Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
The iPad team took a page from the iPhone SE playbook and released what appears to be a throwback—an arguably under-specced tablet that takes aim at the education and enterprise markets. This iPad is supposedly reasonably priced and powerful enough for professionals—but will it also earn high marks for repairability? Join us and find out. It's teardown time!
Want to be the first to see inside the latest gadgets? Follow us on Facebook, Instagram, or Twitter for the latest news from the repair world.
Update: For a full list of part compatibility between the iPad 5 and the iPad Air 1, refer to our compatibility testing blog post.
Выберете то, что вам нужно
Инструменты
Показать больше…
Видео обзор
Это разборка для изучения а не руководство по ремонту. Чтобы отремонтировать iPad 5 Wi-Fi, воспользуйтесь нашим сервисным руководством.
  1. iPad 5 Teardown, iPad 5 Teardown: шаг 1, изображение 1 из 2 iPad 5 Teardown, iPad 5 Teardown: шаг 1, изображение 2 из 2
    • Rumor has it this iPad's packing something old, and something new. Maybe these specs can tell us how far this Apple landed from the tree:
    • Apple 3rd-generation 64-bit A9 processor, with embedded M9 motion coprocessor
    • 9.7-inch multi-touch Retina display with 2048 x 1536 resolution (264 ppi) and non-laminated digitizer
    • 32 GB or 128 GB of storage
    • 8-megapixel 1080p rear-facing iSight camera + 1.2-megapixel 720p front-facing FaceTime HD camera
    • 802.11a/​b/​g/​n/​ac MIMO Wi-Fi + Bluetooth 4.2
    • Touch ID fingerprint sensor + 3-axis gyro + accelerometer + barometer + ambient light sensor
  2. iPad 5 Teardown: шаг 2, изображение 1 из 2 iPad 5 Teardown: шаг 2, изображение 2 из 2
    • We travel far and wide to get you the earliest teardown news possible—exotic timezones such as Australian Eastern Standard Time, and Japan Standard Time. And don't forget Pacific Standard Time, which in this case required six hours of driving... south...
    • Bottom line, our X-pert friends at Creative Electron in San Marcos hosted an iPad teardown for us, and did a little advance X-ray recon, too.
    • Yep. Looks like an original iPad Air in there.
    • It looks just like an iPad Air from the outside as well—but are looks deceiving?
    My Ipad 5 is a day-old when the screen shattered. I was resting my arm on it. Are the Ipad 5 screens so brittle and fragile? The screen display had no support or whatsoever on the adjacent part of the front camera.
    My Ipad5's casing is Urban Armor Gear.
    Will they replace it, or are there instances that they will replace ir for free?
    Paolo Suelto - Ответить
  3. iPad 5 Teardown: шаг 3, изображение 1 из 2 iPad 5 Teardown: шаг 3, изображение 2 из 2
    • Before getting started, we check the back just to make sure this isn't an old iPad masquerading around in a new box.
    • New Model number: A1822—check.
    • Stacked up against the Air 1, the 2017 model looks very similar. Key differences include:
    • The absence of a lock switch (if the Air 2 did it, you can too, iPad 5)
    • Microphone slots shrunk down to microphone holes (less chance of junk ingress?)
    • Single row of speaker holes (more holes = more luxury?)
    • And in case you're wondering, the headphone jack did survive.
  4. iPad 5 Teardown: шаг 4, изображение 1 из 3 iPad 5 Teardown: шаг 4, изображение 2 из 3 iPad 5 Teardown: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    iOpener
    $17.99
    • It's time to start the iPad opening song and dance: Heat, Pry, Peek, Repeat.
    • Based on early reports, we're expecting this device to be more Air 1 than 2—and this right here is why. The LCD and digitizer are unfused, and can be replaced separately. This is great news for repair.
    • Testing our newfound freedom, we take a second to swap in the digitizer and LCD from an Air 1. The connectors fit! We'll do some tests at a later date to let you know if they actually work...
