Xiaomi Redmi Note 7 Screen Replacement
Выберете то, что вам нужно
    1. Xiaomi Redmi Note 7 Screen Replacement, Loosen the rear glass adhesive: шаг 1, изображение 1 из 1
      • Apply a heated iOpener to the rear glass to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
      Спросите у FixBot
      Добавить комментарий
    2. Xiaomi Redmi Note 7 Screen Replacement, Insert an opening pick: шаг 2, изображение 1 из 3 Xiaomi Redmi Note 7 Screen Replacement, Insert an opening pick: шаг 2, изображение 2 из 3 Xiaomi Redmi Note 7 Screen Replacement, Insert an opening pick: шаг 2, изображение 3 из 3
      • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
      • If your rear glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the rear glass.
      • Lift the rear glass with the suction handle to create a small gap between the glass and the frame.
      • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      Спросите у FixBot
    3. Xiaomi Redmi Note 7 Screen Replacement, Slice the bottom edge adhesive: шаг 3, изображение 1 из 2 Xiaomi Redmi Note 7 Screen Replacement, Slice the bottom edge adhesive: шаг 3, изображение 2 из 2
      • Insert a second opening pick and slide it to the bottom left corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Спросите у FixBot
    4. Xiaomi Redmi Note 7 Screen Replacement, Slice the lefthand-side adhesive: шаг 4, изображение 1 из 3 Xiaomi Redmi Note 7 Screen Replacement, Slice the lefthand-side adhesive: шаг 4, изображение 2 из 3 Xiaomi Redmi Note 7 Screen Replacement, Slice the lefthand-side adhesive: шаг 4, изображение 3 из 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Insert a third opening pick at the bottom left corner.
      • Slide the opening pick along the left edge of the phone to slice the rear glass adhesive.
      • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
      Спросите у FixBot
    5. Xiaomi Redmi Note 7 Screen Replacement, Slice the top edge adhesive: шаг 5, изображение 1 из 2 Xiaomi Redmi Note 7 Screen Replacement, Slice the top edge adhesive: шаг 5, изображение 2 из 2
      • Insert a fourth opening pick under the top left corner of the rear glass.
      • Slide the opening pick along the top edge of the phone to slice the rear glass adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Спросите у FixBot
    6. Xiaomi Redmi Note 7 Screen Replacement, Slice the righthand-side adhesive: шаг 6, изображение 1 из 2 Xiaomi Redmi Note 7 Screen Replacement, Slice the righthand-side adhesive: шаг 6, изображение 2 из 2
      • Insert a fifth opening pick at the top right corner of the phone.
      • Slide the opening pick along the right edge to slice the remaining adhesive.
      • Don't try to remove the rear glass all the way yet. The fingerprint sensor is still connected to the motherboard.
      Спросите у FixBot
    7. Xiaomi Redmi Note 7 Screen Replacement, Open up the phone assembly: шаг 7, изображение 1 из 3 Xiaomi Redmi Note 7 Screen Replacement, Open up the phone assembly: шаг 7, изображение 2 из 3 Xiaomi Redmi Note 7 Screen Replacement, Open up the phone assembly: шаг 7, изображение 3 из 3
      • Carefully fold the rear glass to the left side of the phone assembly like you'd open the front cover of a book.
      • Avoid tensioning the fingerprint flex cable during this process.
      Спросите у FixBot
    1. Xiaomi Redmi Note 7 Screen Replacement, Unfasten the screws: шаг 8, изображение 1 из 1
      • Use a Phillips screw driver to remove the three 3.3 mm-long screws securing the connector cover to the midframe.
      Спросите у FixBot
    2. Xiaomi Redmi Note 7 Screen Replacement, Remove the connector cover: шаг 9, изображение 1 из 2 Xiaomi Redmi Note 7 Screen Replacement, Remove the connector cover: шаг 9, изображение 2 из 2
      Инструмент, используемый на этом этапе:
      • Use a pair of tweezers to remove the connector cover.
      Спросите у FixBot
    3. Xiaomi Redmi Note 7 Screen Replacement, Disconnect the battery: шаг 10, изображение 1 из 2 Xiaomi Redmi Note 7 Screen Replacement, Disconnect the battery: шаг 10, изображение 2 из 2
      • Use the flat end of a spudger to pry up and disconnect the battery flex cable from the motherboard.
