Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Dell XPS 15 9570 Battery Replacement
Clay Caldwell
Clay Caldwell и 12 другие участники
Последнее обновление February 4, 2025
10 - 20 минут
Средне
Ненаглядные фото
Нужно больше изображений
This guide will teach you how to replace the battery in your Dell XPS 15 9570.
This process will require a T5 Torx Screwdriver, an iFixit Opening Tool, Phillips #00 Screwdriver, and a replacement battery.
Batteries are what let your laptop hold power. A bad battery can lead to many problems. Here are some signs that your battery may need replacing:
  • The laptop will not stay on, or cannot run without being plugged-in. Constant shutting down is a major sign of battery issues.
  • The laptop will not charge properly.
  • If the battery appears to have become swollen or to have leaked, BE EXTRA CAREFUL.
If your battery is swollen check out this article below:
What to Do With a Swollen iPhone Battery
(It says iPhone, but the same process goes for any lithium-ion battery)
Before starting the repair, swollen battery or not, unplug the device and let the battery's charge reach 0%.
Remember that after you have successfully replaced the battery (which we are sure you will) please recycle it: How to Properly Recycle Your Old iPhone Battery
(Again it says iPhone, but the same process goes for any lithium-ion battery).
Выберете то, что вам нужно
Ремонтный комплект
Этот комплект содержит все детали и инструменты, используемые в руководстве.
Запчасти
Инструменты
Показать больше…
  1. Dell XPS 15 9570 Battery Replacement, Base Cover: шаг 1, изображение 1 из 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Battery Replacement: шаг 2, изображение 1 из 3 Dell XPS 15 9570 Battery Replacement: шаг 2, изображение 2 из 3 Dell XPS 15 9570 Battery Replacement: шаг 2, изображение 3 из 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Battery Replacement: шаг 3, изображение 1 из 2 Dell XPS 15 9570 Battery Replacement: шаг 3, изображение 2 из 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Battery Replacement: шаг 4, изображение 1 из 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Battery Replacement, Battery: шаг 5, изображение 1 из 1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Battery Replacement: шаг 6, изображение 1 из 1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Battery Replacement: шаг 7, изображение 1 из 1
    • With your hands, pick up and remove the battery from the system.
Заключение
13 человек успешно провели ремонт по этому руководству.
Clay Caldwell
Участник с: 09/03/21
369 Репутация
Автор 2 руководств
Команду
University of Alabama, Team 2-4, Bedsole Fall 2021 Участник University of Alabama, Team 2-4, Bedsole Fall 2021
UA-BEDSOLE-F21S2G4
3 членов
Автор 18 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 13
За последние 7 дней: 83
За последние 30 дней: 366
За всё время: 21,951
