Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement
Alex Diaz-Kokaisl
Alex Diaz-Kokaisl
Последнее обновление December 28, 2023
1 - 2 часы
Средне
Use this guide to replace the left Joy-Con sensor rail in your Nintendo Switch OLED.
For your safety, discharge the battery below 25% before disassembling your Switch. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
The Switch OLED uses JIS screws, but you can use a Phillips screwdriver in a pinch. Be very careful not to strip the screws. iFixit's Phillips bits are designed to be cross-compatible with JIS-style screws.
Note: When you remove the shield plate, you’ll need to replace the thermal compound between the plate and the heatsink. Since normal thermal paste isn’t designed to bridge large gaps, the closest replacement is K5 Pro viscous thermal paste. You will, however, need regular replacement thermal paste when replacing the heat sink.
Выберете то, что вам нужно
Запчасти
Инструменты
Показать больше…
iFixit получает комиссию, когда вы совершаете покупку по этим ссылкам.
  1. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Release the Joy Con controller locking tabs: шаг 1, изображение 1 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Release the Joy Con controller locking tabs: шаг 1, изображение 2 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Release the Joy Con controller locking tabs: шаг 1, изображение 3 из 3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the Joy Con controllers: шаг 2, изображение 1 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the Joy Con controllers: шаг 2, изображение 2 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the Joy Con controllers: шаг 2, изображение 3 из 3
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the top screw: шаг 3, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the top screw: шаг 3, изображение 2 из 2
    • Use a Phillips driver, or a JIS driver, to remove the 2 mm-long screw securing the top of the rear case to the frame.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS or Phillips driver if the screws won't come out.
  4. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the bottom screws: шаг 4, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the bottom screws: шаг 4, изображение 2 из 2
    • Use a Phillips driver to remove the two 2 mm-long screws securing the bottom of the rear case to the frame.
  5. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the right screw: шаг 5, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the right screw: шаг 5, изображение 2 из 2
    • Use a Phillips driver to remove the 3.8 mm screw securing the right Joy-Con sensor rail to the rear case.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  6. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the left screw: шаг 6, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the left screw: шаг 6, изображение 2 из 2
    • Use a Phillips driver to remove the 3.8 mm screw securing the left Joy-Con sensor rail to the rear case.
  7. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Open the kickstand: шаг 7, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Open the kickstand: шаг 7, изображение 2 из 2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  8. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the back-side screws: шаг 8, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the back-side screws: шаг 8, изображение 2 из 2
    • Use a Y00 screwdriver to remove the two 4.3 mm screws securing the rear case to the frame.
  9. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the rear case: шаг 9, изображение 1 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the rear case: шаг 9, изображение 2 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the rear case: шаг 9, изображение 3 из 3
    • Lift the rear case up from the top of the device and remove it.
    • If you're having trouble removing the case, use an opening pick to pry up the plastic clips.
  10. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the shield plate's tape: шаг 10, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the shield plate's tape: шаг 10, изображение 2 из 2
    • Use the flat end of a spudger to separate a corner of the tape from the shield plate.
  11. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 11, изображение 1 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 11, изображение 2 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 11, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Use tweezers, or your fingers, to peel back and remove the tape.
    • Store the tape in a clean space for reinstallation.
  12. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the primary Wi-Fi antenna: шаг 12, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the primary Wi-Fi antenna: шаг 12, изображение 2 из 2
    • Use tweezers, or your fingers, to pull up and disconnect the primary Wi-Fi antenna's coaxial cable.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  13. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Reroute the primary antenna's coaxial cable: шаг 13, изображение 1 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Reroute the primary antenna's coaxial cable: шаг 13, изображение 2 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Reroute the primary antenna's coaxial cable: шаг 13, изображение 3 из 3
    • Use tweezers, or your fingers, to reroute the primary antenna's coaxial cable out of its slots in the shield plate.
  14. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Unfasten the primary Wi-Fi antenna: шаг 14, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Unfasten the primary Wi-Fi antenna: шаг 14, изображение 2 из 2
    • Use a Phillips driver to remove the two 4.4 mm screws securing the primary Wi-Fi antenna to the shield plate.
  15. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the primary Wi-Fi antenna: шаг 15, изображение 1 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the primary Wi-Fi antenna: шаг 15, изображение 2 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the primary Wi-Fi antenna: шаг 15, изображение 3 из 3
    • Insert an opening pick between the primary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the primary Wi-Fi antenna from the shield plate.
  16. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 16, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 16, изображение 2 из 2
    • Remove the primary Wi-Fi antenna.
