iPad Pro 11" 3rd Gen Battery Replacement
Выберете то, что вам нужно
    1. iPad Pro 11" 3rd Gen Battery Replacement, Prepare your iPad for disassembly: шаг 1, изображение 1 из 1
      • Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair.
      • Unplug any cables and fully shut down your iPad.
      • If your battery is swollen, take appropriate precautions.
      Спросите у FixBot
      Добавить комментарий
    1. iPad Pro 11" 3rd Gen Battery Replacement, Screen removal information: шаг 2, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Screen removal information: шаг 2, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Screen removal information: шаг 2, изображение 3 из 3
      • While your iPad looks uniform from the outside, there are delicate components under portions of the screen. To avoid damage, follow instructions exactly as written and note the following areas as you open your iPad:
      • Camera module, ambient light sensors, proximity senor, and front microphone
      • Display cables
      • Screen magnets
      • LCD edges
      Спросите у FixBot
    2. iPad Pro 11" 3rd Gen Battery Replacement, Heat the right edge: шаг 3, изображение 1 из 1
      • Apply a heated iOpener to the right edge of the screen for two minutes.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the screen and/or internal battery, so proceed with care.
      Спросите у FixBot
    3. iPad Pro 11" 3rd Gen Battery Replacement, Anti-Clamp instructions: шаг 4, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Anti-Clamp instructions: шаг 4, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Anti-Clamp instructions: шаг 4, изображение 3 из 3
      Инструмент, используемый на этом этапе:
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backward to unlock the Anti-Clamp's arms.
      • Place an object under your iPad so it rests level between the suction cups.
      • Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
      Спросите у FixBot
    4. iPad Pro 11" 3rd Gen Battery Replacement: шаг 5, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 5, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 5, изображение 3 из 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Спросите у FixBot
    5. iPad Pro 11" 3rd Gen Battery Replacement: шаг 6, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement: шаг 6, изображение 2 из 2
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next step.
      Спросите у FixBot
    6. iPad Pro 11" 3rd Gen Battery Replacement, Insert an opening pick: шаг 7, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Insert an opening pick: шаг 7, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Insert an opening pick: шаг 7, изображение 3 из 3
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Apply a suction handle to the right edge of the screen, about 5 cm from the bottom edge.
      • Pull up on the suction handle with firm, constant pressure to create a gap just small enough to insert an opening pick.
      • Only create a gap small enough to insert an opening pick. Overbending the screen will damage it.
      • Insert the tip of an opening pick into the gap.
      • Don't insert the opening pick more than 5 mm or you may damage the LCD.
      Спросите у FixBot
    7. iPad Pro 11" 3rd Gen Battery Replacement, Separate the right edge adhesive: шаг 8, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the right edge adhesive: шаг 8, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the right edge adhesive: шаг 8, изображение 3 из 3
      • Insert a new opening pick in the gap you just created.
      • Slide the pick along the right edge to separate the adhesive.
      • When sliding near the volume buttons, don't insert the pick more than 2 mm or you'll damage the screen magnets.
      • Leave the pick in the top right corner to prevent the adhesive from re-sealing.
      Спросите у FixBot
    8. iPad Pro 11" 3rd Gen Battery Replacement, Heat the top edge: шаг 9, изображение 1 из 1
      • Apply a heated iOpener to the top edge of the screen for two minutes.
      Спросите у FixBot
    9. iPad Pro 11" 3rd Gen Battery Replacement, Top edge information: шаг 10, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Top edge information: шаг 10, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Top edge information: шаг 10, изображение 3 из 3
      • The top edge of the iPad contains the camera module, two ambient light sensors, the proximity sensor, and front microphone. These components are fragile and easily damaged if an opening pick is inserted too far. Only separate the adhesive in the marked locations to avoid damage.
      • The two ambient light sensors can be hard to see and can be located using a flashlight or by placing the iPad under a bright light.
      • Don't insert an opening pick more than 2 mm near the top left and right edges or you'll damage the ambient light sensors.
      • Don't insert an opening pick more than 1 mm near the middle of the top edge or you'll damage the camera module, proximity sensor, and front microphone.
      Спросите у FixBot
    10. iPad Pro 11" 3rd Gen Battery Replacement, Separate the top edge adhesive: шаг 11, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Separate the top edge adhesive: шаг 11, изображение 2 из 2
      • Slide the pick along the top right edge, stopping when you reach the right ambient light sensor.
      • Don't insert the opening pick more than 5 mm.
      • Leave the pick in to prevent the adhesive from re-sealing.
      Спросите у FixBot
    11. iPad Pro 11" 3rd Gen Battery Replacement: шаг 12, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 12, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 12, изображение 3 из 3
      • Insert a new opening pick to the right of the ambient light sensor.
      • Slide the pick along the middle section of the top edge, stopping when you reach the left ambient light sensor.
      • Don't insert the pick more than 1 mm or you'll damage the proximity sensor and front microphone.
      Спросите у FixBot
    12. iPad Pro 11" 3rd Gen Battery Replacement: шаг 13, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement: шаг 13, изображение 2 из 2
      • Insert a new opening pick to the left of the ambient light sensor.
      • Slide the pick along the top left edge, stopping when you reach the left ambient light sensor.
      • Once the top edge adhesive has been separated, you can remove the two picks near the ambient light sensors.
      Спросите у FixBot
    13. iPad Pro 11" 3rd Gen Battery Replacement, Heat the bottom edge: шаг 14, изображение 1 из 1
      • Apply a heated iOpener to the bottom edge of the screen for two minutes.