      Спросите у FixBot
    1. Xiaomi Redmi Note 7 Screen Replacement, Peel the protective foil off: шаг 11, изображение 1 из 2 Xiaomi Redmi Note 7 Screen Replacement, Peel the protective foil off: шаг 11, изображение 2 из 2
      • For easier handling during repairs we highly recommend to separate the back cover including the fingerprint sensor from the phone assembly.
      • Use a pair of tweezers to carefully peel the yellow protective foil off the ZIF connector.
      Спросите у FixBot
    2. Xiaomi Redmi Note 7 Screen Replacement, Open the ZIF connector: шаг 12, изображение 1 из 2 Xiaomi Redmi Note 7 Screen Replacement, Open the ZIF connector: шаг 12, изображение 2 из 2
      • Use the pointed end of a spudger to open the ZIF connector by bringing its black flap in an upright position.
      Спросите у FixBot
    3. Xiaomi Redmi Note 7 Screen Replacement, Disconnect the fingerprint flex cable: шаг 13, изображение 1 из 2 Xiaomi Redmi Note 7 Screen Replacement, Disconnect the fingerprint flex cable: шаг 13, изображение 2 из 2
      • Disconnect the fingerprint flex cable by pulling it straight out off the ZIF connector using a pair of tweezers.
      Спросите у FixBot
    1. Xiaomi Redmi Note 7 Screen Replacement, Unfasten the screws: шаг 14, изображение 1 из 1
      • Use a Phillips screw driver to remove the eight 3.3 mm-long screws securing the loudspeaker assembly.
      Спросите у FixBot
    2. Xiaomi Redmi Note 7 Screen Replacement, Remove the loudspeaker assembly: шаг 15, изображение 1 из 3 Xiaomi Redmi Note 7 Screen Replacement, Remove the loudspeaker assembly: шаг 15, изображение 2 из 3 Xiaomi Redmi Note 7 Screen Replacement, Remove the loudspeaker assembly: шаг 15, изображение 3 из 3
      • Slide an opening pick underneath the right edge of the loudspeaker assembly.
      • Use the opening pick to pry up the loudspeaker assembly.
      • Remove the loudspeaker assembly.
      Спросите у FixBot
    1. Xiaomi Redmi Note 7 Screen Replacement, Unfasten the display connector cover screw: шаг 16, изображение 1 из 1
      • Use a Phillips screw driver to remove the 3.3 mm-long screw securing the display connector cover to the midframe.
      Спросите у FixBot
    2. Xiaomi Redmi Note 7 Screen Replacement, Remove the display connector cover: шаг 17, изображение 1 из 2 Xiaomi Redmi Note 7 Screen Replacement, Remove the display connector cover: шаг 17, изображение 2 из 2
      • Use a pair of tweezers to remove the display connector cover.
      Спросите у FixBot
    3. Xiaomi Redmi Note 7 Screen Replacement, Disconnect the display flex cable: шаг 18, изображение 1 из 2 Xiaomi Redmi Note 7 Screen Replacement, Disconnect the display flex cable: шаг 18, изображение 2 из 2
      • Use the flat end of a spudger to pry up and disconnect the display flex cable.
      Спросите у FixBot
    4. Xiaomi Redmi Note 7 Screen Replacement, Loosen the display adhesive: шаг 19, изображение 1 из 2 Xiaomi Redmi Note 7 Screen Replacement, Loosen the display adhesive: шаг 19, изображение 2 из 2
      • Apply a heated iOpener or a heat gun to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
      Спросите у FixBot
    5. Xiaomi Redmi Note 7 Screen Replacement, Insert an iFlex: шаг 20, изображение 1 из 2 Xiaomi Redmi Note 7 Screen Replacement, Insert an iFlex: шаг 20, изображение 2 из 2
      • Once the screen is warm to touch, apply a suction cup to the bottom edge of the phone.
      • Lift the screen with the suction handle to create a small gap between the screen and the frame.
      • Insert the tip of an iFlex in the gap between the midframe and the screen.
      Спросите у FixBot
    6. Xiaomi Redmi Note 7 Screen Replacement, Insert an opening pick: шаг 21, изображение 1 из 3 Xiaomi Redmi Note 7 Screen Replacement, Insert an opening pick: шаг 21, изображение 2 из 3 Xiaomi Redmi Note 7 Screen Replacement, Insert an opening pick: шаг 21, изображение 3 из 3
      • Insert the tip of an opening pick in the gap between the midframe and the screen, next to the iFlex.