    • We needle a Battery Isolation Pick betwixt the battery contacts and logic board to prevent any... mishaps, stopping those electrons in their tracks traces.
  5. iPad 5 Teardown: шаг 5, изображение 1 из 3 iPad 5 Teardown: шаг 5, изображение 2 из 3 iPad 5 Teardown: шаг 5, изображение 3 из 3
    • Flipping the digitizer on its back reveals the most significant change thus far from the lookalike iPad Air: the addition of Touch ID, and its associated hardware.
    • NXP 8461A1—also visible as a 5x4 ball grid array hiding under the speaker in this sweet X-ray image.
    • Probably a NXP Semiconductor NVT8461A1 (WLCSP20) secure microcontroller.
    • Thumbs up for fingerprint reading. Thumbs down for a harder repair, since the sensor is uniquely paired to its logic board at the factory.
    • At least this lovely button is still a button (unlike the solid-state un-button that debuted on 7-series iPhones). Peep that switch under the Lightning port traces.
    • Likely hall sensors
  6. iPad 5 Teardown: шаг 6, изображение 1 из 2 iPad 5 Teardown: шаг 6, изображение 2 из 2
    • Moving on to the display, we don't spy any convenient manufacturer marks this time around.
    • LG, are you okay?
    • Front and center on the display PCB, we find a Parade DP655—the same LCD timing controller found on the Air 1 display.
    • Texas Instruments TPS65143 display power supply
    • Rohm BR24T16-W 16 Kb serial EEPROM memory
    • In Apple's press release announcing the iPad 5, they told us it comes equipped with a "brighter 9.7-inch Retina display."
    • Our question is: brighter than what? It doesn't look that different from the Air 1's display. If they mean brighter than the Air 2, then that may simply be due to reverting to the unfused display design of the Air 1.
  7. iPad 5 Teardown: шаг 7, изображение 1 из 3 iPad 5 Teardown: шаг 7, изображение 2 из 3 iPad 5 Teardown: шаг 7, изображение 3 из 3
    • So remember how we said this was similar to the first Air? We were serious—take a look at the Air 1 and iPad 5 respectively. Not much has changed.
    • Here the Air 1 is dressed in Space Grey, and has a slightly larger Wi-Fi module.
    • The iPad 5 is in silver, and... has less tape? I mean, they're pretty identical.
    • Editor's note: It's actually all the same tape, just in neater lines. Sorry it went back on a little wrinkly after making guides on that Air 1—guides that'll also help you fix your new iPad 5.
    • They both pack the same 32.9 Wh battery, beating the 27.6 Wh iPad Air 2 and the 27.9 Wh iPad Pro 9.7" (all of which are outpaced by the Surface Pro 4's 38.2 Wh reservoir).
  8. iPad 5 Teardown: шаг 8, изображение 1 из 1
    • Time to scout out some silicon! The backside of this board is devoid of chips, so we'll save our glue-fighting powers for another day. Meanwhile, here's what's floating around topside:
    • Apple A9 APL0898 SoC + Samsung K3RG1G10BM-BGCH 2 GB LPDDR4 RAM (as seen in the iPhone 6s)
    • SK Hynix H23QEG8VG2ACR 32 GB NAND flash storage
    • 2x Broadcom BCM5976 touch controllers—as seen in iPhones 5, 5c, 5s, 6, 6 Plus, SE, as well as trackpads in MacBooks, MacBook Airs and Pros, and the last two generations of iPads
    • Apple 343S00144-A0 and 338S1213 power management and audio codec respectively
    • NXP 67V04 (PN67V) NFC Controller as seen in the iPhone 7 and Apple Watch Series 2
    • NXP Semiconductor CBTL610A38 USB charging IC, as seen in the iPhone 7
    • Apple/USI 339S0038 Wi-Fi module
    So what's the dac chip is it cirrus logic too
    Roice Tiamzon - Ответить
    NXP USB IC is actually part number 610A3B, not 610A38
    HandHeldRehab - Ответить
  9. iPad 5 Teardown: шаг 9, изображение 1 из 1
    • IC Identification, continued:
    • Texas Instruments TPS5662 backlight driver (likely)
    • Bosch Sensortec pressure sensor
    • Invensense accelerometer
  10. iPad 5 Teardown: шаг 10, изображение 1 из 2 iPad 5 Teardown: шаг 10, изображение 2 из 2
    • And that's a wrap!
