Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
DJI Mini 2 Gimbal Camera Replacement
Parker Sowersby
Parker Sowersby и 4 другие участники
Последнее обновление July 5, 2024
1 - 2 часы
Средне
This guide will show you how to successfully replace the gimbal assembly inside the DJI Mini 2 drone. If you need more detailed information on disassembling the gimbal camera to replace the camera cable or replace the gimbal housing, watch the video guide.
The Gimbal Camera is the camera that allows the drone to capture video and photos. It also can rotate in place to allow for multiple angles for the photos the drone can take. If the Gimbal Camera is broken or damaged this will prevent the drone from successfully capturing photos and videos.
This guide requires the use of ESD-safe tools.
If you have replaced the gimbal assembly, you will need to calibrate your DJI Mini 2 drone, but for gimbal calibration, you will need to use additional software.
How to calibrate the gimbal camera watch this video tutorial https://youtu.be/mu03HWXplM4
Выберете то, что вам нужно
Инструменты
Показать больше…
Видео обзор
  1. DJI Mini 2 Gimbal Camera Replacement, Battery: шаг 1, изображение 1 из 2 DJI Mini 2 Gimbal Camera Replacement, Battery: шаг 1, изображение 2 из 2
    • Face the DJI Mini 2 away from you so that you are looking at the charging ports.
    • Use your finger to open up the back panel.
  2. DJI Mini 2 Gimbal Camera Replacement: шаг 2, изображение 1 из 2 DJI Mini 2 Gimbal Camera Replacement: шаг 2, изображение 2 из 2
    • Pinch the locking mechanism on the battery to release the lock.
    • Pull the battery straight out of the compartment.
    Honestly, did we need an ifixit tutorial on THIS?!
    Next up, how to insert the battery.
    Big Ed - Ответить
    @big_ed Perhaps author wanted to make sure no electric issues to occur @people who are not aware of possible damages whilst having battery still inside.. Next up, a smart remark?
    Ruud - Ответить
    Merci 🔥 pour le tuto j'avais oublié comment on fait
    Layoness Record - Ответить
    Merci à vous pour ce bref mais incontournable tutoriel permettant l'accès à la batterie !
    Albert Brian Frank - Ответить
  3. DJI Mini 2 Gimbal Camera Replacement, Drone Body: шаг 3, изображение 1 из 2 DJI Mini 2 Gimbal Camera Replacement, Drone Body: шаг 3, изображение 2 из 2
    • Unfold the wings of the drone.
    • Place the drone upside down on a flat surface.
    • There should be stickers on the device telling you how to unfold the propeller arms.
  4. DJI Mini 2 Gimbal Camera Replacement: шаг 4, изображение 1 из 2 DJI Mini 2 Gimbal Camera Replacement: шаг 4, изображение 2 из 2
    • Remove the four 5 mm J000 screws near each propeller arm.
  5. DJI Mini 2 Gimbal Camera Replacement: шаг 5, изображение 1 из 3 DJI Mini 2 Gimbal Camera Replacement: шаг 5, изображение 2 из 3 DJI Mini 2 Gimbal Camera Replacement: шаг 5, изображение 3 из 3
    • Flip the drone back over.
    • Use a combination of the opening tool and your fingers to pry open the top panel of the drone along the seams.
  6. DJI Mini 2 Gimbal Camera Replacement: шаг 6, изображение 1 из 2 DJI Mini 2 Gimbal Camera Replacement: шаг 6, изображение 2 из 2
    • Remove the two 5 mm J000 screws located in the battery hatch and near the ports on the back of the drone.
  7. DJI Mini 2 Gimbal Camera Replacement: шаг 7, изображение 1 из 2 DJI Mini 2 Gimbal Camera Replacement: шаг 7, изображение 2 из 2
    • Flip the drone over again.
    • Pry off the bottom panel of the drone using the opening tools and your fingers.
  8. DJI Mini 2 Gimbal Camera Replacement, Main Board: шаг 8, изображение 1 из 3 DJI Mini 2 Gimbal Camera Replacement, Main Board: шаг 8, изображение 2 из 3 DJI Mini 2 Gimbal Camera Replacement, Main Board: шаг 8, изображение 3 из 3
    • Remove the three 3mm J000 screws on the black plate.
