iPhone 11 Screen Replacement
Выберете то, что вам нужно
  1. iPhone 11 Screen Replacement, Remove the pentalobe screws: шаг 1, изображение 1 из 2 iPhone 11 Screen Replacement, Remove the pentalobe screws: шаг 1, изображение 2 из 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Спросите у FixBot
    Добавить комментарий
  2. iPhone 11 Screen Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 11 Screen Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 11 Screen Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Спросите у FixBot
  3. iPhone 11 Screen Replacement, Tape over any cracks: шаг 3, изображение 1 из 3 iPhone 11 Screen Replacement, Tape over any cracks: шаг 3, изображение 2 из 3 iPhone 11 Screen Replacement, Tape over any cracks: шаг 3, изображение 3 из 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
    Спросите у FixBot
  4. iPhone 11 Screen Replacement, Anti-Clamp instructions: шаг 4, изображение 1 из 3 iPhone 11 Screen Replacement, Anti-Clamp instructions: шаг 4, изображение 2 из 3 iPhone 11 Screen Replacement, Anti-Clamp instructions: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the top, and one on the bottom.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Спросите у FixBot
  5. iPhone 11 Screen Replacement: шаг 5, изображение 1 из 3 iPhone 11 Screen Replacement: шаг 5, изображение 2 из 3 iPhone 11 Screen Replacement: шаг 5, изображение 3 из 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Спросите у FixBot
  6. iPhone 11 Screen Replacement: шаг 6, изображение 1 из 3 iPhone 11 Screen Replacement: шаг 6, изображение 2 из 3 iPhone 11 Screen Replacement: шаг 6, изображение 3 из 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Спросите у FixBot
  7. iPhone 11 Screen Replacement, Heat the lower edge of the phone: шаг 7, изображение 1 из 1
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute.
    Спросите у FixBot
  8. iPhone 11 Screen Replacement: шаг 8, изображение 1 из 2 iPhone 11 Screen Replacement: шаг 8, изображение 2 из 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
    Спросите у FixBot
  9. iPhone 11 Screen Replacement, Lift the display slightly: шаг 9, изображение 1 из 3 iPhone 11 Screen Replacement, Lift the display slightly: шаг 9, изображение 2 из 3 iPhone 11 Screen Replacement, Lift the display slightly: шаг 9, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap under the screen and the plastic bezelnot the screen itself.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Спросите у FixBot
  10. iPhone 11 Screen Replacement, Separate the screen adhesive: шаг 10, изображение 1 из 3 iPhone 11 Screen Replacement, Separate the screen adhesive: шаг 10, изображение 2 из 3 iPhone 11 Screen Replacement, Separate the screen adhesive: шаг 10, изображение 3 из 3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    Спросите у FixBot
  11. iPhone 11 Screen Replacement, Screen information: шаг 11, изображение 1 из 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    Спросите у FixBot
  12. iPhone 11 Screen Replacement: шаг 12, изображение 1 из 3 iPhone 11 Screen Replacement: шаг 12, изображение 2 из 3 iPhone 11 Screen Replacement: шаг 12, изображение 3 из 3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    Спросите у FixBot
  13. iPhone 11 Screen Replacement: шаг 13, изображение 1 из 3 iPhone 11 Screen Replacement: шаг 13, изображение 2 из 3 iPhone 11 Screen Replacement: шаг 13, изображение 3 из 3
    • The top edge of the display is secured with both glue and clips.
    • Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
    • Insert your pick into the top-right corner of the phone.
    Спросите у FixBot
  14. iPhone 11 Screen Replacement: шаг 14, изображение 1 из 2 iPhone 11 Screen Replacement: шаг 14, изображение 2 из 2
    • Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
    • Slide the pick to the top left corner and cut any remaining adhesive securing the display.
    • Don't insert your pick more than 3 mm, as you may damage the Face ID sensor array.
    Спросите у FixBot
  15. iPhone 11 Screen Replacement, Remove the suction cup: шаг 15, изображение 1 из 1
    • Pull the small nub on the suction cup to detach it from the front panel.
    Спросите у FixBot
  16. iPhone 11 Screen Replacement, Open the iPhone: шаг 16, изображение 1 из 3 iPhone 11 Screen Replacement, Open the iPhone: шаг 16, изображение 2 из 3 iPhone 11 Screen Replacement, Open the iPhone: шаг 16, изображение 3 из 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Prop the display up against something sturdy.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    Спросите у FixBot
  17. iPhone 11 Screen Replacement, Display Assembly: шаг 17, изображение 1 из 2 iPhone 11 Screen Replacement, Display Assembly: шаг 17, изображение 2 из 2
    • To access the screws in the following step, tilt the display by slightly lifting its lower edge.
