iPhone 8 LCD and Digitizer Replacement
Выберете то, что вам нужно
    1. iPhone 8 LCD and Digitizer Replacement, Remove the pentalobe screws: шаг 1, изображение 1 из 1
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.5 mm pentalobe screws on the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Спросите у FixBot
      Добавить комментарий
    1. iPhone 8 LCD and Digitizer Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 8 LCD and Digitizer Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 8 LCD and Digitizer Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Спросите у FixBot
    1. iPhone 8 LCD and Digitizer Replacement, Tape over the display: шаг 3, изображение 1 из 3 iPhone 8 LCD and Digitizer Replacement, Tape over the display: шаг 3, изображение 2 из 3 iPhone 8 LCD and Digitizer Replacement, Tape over the display: шаг 3, изображение 3 из 3
      • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
      Спросите у FixBot
    1. iPhone 8 LCD and Digitizer Replacement, Anti-Clamp instructions: шаг 4, изображение 1 из 3 iPhone 8 LCD and Digitizer Replacement, Anti-Clamp instructions: шаг 4, изображение 2 из 3 iPhone 8 LCD and Digitizer Replacement, Anti-Clamp instructions: шаг 4, изображение 3 из 3
      Инструмент, используемый на этом этапе:
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Спросите у FixBot
    2. iPhone 8 LCD and Digitizer Replacement: шаг 5, изображение 1 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 5, изображение 2 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 5, изображение 3 из 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Спросите у FixBot
    3. iPhone 8 LCD and Digitizer Replacement: шаг 6, изображение 1 из 2 iPhone 8 LCD and Digitizer Replacement: шаг 6, изображение 2 из 2
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick into the gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Спросите у FixBot
    4. iPhone 8 LCD and Digitizer Replacement, Heat the display: шаг 7, изображение 1 из 1
      • The next three steps show how to separate the screen using a suction cup.
      • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
      • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
      Спросите у FixBot
    5. iPhone 8 LCD and Digitizer Replacement, Separate the display: шаг 8, изображение 1 из 2 iPhone 8 LCD and Digitizer Replacement, Separate the display: шаг 8, изображение 2 из 2
      • Apply a suction cup to the lower half of the front panel, just above the home button.
      • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
      Спросите у FixBot
    6. iPhone 8 LCD and Digitizer Replacement: шаг 9, изображение 1 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 9, изображение 2 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 9, изображение 3 из 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
      • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Спросите у FixBot
    7. iPhone 8 LCD and Digitizer Replacement: шаг 10, изображение 1 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 10, изображение 2 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 10, изображение 3 из 3
      • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
      • Stop near the top left corner of the display.
      • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
      Спросите у FixBot
    8. iPhone 8 LCD and Digitizer Replacement, Screen information: шаг 11, изображение 1 из 1
      • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
      Спросите у FixBot
    9. iPhone 8 LCD and Digitizer Replacement: шаг 12, изображение 1 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 12, изображение 2 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 12, изображение 3 из 3
      • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Спросите у FixBot
    10. iPhone 8 LCD and Digitizer Replacement: шаг 13, изображение 1 из 2 iPhone 8 LCD and Digitizer Replacement: шаг 13, изображение 2 из 2
      • Gently pull up on the suction cup to lift up the bottom edge of the display.
      • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Спросите у FixBot
    11. iPhone 8 LCD and Digitizer Replacement: шаг 14, изображение 1 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 14, изображение 2 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 14, изображение 3 из 3
      • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
      Спросите у FixBot
    12. iPhone 8 LCD and Digitizer Replacement: шаг 15, изображение 1 из 2 iPhone 8 LCD and Digitizer Replacement: шаг 15, изображение 2 из 2
      • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
      Спросите у FixBot
    13. iPhone 8 LCD and Digitizer Replacement: шаг 16, изображение 1 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 16, изображение 2 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 16, изображение 3 из 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      Спросите у FixBot
    1. iPhone 8 LCD and Digitizer Replacement, Disconnect the battery: шаг 17, изображение 1 из 2 iPhone 8 LCD and Digitizer Replacement, Disconnect the battery: шаг 17, изображение 2 из 2
      Magnetic Project Mat
      $19.95
      • Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths:
      • Two 1.3 mm screws
      • Two 2.8 mm screws
      • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
      • Remove the bracket.
      Спросите у FixBot
    2. iPhone 8 LCD and Digitizer Replacement: шаг 18, изображение 1 из 2 iPhone 8 LCD and Digitizer Replacement: шаг 18, изображение 2 из 2
      • Use the point of a spudger to pry the battery connector out of its socket in the logic board.
      • Don't pry against the logic board, or you may damage the charging circuitry.
