Dell Latitude 7490 Charging Port Replacement
Введение
Перейти к шагу 1Use this guide to replace the charging port in your Dell Latitude 7490.
Выберете то, что вам нужно
Unplug all cables and fully shut down your laptop.
Flip your laptop over so the rubber feet strips are facing up.
Use a Phillips screwdriver to fully loosen the eight captive screws securing the back cover.
Insert the long side of an opening pick between the top right corner of the back cover and frame.
Pry the back cover up to release the clips securing the top right corner.
Slide the opening pick down the right edge and around the bottom right corner to release the clips.
Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
Grip the plastic tab on the battery connector and pull straight up to disconnect it.
Use a Phillips screwdriver to remove the 3.8 mm‑long screw securing the charging port bracket.
Remove the bracket.
Grip the charging port cable just below its connector.
Pull the connector straight out of its socket and remove the charging port.
