Samsung Galaxy Book Pro 360 15" Rubber Feet Replacement
Введение
Перейти к шагу 1Use this guide to replace the rubber feet in your Galaxy Book Pro 360 15" laptop.
Выберете то, что вам нужно
Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
Инструмент, используемый на этом этапе:Tweezers$4.99
Insert an opening pick between the rear case and the rubber foot.
Pry up with the pick and dislodge the foot from the rear case.
Use tweezers or your fingers to remove the rubber foot.
Repeat this process on the remaining rubber feet.
To reassemble your device, follow the instructions in reverse order.