    • We owe a huge shoutout to Creative Electron who hosted us and fed us pizza and caffeine.
    • And provided these sweet X-ray images.
    • And trusted us with their shiny new iPad...
    • Update: For a full list of part compatibility between the iPad 5 and the iPad Air 1, refer to our compatibility testing blog post.
  11. Заключительные мысли
    • The LCD is easy to remove once the front panel is separated from the iPad.
    • The battery is not soldered to the logic board. We'll give it that.
    • Just like in previous iPads, the front panel is glued to the rest of the device, greatly increasing the chances of cracking the glass during a repair.
    • Gobs of adhesive hold everything in place. As with its Air 1 predecessor, this ranks among the most difficult battery removal procedures we've seen in an iPad.
    • The LCD has foam sticky tape adhering it to the front panel, increasing chances of it being shattered during disassembly.
    • You can't access the front panel's connector until you remove the LCD.
    Уровень ремонтопригодности
    2
    Ремонтопригодность 2из 10
    (10 легче всего ремонтировать)
Evan Noronha
Участник с: 02/05/15
226 255 Репутация
Автор 168 руководств
39 Комментариев
Digitizer or LCD compatible between the two?
Ryan Galvan - Ответить
Digi and LCD compatible with the air 1?
jared - Ответить
Yes, same as iPad Air
HandHeldRehab -
Do all the controls and cutouts (volume buttons, power, microphone holes, speaker holes, etc.) align in the same locations as the iPad Air? I'm hoping to be able to use my old leather smart case (which is no longer manufactured) for this iPad if I decide to buy it.
Zorin the Lynx - Ответить
I'm going to guess that the Air 1 digi won't fit due to the touch ID button being bigger than the regular home button.
Brian - Ответить
It's same since I compare with the air 2 home bottom
リセイシン -
Does the Air 1 digitizers work on this one ?
letsmod - Ответить
I don't think so since he change from home button to TouchID, the size always are different...
Robert G -
The Good, you can transfer the TouchID to a new touchscreen, if you damage it.
Robert G -
The iPad 5 has 2GB of ram, like the Air 2. The Air has 1GB.
James Michnya -
How many gigabytes RAM?
Loran - Ответить
What wifi module is as always unknown.
Stiv Vert - Ответить
What about the cases for this new iPad 9.7? Do the cases for iPad Air 1 fit it? For people buying this thing it's a really useful question!!!
vitaferra - Ответить
Sorta. Not perfect but usable. I have a UAG folio style case and it works fine on both a 9.7 and an air 1
Curtis Jordan Lenox -
Most other sites citing iFixit's findings are misinterpreting them as implying that the new iPad is the same as the iPad Air, while ignoring the fact that it has the A9 chip instead of the A7, which is a huge difference.
iFixit's comments come from the point of view of disassembling and repairing the product, not from a performance or value perspective.
R Sriceso - Ответить
To my knowledge this iPad is replacing the iPad Air 2 which has an A8X, not A7.
Martin Bergstrom -
I don't understand, why it only achieved a 2/10. In my opinion, the device should be a 5 or 6.
I repaired dozens of iPad Air 1 an i never had the feel that i could damage anything while removing the front glass / digitizer. Of course, it will take some time and lots of patience, but if you are working clean and carefully, there is not much of a chance for damaged parts.
Also i doesn't care about a non destructive battery removal. If i'm in need do remove the battery, then because i'm about to replace it. It doesn't matter, if the old battery will be damaged in this process.