  17. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the secondary Wi-Fi antenna: шаг 17, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the secondary Wi-Fi antenna: шаг 17, изображение 2 из 2
    • Use tweezers, or your fingers, to pull up and disconnect the secondary Wi-Fi antenna's coaxial cable.
  18. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: шаг 18, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: шаг 18, изображение 2 из 2
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable from its slot in the frame.
  19. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Unfasten the secondary Wi-Fi antenna: шаг 19, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Unfasten the secondary Wi-Fi antenna: шаг 19, изображение 2 из 2
    • Use a Phillips driver to remove the 4.4 mm screw securing the secondary Wi-Fi antenna to the shield plate.
  20. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the secondary Wi-Fi antenna: шаг 20, изображение 1 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the secondary Wi-Fi antenna: шаг 20, изображение 2 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the secondary Wi-Fi antenna: шаг 20, изображение 3 из 3
    • Insert an opening pick between the secondary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the secondary Wi-Fi antenna from the shield plate.
    • Don't attempt to completely remove the antenna yet, as its coaxial cable is still routed through the frame.
  21. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 21, изображение 1 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 21, изображение 2 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 21, изображение 3 из 3
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable out of its slot in the frame.
    • Remove the secondary Wi-Fi antenna.
  22. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Unfasten the shield plate: шаг 22, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Unfasten the shield plate: шаг 22, изображение 2 из 2
    • Use a Phillips driver to remove the six 4.4 mm screws securing the shield plate to the frame.
  23. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 23, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 23, изображение 2 из 2
    • Use your fingers to lift the top of the shield plate up and away from the frame.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Whenever the shield plate is removed, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as K5 Pro, during reassembly.
  24. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the battery: шаг 24, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the battery: шаг 24, изображение 2 из 2
    • Use the point of a spudger to pry up and disconnect the battery.
  25. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the tape: шаг 25, изображение 1 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the tape: шаг 25, изображение 2 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the tape: шаг 25, изображение 3 из 3
    • Use tweezers, or your fingers, to remove the piece of tape obscuring the daughterboard's screw.
  26. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Unfasten the daughterboard: шаг 26, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Unfasten the daughterboard: шаг 26, изображение 2 из 2
    • Use a Phillips driver to remove the 4 mm screw securing the daughterboard to the frame.
  27. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the daughterboard: шаг 27, изображение 1 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the daughterboard: шаг 27, изображение 2 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the daughterboard: шаг 27, изображение 3 из 3
    • The bottom of the daughterboard is connected to the motherboard via a press connector.
    • Insert a spudger between the edge of the daughterboard and the motherboard.
    • Pry up with the spudger to disconnect the press connector and separate the daughterboard from the frame.
    • Remove the daughterboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  28. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Unfasten the heat sink: шаг 28, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Unfasten the heat sink: шаг 28, изображение 2 из 2
    • Use a Phillips driver to remove the three 3 mm screws securing the heat sink to the motherboard.
  29. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the heat sink: шаг 29, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the heat sink: шаг 29, изображение 2 из 2
    • Insert a spudger between the heat sink's bracket and the motherboard.
    • Pry up with the spudger to separate the heat sink from the motherboard.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
  30. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 30, изображение 1 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 30, изображение 2 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 30, изображение 3 из 3
    • Insert a spudger in the gap between the fan and the heat sink.
    • Pry up with the spudger to separate the heat sink from the adhesive beneath it.
    • Remove the heat sink.
    • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
  31. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the fan's ZIF connector: шаг 31, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the fan's ZIF connector: шаг 31, изображение 2 из 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
  32. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 32, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 32, изображение 2 из 2
    • Use a pair of tweezers to pull the fan cable straight out of its connector on the motherboard.
  33. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Unfasten the fan: шаг 33, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Unfasten the fan: шаг 33, изображение 2 из 2
    • Use a Phillips driver to remove the three 3 mm screws securing the fan to the frame.
  34. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the fan: шаг 34, изображение 1 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the fan: шаг 34, изображение 2 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the fan: шаг 34, изображение 3 из 3
    • Use a spudger to lift the fan out straight out of the frame.
    • Remove the fan.
  35. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the power button board's ZIF connector: шаг 35, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the power button board's ZIF connector: шаг 35, изображение 2 из 2
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the power button board's ZIF connector.
  36. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 36, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 36, изображение 2 из 2
    • Use a pair of tweezers to pull the power button board cable straight out of its connector on the motherboard.
