
Just preformed the repair today with success!
The total repair took me about 30 minutes. I would suggest anyone doing this repair to buy a can of air before starting — I was amazed at how dirty my machine was under the case.
Many thanks for sharing this guide.
Caleb Dowdy - Ответить
can you share the ebay link thanks
ALI AL-Hashmi -
Is it possible to swap the matte screen with the glass touch screen
Kevin Chan - Ответить
Hi i try to do this in mi razer blade 14 2017…. the model is same, spare part and all connectors are the same, but when i turn on the laptop screen is black… the logo in the back of the screen is turn on also the touch works… i plugged a monitor to the laptop and works… i touch the screen in the laptop and see it works on the monitor….
when i go to settings and try to identify screens, cant see the screen of the laptop (default) as available.
I disable and enable the drivers (device manager) both graphic cards nothing happens.
I notice the connector has this number CA12020569TH is the same in both screens (i assume was part number), but down of this number connectors had a different number, spare part is 7AR01A7 (i assume was serial num) the original i don’t have it, i re install the broken screen,
Can you help me please, the spare part is a full assembly like the one in this post. Thanks for you time if you read this and best Regards
Tomas Gerardo Thomas Paz - Ответить
Hi Tomas Gerado,
I have the same problem. Have you solved the problem yet? Please share your experience.
Thank you,
Vinh PHAM GIA -
My screen is also black after doing this fix. Anyone solve this issue yet?
kaleblora -
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 5
За последние 7 дней: 11
За последние 30 дней: 23
За всё время: 11,949