To be honest. The batteries lasts very long. I have an iPad 4 and an iPad Air 1 by myself from almost day one. They will be used on a daily basis and their batteries are still very fine. The same for my "customer's" iPads. Roughly 9 out of 10 iPad repairs i did, are screen or digitizer replacements, sometimes a camera or the Lightning port is broken, but i never had an iPad with a dead battery on my desk.
Michael Slomma - Ответить
Try working in education, you'll have lots of battery replacements on your desk. Kids use iPads for a class period then they all get put back on the chargers. These iPads are supposed to last 5 years but the battery is dead within one. Battery consumption is not covered under Apple's 1 year warranty and school districts cant afford Apple Care.
benjaminvikse - Ответить
This model's digitizer and LCD will work on the Air 1.. but not the other way around.
Matt M - Ответить
It was an awesome tear down! I have a question. The only reason I'm hesitating buying this is cuz it doesn't have the laminated screen can it be replaced with iPad air 2 screen?
Tony Moon - Ответить
Air 2 wouldn't work because of the fused glass and LCD together. vs them being independent in this model and the Air 1
Matt M -
Who makes the gyroscope here?
T.C. - Ответить
Guys, great post super helpful! Any idea who made the gyroscope in this one?
Jason Day - Ответить
Jason, we found some more info on the gyro, but we're not 100% on who makes it. Let me know now to reach you if you want to discuss.
T.C. -
Hi T.C. -- feel free to email me at jayday6564@gmail.com; we can set up a time to chat if you'd like.
It this iPad affected by the a9 chipgate as well? Samsung vs TSMC
Yongbin Guan - Ответить
I want to know if the LCD and digitizer are compatible for each other.My new ipad was filled with water and I would like to change it with the LCD of iPad Air 1.
luowenxing - Ответить
Can confirm the screen is brighter than the Air 1, if a touch warmer.
Sean Hearrell - Ответить
Touch ID is gen1 or gen2?
anonymous 1774 - Ответить
Is the dac cirrus logic if not I'm not buying that
Hello,
I just bought my Ipad 5 last week for my LLB course.
On the first day(night class) of my Ipad 5, the screen already retired.
I was listening to my professor intently with my Ipad on my left lap and my arm resting, and another instance was my Ipad 5 on top of the armchair and my resting on it. When the class finished, My Ipad screen adjacent to the front camera is already cracked/shattered extending to the home button.
Btw, my Ipad 5 is covered by Urbam Arm Gear casing (Ipad 5 edition). It passed the drop testing and all of their tests.
However, My Ipad 5 screen display broke when I was resting my arm on it which is comfortable and who doesn't rest their arm on an Ipad?
Is this covered by the warranty? I mean it wasn't accidental, I was doing my daily routine with no "accidental" damages.
The IPAD 5 is good, and I bought because it was cheaper and more practical for my course. With my Ipad retiring on its first day, I shouldve bought the Apple pro since the price of repairing is absurd.
Feeling all rightMe have bad, after all the advances in technology also in that hardware update
ms li - Ответить
Hi!
Could you please measure the thickness of the glass screen? I bought this ipad and it broke more or less immediately. Would be interesting to know how thick it is so it can be compared to other Ipads, I really don’t think this is acceptable.
Tomas Andersson - Ответить
Hello,
Wondering if you. Guys can help direct me the correct way. I have a ipad 5th Gen that the Glass broke. I removed the glass and saved the digitizer but now I cannot find a Touch ID home button in replacement with the Glass. I read that the Touch ID won’t work from a Air 1 to the Ipad 5. I don’t care if the Touch ID feature doesn’t work. Just need someone to confirm the use of it from a Ipad Air 1 Home Button/Touch ID on a 2017 Model A1822. Thank You
Emmanuel Rodriguez - Ответить
Can you replace a shattered screen????
Bryan Spannaus - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 17
За последние 7 дней: 104
За последние 30 дней: 436
За всё время: 173,985
