Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
Вопросов 20 Показать все
Replace Logic board with Late 2009 logic board?
I bought this from a govt auction. They pulled the hard drive out, but in that process they broke the display adapter on the logic board. Can I replace this board with a board from Late 2009?
Это хороший вопрос?
Оценка 0
5 Комментариев
Please post a few pics of the damage Adding images to an existing question so we can see what you need.
из
Hi Dan, I just uploaded a couple of pictures.
из
Yup it is possible
if you find my answer useful please click accept as a solution.
из
@imacman123 - So how you you fix this?
Saying its possible is not an answer!
из
I meant it is possible to use a 2009 replacement logic board on an iMac 2009 sorry for misunderstanding.
из
Добавить комментарий
Ответов (3)
Наиболее полезный ответ
I’d see if I could disconnect the connector body which was pulled off with the cable from display cable, then connect it to the logic board and secure it with Kapton tape then connect the cable back to the display.
Был ли этот ответ полезен?
Оценка 3
4 Комментариев:
@mayer - Yes, threading the plastic shell back is a possible solution!
из
So, the logic board connection would be the new "permanent" connection?
из
prabs That's the idea. Straighten those pins up some before doing it first.
из
Thanks. I will give it a shot or try what Dan suggested.
из
Here’s a vid showing the steps to re-tin the pads after desoldering the pins from them iMac 21,5" & 27" LVDS Display connector repair and here is the connector LCD Display LVDS Cable Connector (30-pin)
You may want to find someone with the needed tools and skills to put a new connector on. This would be the best solution if you can’t get the pins re-inserted into the shell.
Оценка 2
1 Комментарий:
Thanks. I will ask if my buddy can give it a shot or try what mayer suggested.
из
The best solution would be to solder a new socket on the board. Try to fit the broken one is risky cause you could short pins and damage the display and (or) the logic board. There's 50v passing thru the socket to the display cable.
Оценка 1
1 Комментарий:
Long time, no see
из
Добавьте свой ответ
prabs77 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 131