      • Remove the iFlex.
      • Slide the opening pick to the bottom right corner to cut the adhesive. Leave it in its place to prevent the adhesive from resealing.
      Спросите у FixBot
    7. Xiaomi Redmi Note 7 Screen Replacement, Cut the adhesive: шаг 22, изображение 1 из 2 Xiaomi Redmi Note 7 Screen Replacement, Cut the adhesive: шаг 22, изображение 2 из 2
      • Insert a second opening pick and slide it to the bottom left corner of the screen to cut the adhesive.
      Спросите у FixBot
    8. Xiaomi Redmi Note 7 Screen Replacement, Cut the lefthand-side adhesive: шаг 23, изображение 1 из 3 Xiaomi Redmi Note 7 Screen Replacement, Cut the lefthand-side adhesive: шаг 23, изображение 2 из 3 Xiaomi Redmi Note 7 Screen Replacement, Cut the lefthand-side adhesive: шаг 23, изображение 3 из 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun to reheat it.
      • Insert a third opening pick under the bottom left corner of the phone.
      • Slide the opening pick up to the top left corner to cut the adhesive. Leave it in to prevent the adhesive from resealing.
      Спросите у FixBot
    9. Xiaomi Redmi Note 7 Screen Replacement, Cut the top edge adhesive: шаг 24, изображение 1 из 2 Xiaomi Redmi Note 7 Screen Replacement, Cut the top edge adhesive: шаг 24, изображение 2 из 2
      • Insert a fourth opening pick at the top left corner.
      • Slide the opening pick along the top edge of the phone to cut the adhesive. Leave the opening pick in the top right corner of the screen to prevent the adhesive from resealing.
      • When you slice near the front facing camera, insert only the tip of the opening pick to avoid damaging or smearing the camera.
      Спросите у FixBot
    10. Xiaomi Redmi Note 7 Screen Replacement, Cut the righthand-side adhesive: шаг 25, изображение 1 из 2 Xiaomi Redmi Note 7 Screen Replacement, Cut the righthand-side adhesive: шаг 25, изображение 2 из 2
      • Insert a fifth opening pick and slide it along the right edge of the phone to cut the remaining adhesive.
      • Do not try to remove the display all the way yet, the display cable is still threaded through the frame and possibly adhered on the inner side of the midframe.
      Спросите у FixBot
    11. Xiaomi Redmi Note 7 Screen Replacement, Remove the screen: шаг 26, изображение 1 из 3 Xiaomi Redmi Note 7 Screen Replacement, Remove the screen: шаг 26, изображение 2 из 3 Xiaomi Redmi Note 7 Screen Replacement, Remove the screen: шаг 26, изображение 3 из 3
      • Thread the display flex cable through the gap in the midframe and remove the screen.
      • The upper speaker grill of the Redmi Note 7 is likely to fall off during this procedure. Avoid loosing it during the screen removal.
      Спросите у FixBot
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
15 человек успешно провели ремонт по этому руководству.
Dominik Schnabelrauch
Участник с: 11/23/16
262 140 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 37 992 руководств
3 Комментарии к руководству
This guide is just WRONG and useless.
He disconnect the battery cable and nothing else: if you try this, at step 18 you will just pull a flex cable that is still screwed. The correct ribbon is not the one near the battery connector shown in step 10, but the one on the left under the camera.
Guide shows he removes 3 screews, and these are just to disconnect the battery. After this, it is necessary to remove more screws and actually disconnect the display flex: 1 to free the small metal cover blocking the ribbon (similar to step 9) and 8 more screws on the bottom of the phone to free and remove the loudspeaker, which otherwise will block the display ribbon even if it was disconnected and the first screw I mentioned removed.
A M - Ответить Поделиться
Hi A M,
thank you for your feedback. You're completely right. Some prereq guides for the screen guide were set to private and because of that not visible. I made them public and the full display removal procedure should be correct now. If you notice anything else that is wrong or I missed something, please let me know.
Dominik Schnabelrauch - Ответить Поделиться
شكراً جزيلا
Moawia Boutara - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 9
За последние 7 дней: 57
За последние 30 дней: 244
За всё время: 23,100