  37. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the right Joy-Con sensor rail's ZIF connector: шаг 37, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the right Joy-Con sensor rail's ZIF connector: шаг 37, изображение 2 из 2
    • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the right Joy-Con sensor rail's ZIF connector.
  38. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 38, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 38, изображение 2 из 2
    • Use a pair of tweezers to pull the right Joy-Con sensor rail's cable straight out of its connector on the motherboard.
  39. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the display's ZIF connector: шаг 39, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the display's ZIF connector: шаг 39, изображение 2 из 2
    • Use an opening tool, spudger, or your fingernail to flip up the hinged locking flap on the display's ZIF connector.
  40. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 40, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 40, изображение 2 из 2
    • Use a pair of tweezers to pull the display cable straight out of its connector on the motherboard.
  41. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the left speaker: шаг 41, изображение 1 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the left speaker: шаг 41, изображение 2 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the left speaker: шаг 41, изображение 3 из 3
    • Use blunt tweezers, or your fingers, to pull the left speaker's JST connector out of its socket.
  42. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the right speaker: шаг 42, изображение 1 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the right speaker: шаг 42, изображение 2 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the right speaker: шаг 42, изображение 3 из 3
    • Use blunt tweezers, or your fingers, to pull the right speaker's JST connector out of its socket.
  43. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the left Joy-Con sensor rail's ZIF connector: шаг 43, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Disconnect the left Joy-Con sensor rail's ZIF connector: шаг 43, изображение 2 из 2
  44. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 44, изображение 1 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 44, изображение 2 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement: шаг 44, изображение 3 из 3
    • Use a pair of tweezers to pull the left Joy-Con sensor rail's cable straight out of its connector on the motherboard.
  45. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Unfasten the motherboard: шаг 45, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Unfasten the motherboard: шаг 45, изображение 2 из 2
    • Use a Phillips driver to remove the five screws securing the midframe to the frame:
    • Three 3 mm screws
    • Two 4.4 mm screws
  46. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the motherboard: шаг 46, изображение 1 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the motherboard: шаг 46, изображение 2 из 3 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the motherboard: шаг 46, изображение 3 из 3
    • Insert a spudger between the motherboard and the frame.
    • Pry up with the spudger to separate the motherboard from the frame.
    • Remove the motherboard.
  47. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Left Joy-Con Sensor Rail: шаг 47, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Left Joy-Con Sensor Rail: шаг 47, изображение 2 из 2
    • Use your fingers to gently peel back the left Joy-Con sensor rail's cable from the frame.
  48. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Unfasten the left Joy-Con sensor rail: шаг 48, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Unfasten the left Joy-Con sensor rail: шаг 48, изображение 2 из 2
    • Use a Phillips driver to remove the 3.8 mm screw securing the left Joy-Con sensor rail to the frame.
  49. Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the left Joy-Con sensor rail: шаг 49, изображение 1 из 2 Nintendo Switch OLED Model Left Joy-Con Sensor Rail Replacement, Remove the left Joy-Con sensor rail: шаг 49, изображение 2 из 2
    • Remove the left Joy-Con sensor rail.
Заключение
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
4 человек успешно провели ремонт по этому руководству.
Alex Diaz-Kokaisl
Участник с: 01/16/22
162 867 Репутация
Автор 769 руководств
Команду
iFixit Участник iFixit
Staff
119 членов
Автор 19 481 руководств
3 Комментариев
I don't believe the PH00 mentioned at the top is the correct screwdriver for this. Like the original Switch Left Joy Con Rail replacement guide, JIS000 seems to be more correct after I found out the hard way. Maybe Y000 as well, but Y00 worked well enough.
I would also recommend adding the "These screws are torqued down" warning on the rail screw sections, as those screws were specifically the ones that stripped for me, which I also saw was present in the original Switch Left Joy Con Rail guide.
I'm also a little confused why Step 6 has you remove the middle screw from the left rail just for removing the back shell. At least on my Switch OLED, only the topmost rail screws on the left and right rails go through the back shell. While this is required later for this particular tutorial, it doesn't seem necessary this early.
xperia64 - Ответить
Hi there.
Great points! I have updated the guides accordingly.
Alex Diaz-Kokaisl -
Thank you so much for this 🙌🏻 ordered a rail and screwdriver kit from Amazon to give this a try and my sons left joycon was not connecting even after cleaning and trying different joycon, yes it felt like open heart surgery 😂 but for my first time doing anything like this and your clear instructions it’s now all fixed 😅 THANK YOU
Charlene Fawcett - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 21
За последние 7 дней: 134
За последние 30 дней: 442
За всё время: 9,155