      • Bend the battery connector cable slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Спросите у FixBot
    1. iPhone 8 LCD and Digitizer Replacement, Disconnect the display and digitizer: шаг 19, изображение 1 из 2 iPhone 8 LCD and Digitizer Replacement, Disconnect the display and digitizer: шаг 19, изображение 2 из 2
      • Use the point of a spudger to pry the lower display connector out of its socket.
      • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
      Спросите у FixBot
    2. iPhone 8 LCD and Digitizer Replacement: шаг 20, изображение 1 из 2 iPhone 8 LCD and Digitizer Replacement: шаг 20, изображение 2 из 2
      • Use the point of a spudger to disconnect the second lower display cable.
      Спросите у FixBot
    3. iPhone 8 LCD and Digitizer Replacement: шаг 21, изображение 1 из 2 iPhone 8 LCD and Digitizer Replacement: шаг 21, изображение 2 из 2
      • Remove the three 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
      Спросите у FixBot
    4. iPhone 8 LCD and Digitizer Replacement: шаг 22, изображение 1 из 2 iPhone 8 LCD and Digitizer Replacement: шаг 22, изображение 2 из 2
      • Use the point of a spudger to disconnect the front panel sensor assembly connector.
      Спросите у FixBot
    5. iPhone 8 LCD and Digitizer Replacement, Remove the display assembly: шаг 23, изображение 1 из 1
      Спросите у FixBot
    1. iPhone 8 LCD and Digitizer Replacement, Remove the home/Touch ID sensor bracket: шаг 24, изображение 1 из 2 iPhone 8 LCD and Digitizer Replacement, Remove the home/Touch ID sensor bracket: шаг 24, изображение 2 из 2
      • Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
      • One 1.2 mm screw
      • Remove this screw first. Excess pressure may bend the home button bracket if you remove the 1.3mm screws first.
      • Three 1.3 mm screws
      • During reassembly, be careful not to overtighten these screws, or your home button may not work.
      Спросите у FixBot
    2. iPhone 8 LCD and Digitizer Replacement, Disconnect the Touch ID sensor: шаг 25, изображение 1 из 3 iPhone 8 LCD and Digitizer Replacement, Disconnect the Touch ID sensor: шаг 25, изображение 2 из 3 iPhone 8 LCD and Digitizer Replacement, Disconnect the Touch ID sensor: шаг 25, изображение 3 из 3
      • Use an opening tool to pry under the left edge of the home button cable connector to disconnect it from its socket.
      • If the entire connector begins to flip up without separating, press down on the cable at the top edge of the connector with the flat end of your spudger, while simultaneously prying up the left edge of the connector. Be very careful not to damage the cable or connector, or you will permanently disable the sensor.
      Спросите у FixBot
    3. iPhone 8 LCD and Digitizer Replacement, Remove the Touch ID sensor: шаг 26, изображение 1 из 1
      • Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
      • Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
      • Don't overheat the display. It should be slightly too hot to touch comfortably.
      Спросите у FixBot
    4. iPhone 8 LCD and Digitizer Replacement: шаг 27, изображение 1 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 27, изображение 2 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 27, изображение 3 из 3
      • Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
      Спросите у FixBot
    5. iPhone 8 LCD and Digitizer Replacement: шаг 28, изображение 1 из 1
      • Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
      • To reinstall, first feed the cable through the hole in the front of the display as shown.
      • Your replacement part may come with extra Y000 screws already installed near the Home Button. Remove the unnecessary screws so that you can reinstall the home button bracket.
      Спросите у FixBot
    1. iPhone 8 LCD and Digitizer Replacement, Remove the earpiece bracket: шаг 29, изображение 1 из 1
      • Remove the three Phillips screws securing the top earpiece bracket to the front panel:
      • Two 2.6 mm screws
      • One 1.8 mm screw
      Спросите у FixBot
    2. iPhone 8 LCD and Digitizer Replacement: шаг 30, изображение 1 из 1
      • Remove the earpiece speaker bracket.
      Спросите у FixBot
    3. iPhone 8 LCD and Digitizer Replacement, Move the front-facing camera: шаг 31, изображение 1 из 2 iPhone 8 LCD and Digitizer Replacement, Move the front-facing camera: шаг 31, изображение 2 из 2
      • Lift the front facing camera up out of its socket and swing it out of the way.
      Спросите у FixBot
    4. iPhone 8 LCD and Digitizer Replacement, Remove the earpiece speaker: шаг 32, изображение 1 из 1
      • Remove the two Phillips screws securing the earpiece speaker to the front panel:
      • One 1.8 mm screw
      • One 2.3 mm screw
      Спросите у FixBot
    5. iPhone 8 LCD and Digitizer Replacement: шаг 33, изображение 1 из 1
      • Remove the earpiece speaker.
