Инструмент, используемый на этом этапе:Tesa 61395 Tape$2.99
Without letting the ambient light sensor adhesive touch the screen, use a pair of tweezers to hold the sensor above the back of the new screen.
Align the ambient light sensor with its recess in the back of the screen.
Use a spudger or your finger to press the ambient light sensor into its recess.
Lay the ambient light sensor cable down on the back of the screen.
Use your finger to press down the ambient light sensor cable.
Use tweezers or your fingers to place the ambient light sensor bracket over the back of the sensor.
Use a Phillips screwdriver to install the 1.3 mm‑long screw securing the ambient light sensor bracket.
Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
Use a pair of tweezers to remove the adhesive around the entire perimeter of the phone.
Wrap a microfiber or lint-free cloth around the pointed end of a spudger and apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to the cloth.
Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to make sure the adhesive is oriented correctly.
Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but do not remove the liner all the way.
While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
When the adhesive is aligned, use your finger to press it down firmly along the bottom edge.
Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
Make sure the liner is aligned properly by checking that all spring contacts and the front-facing camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
Use the flat end of a spudger to press the adhesive firmly into place all around the iPhone.
Use the point of a spudger to lift the pull tab in the top‑right corner of the frame until you can grab it with your fingers.
Peel back the top liner and remove it.
Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. If the adhesive is clean and properly aligned, you may proceed, just be careful not to touch anything to the exposed adhesive until you are ready to install the screen.
Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
Use the flat end of a spudger or your finger to connect the screen and front sensor press connectors.
Use a pair of tweezers or your fingers to place the screen connector cover over the screen connector by inserting it at a slight downward angle to engage the hook, then laying the cover flat over the connector.
Use a pair of tweezers or your fingers to place the front sensor connector cover over the front sensor connector by inserting it at a 90‑degree angle to engage the hook, then laying the cover flat over the connector.
Use a tri-point Y000 driver to install the two 0.9 mm‑long screws securing the front sensor connector and screen connector covers.
Use a pair of tweezers or your fingers to remove the two narrow liners covering the adhesive along the right, top, and bottom edges of the iPhone.
Without letting the screen touch the adhesive, hold the screen over the phone so you can access the final liner along the left edge of the phone.
Use a pair of tweezers or your fingers to remove the final liner along the left edge of the phone.
Firmly press the top edge of the screen into the adhesive, then the bottom edge, until the screen is fully seated in the frame.
To help the adhesive bond, apply heat to the edges of the screen using an iOpener, hair dryer, or heat gun until it's hot to the touch.
Firmly press around the perimeter of the screen.
If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the screen.
If you have the box your iPhone came in, take the lid and place it on a flat surface.
Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
Place the iPhone screen-side-down on a soft, flat surface.
Apply tape to the back glass to protect its finish.
Place two layers of coins or similarly thick objects on the tape along the edges of the back glass.
Evenly distribute the coins and make sure they are at least as thick as the camera bump.
Stack multiple books or other heavy objects on your iPhone.
Финишная прямая