  9. DJI Mini 2 Gimbal Camera Replacement: шаг 9, изображение 1 из 2 DJI Mini 2 Gimbal Camera Replacement: шаг 9, изображение 2 из 2
    • Use your fingers to pull the black plate off to reveal main board.
  10. DJI Mini 2 Gimbal Camera Replacement: шаг 10, изображение 1 из 3 DJI Mini 2 Gimbal Camera Replacement: шаг 10, изображение 2 из 3 DJI Mini 2 Gimbal Camera Replacement: шаг 10, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Try to avoid disturbing the blue thermal paste covering two of the large board components. If the paste is disturbed or splotchy in places it may need to be removed and reapplied. For more information refer to the How to Apply Thermal Paste guide.
    • Using ESD Safe Tweezers Blunt Nose, remove the 5 cables attached to the main board.
  11. DJI Mini 2 Gimbal Camera Replacement: шаг 11, изображение 1 из 2 DJI Mini 2 Gimbal Camera Replacement: шаг 11, изображение 2 из 2
    • Use the ESD Safe Tweezers Blunt Nose and your fingers to pull off the main board from the drone carriage.
    note: the connectors are stuck with a hotglue sometimes, so be careful. i suggest heating gently before attempting to break the glue.
    jcollins1905 - Ответить
  12. DJI Mini 2 Gimbal Camera Replacement, Gimbal Camera: шаг 12, изображение 1 из 2 DJI Mini 2 Gimbal Camera Replacement, Gimbal Camera: шаг 12, изображение 2 из 2
    • Use your hands to remove the camera cover.
  13. DJI Mini 2 Gimbal Camera Replacement: шаг 13, изображение 1 из 1
    • Pull the cable that was once attached to the mainboard and attaches to the camera through the main body.
  14. DJI Mini 2 Gimbal Camera Replacement: шаг 14, изображение 1 из 2 DJI Mini 2 Gimbal Camera Replacement: шаг 14, изображение 2 из 2
    • Use the tweezers to pull the four rubber camera holsters off of the body.
  15. DJI Mini 2 Gimbal Camera Replacement: шаг 15, изображение 1 из 1
    • Using the J000 screwdriver, remove the two remaining 3 mm screws connecting the camera to the body.
    • Remove the camera.
Заключение
5 человек успешно провели ремонт по этому руководству.
Parker Sowersby
Участник с: 03/28/22
295 Репутация
Автор 2 руководств
Команду
UMass Dartmouth, Team F-1, Gurgel Spring 2022 Участник UMass Dartmouth, Team F-1, Gurgel Spring 2022
UMASSD-GURGEL-S22SFG1
2 членов
Автор 15 руководств
7 Комментариев
this guide is missing so many steps its ridiculous
Ben Coleman - Ответить
Hi Ben, thank you for the constructive criticism, but this is what happens when you make “creating a guide” a class requirement for a grade rather then hire professionals. I personally had no idea what I was doing writing this and just wanted to get my grade. So unfortunately, this guide will not be updated.
Parker Sowersby -
Check out the video guide
Arty -
Thank you very much for your tutorial. I successfully managed to replace my broken camera assembly. Maybe you should mention how to insert gimbal back (not as easy as it seems). With the official part, you have to use pliers to pull the little rubber parts. And even with an official part, you will always have a warning message about calibration. We can’t do anything for this except sending the drone to dji. Even if the calibration is fine and the drone perfectly working, there is this anti self repair « protection »… Only a certified DJI technician/shop can remove the error.
Gauthier Heiss - Ответить
Thanks for the warning about anti self-repair! Was debating replacing it myself to save using up a strike for more serious damage. I didn't see anything about that voiding the warranty though...
Dawson Ross -
Where do you get the parts?
Dillon Hughes - Ответить
Hi. My gimbal brackets have been snapped. I need to replace it with new one.I already purchased the new gimbal from Amazon. In your tutorial missed to explain how to replace it. Please advise.
Max - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 13
За последние 7 дней: 90
За последние 30 дней: 417
За всё время: 19,602