      Спросите у FixBot
    1. iPhone 8 LCD and Digitizer Replacement, Remove the front camera and sensor cable: шаг 34, изображение 1 из 1
      • Heat an iOpener and apply it to the upper edge of the display to soften the adhesive holding the front camera and sensor assembly in place.
      • Wait about two minutes before moving on to the next step to adequately soften the adhesive.
      Спросите у FixBot
    2. iPhone 8 LCD and Digitizer Replacement: шаг 35, изображение 1 из 2 iPhone 8 LCD and Digitizer Replacement: шаг 35, изображение 2 из 2
      • Use the point of a spudger to gently pry the proximity sensor out of its recess on the front panel.
      • Try to get your tool all the way under the sensor to pry it away from the clear plastic beneath. If you pry only against the cable, the sensor may separate from the cable assembly and will need replacement. If you're replacing the sensor/cable assembly anyway, then it doesn't matter.
      Спросите у FixBot
    3. iPhone 8 LCD and Digitizer Replacement: шаг 36, изображение 1 из 2 iPhone 8 LCD and Digitizer Replacement: шаг 36, изображение 2 из 2
      • Slide the tip of a spudger underneath the ambient light sensor flex cable, and lift the sensor out of its housing.
      Спросите у FixBot
    4. iPhone 8 LCD and Digitizer Replacement: шаг 37, изображение 1 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 37, изображение 2 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 37, изображение 3 из 3
      • Slide an opening pick underneath front camera cable assembly, separating the adhesive holding the camera and sensor cable.
      Спросите у FixBot
    5. iPhone 8 LCD and Digitizer Replacement: шаг 38, изображение 1 из 1
      • Remove the front camera and sensor cable.
      Спросите у FixBot
    1. iPhone 8 LCD and Digitizer Replacement, Separate the LCD and digitizer: шаг 39, изображение 1 из 2 iPhone 8 LCD and Digitizer Replacement, Separate the LCD and digitizer: шаг 39, изображение 2 из 2
      • Remove the six 1.2 mm Y000 screws from both sides of the display.
      Спросите у FixBot
    2. iPhone 8 LCD and Digitizer Replacement: шаг 40, изображение 1 из 1
      • Heat an iOpener and lay it over the edge of the shield closest to the home button to soften the adhesive holding it in place.
      Спросите у FixBot
    3. iPhone 8 LCD and Digitizer Replacement: шаг 41, изображение 1 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 41, изображение 2 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 41, изображение 3 из 3
      • Use an opening pick to break up the adhesive near the home button that holds the flat display cable to the LCD shield plate.
      Спросите у FixBot
    4. iPhone 8 LCD and Digitizer Replacement: шаг 42, изображение 1 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 42, изображение 2 из 3 iPhone 8 LCD and Digitizer Replacement: шаг 42, изображение 3 из 3
      • Insert an opening pick from the bottom right corner and continue to separate the display cable from the LCD shield plate.
      Спросите у FixBot
    5. iPhone 8 LCD and Digitizer Replacement: шаг 43, изображение 1 из 2 iPhone 8 LCD and Digitizer Replacement: шаг 43, изображение 2 из 2
      • Gently lift the LCD shield plate from the display assembly.
      • Be careful not to snag the display data cables when removing the LCD shield plate.
      Спросите у FixBot
    6. iPhone 8 LCD and Digitizer Replacement: шаг 44, изображение 1 из 1
      • Only the LCD and digitizer remain.
      Спросите у FixBot
Заключение
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our iPhone 8 Answers community for troubleshooting help.
87 человек успешно провели ремонт по этому руководству.
Arthur Shi
Участник с: 01/03/18
344 886 Репутация
Автор 915 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 48 000 руководств
21 Комментарии к руководству
So I’m pretty sure I know the answer to this - but can I test out the screen replacement without hooking up the camera, home button, etc? Can I just attach the three cables to the phone to make sure the screen works, or would it brick the phone?
Sarah Ybarra - Ответить Поделиться
Hi Sarah,
You can test the display without bricking your phone. It may boot-loop when the front sensor/camera assembly isn’t connected though. Be careful while you work with an opened phone with the battery connected…it is easy to accidentally short things out!
Arthur Shi - Ответить Поделиться
After replacing the iPhone 8 LCD Screen and Digitizer, it seems that the battery is draining faster. I just wanted to see if this is a normal problem or was there something I missed during the install process?
Jason Adams - Ответить Поделиться
My daughters phone was repaired and the same thing is happening to her
tiffinycook - Ответить Поделиться
Do you have to remove the plastic holder for the camera?
Diego Cisneros - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 13
За последние 7 дней: 97
За последние 30 дней: 431
За всё время: 127,453