    • Be careful not to strain or tear the display cables.
    Спросите у FixBot
  18. iPhone 11 Screen Replacement, Unscrew the battery connector cover: шаг 18, изображение 1 из 2 iPhone 11 Screen Replacement, Unscrew the battery connector cover: шаг 18, изображение 2 из 2
    Magnetic Project Mat
    $19.95
    • Use a Y000 driver to remove the three 1.1 mm-long screws securing the battery connector bracket.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    Спросите у FixBot
  19. iPhone 11 Screen Replacement, Remove the battery connector cover: шаг 19, изображение 1 из 1
    • Remove the bracket.
    Спросите у FixBot
  20. iPhone 11 Screen Replacement, Disconnect the battery: шаг 20, изображение 1 из 2 iPhone 11 Screen Replacement, Disconnect the battery: шаг 20, изображение 2 из 2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally contacting the socket.
    Спросите у FixBot
  21. iPhone 11 Screen Replacement, Unscrew the logic board cover screws: шаг 21, изображение 1 из 2 iPhone 11 Screen Replacement, Unscrew the logic board cover screws: шаг 21, изображение 2 из 2
    • Use a Y000 driver to remove the five 1.1 mm screws securing the logic board cover bracket.
    Спросите у FixBot
  22. iPhone 11 Screen Replacement, Remove the logic board cover bracket: шаг 22, изображение 1 из 1
    Спросите у FixBot
  23. iPhone 11 Screen Replacement, Disconnect the display: шаг 23, изображение 1 из 3 iPhone 11 Screen Replacement, Disconnect the display: шаг 23, изображение 2 из 3 iPhone 11 Screen Replacement, Disconnect the display: шаг 23, изображение 3 из 3
    • Use a spudger or a fingernail to disconnect the LCD panel cable connector.
    • Disconnect the digitizer connector next to it.
    Спросите у FixBot
  24. iPhone 11 Screen Replacement, Disconnect the front sensors: шаг 24, изображение 1 из 2 iPhone 11 Screen Replacement, Disconnect the front sensors: шаг 24, изображение 2 из 2
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
    Спросите у FixBot
  25. iPhone 11 Screen Replacement, Remove the display assembly: шаг 25, изображение 1 из 1
    Спросите у FixBot
  26. iPhone 11 Screen Replacement, Unscrew the front assembly: шаг 26, изображение 1 из 1
    • Remove four screws securing the speaker/sensor assembly:
    • Three 1.6 mm Phillips screws
    • One 1.3 mm Y000 screw
    Спросите у FixBot
  27. iPhone 11 Screen Replacement, Flip the speaker assembly over: шаг 27, изображение 1 из 3 iPhone 11 Screen Replacement, Flip the speaker assembly over: шаг 27, изображение 2 из 3 iPhone 11 Screen Replacement, Flip the speaker assembly over: шаг 27, изображение 3 из 3
    • Use the point of a spudger to gently pry up the top edge of the speaker.
    • Flip the speaker assembly over—down and away from the top edge of the display.
    • The speaker remains attached via very thin ribbon cables. Be careful not to strain or damage the cables.
    Спросите у FixBot
  28. iPhone 11 Screen Replacement, Heat up the top edge of the display: шаг 28, изображение 1 из 1
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the top front of the display for 1-2 minutes, in order to soften the adhesive securing the sensors.
    Спросите у FixBot
  29. iPhone 11 Screen Replacement, Pry up the microphone: шаг 29, изображение 1 из 3 iPhone 11 Screen Replacement, Pry up the microphone: шаг 29, изображение 2 из 3 iPhone 11 Screen Replacement, Pry up the microphone: шаг 29, изображение 3 из 3
    • Carefully slide the edge of your opening pick underneath the flex cable below the microphone.
    • Twist gently to separate the microphone, while being careful not to strain or damage the flex cable.
    • If needed, use the point of the spudger to finish separating the microphone from its notch in the front panel.
    Спросите у FixBot
  30. iPhone 11 Screen Replacement, Remove the ambient light sensor bracket: шаг 30, изображение 1 из 2 iPhone 11 Screen Replacement, Remove the ambient light sensor bracket: шаг 30, изображение 2 из 2
    • Use tweezers to slide the small bracket straight up and off of the ambient light sensor.
