Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
A game console released in North America by the Nintendo Company in 1985, called the Nintendo Entertainment System, model NES-001.
No Image on TV and blinking light
Hi there! I bought a NES that doesnt work.. When i plug her on the TV, the light start blinking and no image appears on the TV, the image is the same as i didint have plugged the console.
Do you know what is wrong with the console? I tried different TV outputs and cleaning the cartridge reader.
Thanks in advance!
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (2)
Best bet is to take the NES Console apart, neatly and replace the 72-Pin connector. This will solve the problem 99.99% of the time.
Был ли этот ответ полезен?
Оценка 0
Hello. You have what may be a broken 72 Pin Connector. You May want to get a new one or it may be dirty so just clean it. The Game may be dirty too. Cut off the green part of a sponge or get scrub pads from the store too clean your pins. If it does not work, Open your cartridge and clean the pins well with a small ammount of counter top cleaner. brish it on and then take a towl and wipe the cleaner off. Then put the case back on. Please only do this with the game.
Оценка 0
Добавьте свой ответ
Daniel Reis будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 3
За последние 7 дней: 5
За последние 30 дней: 7
За всё время: 1,273
