Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
My note 5 got wet
my note 5 got wet not much but now the back button is not working what should i do to get it back working
Это хороший вопрос?
Оценка 5
Добавить комментарий
Ответов (4)
Выбранное решение
If its just the back button then you can replace it and all will be right
Samsung Galaxy Note5 LCD screen & USB board & Home button Replacement
There is a small cuircut board that can be replaced
They can be purchased on amazon or ebay. Sorry there not available here
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
hi i droped my samsung galaxy note5 in the water and i dont no what to do?
из
My charging port got wet and my phone won't charge correctly, I don't know what to do.
Оценка 0
1 Комментарий:
Firstly you can try to make the charging port dry,such as blotting paper,hair drier with very little wind,etc.
If it is still not work,I think you need buy a new charging port flex cable and replace it.
из
Well instead of paying for it to get fixed you can easy just let it completely dry and backup all of your photos,videos,and contacts. And master reset it. That's what I did to mine and I dropped it in a fish tank
Оценка 0
1 Комментарий:
I cleaned a clients note 4 thoroughly. Still didn't work as some component chips are burnt.
из
Hi I have a stylo 5 and I just got a stylo 5 and I dropped it in water. After i put it in rice it would only turn on and then say it has no power. My phone won't charge when I plugged it in or show the light that there is a charge. I put it back in the rice to try to dry it out again but I was just wondering what else I could do to try to get it to start charging
Оценка 0
Добавьте свой ответ
vlutchman23 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 11
За всё время: 6,367