    Спросите у FixBot
  31. iPhone 11 Screen Replacement, Loosen the ambient light sensor: шаг 31, изображение 1 из 2 iPhone 11 Screen Replacement, Loosen the ambient light sensor: шаг 31, изображение 2 из 2
    • Use tweezers to wiggle the ambient light sensor and lift it from its notch in the display.
    • If the sensor does not wiggle free after a few seconds, apply more heat and try again.
    • The sensor remains attached to the rest of the sensor assembly via a very thin flex cable. Be careful not to strain or damage the cable.
    Спросите у FixBot
  32. iPhone 11 Screen Replacement: шаг 32, изображение 1 из 3 iPhone 11 Screen Replacement: шаг 32, изображение 2 из 3 iPhone 11 Screen Replacement: шаг 32, изображение 3 из 3
    • Working left to right, slide an opening pick beneath the flex cable and underneath the proximity sensor + flood illuminator module.
    • Gently wiggle and lift to separate the module from its notch in the front panel.
    • It's helpful to lift and hold the speaker out of the way for access. Just be careful not to pull on the thin flex cable while you work.
    Спросите у FixBot
  33. iPhone 11 Screen Replacement, Remove the speaker + front sensors: шаг 33, изображение 1 из 3 iPhone 11 Screen Replacement, Remove the speaker + front sensors: шаг 33, изображение 2 из 3 iPhone 11 Screen Replacement, Remove the speaker + front sensors: шаг 33, изображение 3 из 3
    • Remove the earpiece speaker and front sensor assembly.
    • During reassembly, check the position of the black plastic module containing these components:
    • Proximity sensor
    • Flood illuminator
    • The module must be positioned so that these components are not obstructed by any adhesive.
    Спросите у FixBot
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or search our iPhone 11 Answers community for help.
228 человек успешно провели ремонт по этому руководству.
Arthur Shi
Участник с: 01/03/18
344 054 Репутация
Автор 915 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 31 531 руководств
19 Комментарии к руководству
Zu Schritt 13:
Was kann ich tun wenn die Metallplatte sich nicht aus dem Gehäuse löst?
Jakob Hahn - Ответить Поделиться
Versuchen Sie, das Telefon beim zweiten Mal dort erneut aufzuwärmen, wo es in der Anleitung angegeben ist. Vielleicht versuchen Sie auch, Ihren iOpener für längere Zeit in der Mikrowelle zu erhitzen/zu erhitzen. Wenn das nicht funktioniert, überprüfen Sie, ob keine weiteren Schrauben entfernt werden müssen. Und das Letzte, was Sie versuchen könnten, wäre, ein paar andere Hebelwerkzeuge zu verwenden und/oder zu versuchen, es in einer anderen Richtung aus dem Gehäuse zu bekommen.
Platinumgaming57 “Solar_Flare” - Ответить Поделиться
During reassembly, is there a step in which I need to apply adhesive? (asking since you find adhesive as you disassemble)
Athanasius Pernath - Ответить Поделиться
Most often you will re-apply the adhesive to the new LCD assembly itself. Note that the part you will need is designed to provide waterproofing to the device. If you put the adhesive + waterproof seal onto the new LCD incorrectly then the device will not be waterproof. Note: I'm no qualified professional, and I'm only a 9th grader but I have lots of experience with this particular repair and I have almost mastered it.( I have fixed maybe 7 or 8 iPhone 11s alone) And in my experience, applying the new adhesive + seal to the new LCD assembly has always worked out great and resulted in a happy customer and good feedback.
I had the same problem, I had ordered a display plus adhesive here at iFixit shop, but there were no instruction how to attach it. I looked at manuals of other adhesives and found a proper way, that worked for me: Before reattaching the display cables I attached the adhesive on the phone, not on the display. At first you have to remove all old adhesive properly, if you have isopropanol you can use it to clean the frame. Then you remove the protective sheet (the side with the tab) from the new adhersive, place it carefully on the phone and press it with a spudger all around the frame. The protective sheet on this side is made of different parts so you can remove them on parts where you have to work on. Then you can attach the display cables and the battery cable and test if it works. If all works fine you can remove the last protective sheets and go on to attach the whole display unit.
SiRo - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 201
За последние 7 дней: 1,386
За последние 30 дней: 6,590
За всё время: 385,756
