Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
Вопросов 20 Показать все
iMac 27 black screen.
hi i bought a broken apple imac 27 the system powers on but no apple start up sound and also the screen stays black.
i tryed connecting to a external display but still does not work.
i have looked at the diagnostic leds left of the ram slots with the screen removed and i just see 2 leds that stop on.
anyone help please.
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Hook the iMac up to a external monitor. If it still doesn't work, it's the video card.
These iMacs should use a MXM graphics card. Here's a guide on how to replace it.
This is probably the cause of the problem in your computer. If this doesn't fix it, then come back on the issue.
If the video card doesn't fix it, then I'd look into the screen. It's usually not the screen though. However, it can cause this problem. If you wanted to check without a GPU, then shine a flashlight at the screen and see if you get an image. If you do, it's probably the screen. If not, it's a bad screen altogether or a bad graphics card.
Был ли этот ответ полезен?
Оценка 1
6 Комментариев:
the emc number is 2374 mate does this help.
из
forgot to put its a Model Number A1312 late 2009 model emc number is 2374
из
I thought hat would work, but it only pulls iBooks and emacs up, it looks like i need the last 3 digits of mur serial number, it's in the same place
из
the last 3 digits of the serial number is: 5RU
из
I have put the link where the serial number lookup can be done, it is not working for me
из
Показать 1 больше комментариев
Добавьте свой ответ
joey будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,208