      Спросите у FixBot
    14. iPad Pro 11" 3rd Gen Battery Replacement, Separate the bottom edge adhesive: шаг 15, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Separate the bottom edge adhesive: шаг 15, изображение 2 из 2
      • Insert a new opening pick in the bottom right corner below the existing pick.
      • Don't insert the opening pick more than 2 mm when sliding on the right edge.
      • Slide the pick around the bottom right corner to separate the adhesive.
      Спросите у FixBot
    15. iPad Pro 11" 3rd Gen Battery Replacement: шаг 16, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement: шаг 16, изображение 2 из 2
      • Slide the opening pick along the bottom edge, stopping at the USB-C port.
      • Don't insert the opening pick more than 5 mm when separating the bottom edge adhesive.
      • Leave the pick in to prevent the bottom edge adhesive from re-sealing.
      Спросите у FixBot
    16. iPad Pro 11" 3rd Gen Battery Replacement: шаг 17, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement: шаг 17, изображение 2 из 2
      • Insert a new opening pick to the left of the USB-C port.
      • Separate the remaining bottom edge adhesive.
      • Don't insert the opening pick more than 5 mm when slicing the bottom edge adhesive.
      • Leave the pick in the bottom left corner to prevent the bottom edge adhesive from re-sealing.
      Спросите у FixBot
    17. iPad Pro 11" 3rd Gen Battery Replacement, Heat the left edge: шаг 18, изображение 1 из 1
      • Apply a heated iOpener to the left edge of the screen for two minutes.
      Спросите у FixBot
    18. iPad Pro 11" 3rd Gen Battery Replacement, Left edge information: шаг 19, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Left edge information: шаг 19, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Left edge information: шаг 19, изображение 3 из 3
      • The left edge of the iPad contains several display cables. These cables are extremely fragile and easily damaged if an opening pick is inserted too far or at the wrong angle. Follow the instructions exactly as written to avoid damage.
      • The display cables are located within small indents of the frame and require an opening pick to be inserted at a 45° angle.
      • There are flat sections of the frame which require an opening pick to be inserted horizontally.
      Спросите у FixBot
    19. iPad Pro 11" 3rd Gen Battery Replacement, Separate the left edge adhesive: шаг 20, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Separate the left edge adhesive: шаг 20, изображение 2 из 2
      • Insert an opening pick at a 45˚ angle just above the bottom left corner.
      • Don't insert the pick more than 5 mm or you'll damage the display cables.
      • Carefully slide the pick along the left edge, stopping when you reach the flat section of the frame.
      Спросите у FixBot
    20. iPad Pro 11" 3rd Gen Battery Replacement: шаг 21, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement: шаг 21, изображение 2 из 2
      • Lower the opening pick so it is horizontal to the screen.
      • Don't insert the pick more than 5 mm.
      • Continue separating the left edge adhesive until you reach the next indented section of the frame.
      Спросите у FixBot
    21. iPad Pro 11" 3rd Gen Battery Replacement, Separate the remaining adhesive: шаг 22, изображение 1 из 1
      • Separate the remaining adhesive, making sure to follow the instructions exactly as written.
      • Slide the pick at a 45˚ downward angle and don't insert the pick more than 5 mm.
      • Slide the pick horizontally and don't insert the pick more than 5 mm.
      Спросите у FixBot
    22. iPad Pro 11" 3rd Gen Battery Replacement, Separate the screen from the frame: шаг 23, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the screen from the frame: шаг 23, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the screen from the frame: шаг 23, изображение 3 из 3
      • At this point, you've separated most of the screen adhesive. Lift the edges of the screen up slightly to check if there is any remaining adhesive.
      • Use an opening pick to remove any remaining adhesive keeping the screen stuck to the frame.
      • Grab the top right and bottom left corners of the screen.
      • Slowly slide the screen towards the bottom right corner to separate it from the frame.
      • Don't fully remove the screen as it is held in place by several ribbon cables underneath.
      • Shift the screen towards the bottom right corner of the frame until the ambient light sensor ribbon cable near the top edge is uncovered.
      Спросите у FixBot
    23. iPad Pro 11" 3rd Gen Battery Replacement, Unscrew the ambient light sensor cable bracket: шаг 24, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Unscrew the ambient light sensor cable bracket: шаг 24, изображение 2 из 2
      FixMat
      $36.95
      • Use a Phillips screwdriver to remove the two screws securing the ambient light sensor cable bracket to the logic board:
      • One 1.3 mm screw
      • One 2.0 mm screw
      • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
      Спросите у FixBot
    24. iPad Pro 11" 3rd Gen Battery Replacement, Remove the ambient light sensor cable bracket: шаг 25, изображение 1 из 1
      • Use a pair of tweezers or your fingers to remove the bracket.
      Спросите у FixBot
    25. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the ambient light sensor cable: шаг 26, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the ambient light sensor cable: шаг 26, изображение 2 из 2
      • Use the flat end of a spudger to disconnect the ambient light sensor cable by lifting straight up on the press connectors.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Спросите у FixBot
    26. iPad Pro 11" 3rd Gen Battery Replacement, Reposition the screen: шаг 27, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Reposition the screen: шаг 27, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Reposition the screen: шаг 27, изображение 3 из 3
      • Don't try to remove the screen yet, as it's still attached by delicate ribbon cables.
      • Grip the right edge of the screen and fold it open like a book.
      • Lay the screen down over the left edge of the iPad.
      Спросите у FixBot
    1. iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the lower cable shield: шаг 28, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the lower cable shield: шаг 28, изображение 2 из 2
      • Use a Phillips screwdriver to remove the five screws securing the lower cable shield to the logic board:
      • Two 2.0 mm screws
      • Three 1.3 mm screws
      Спросите у FixBot
    2. iPad Pro 11" 3rd Gen Battery Replacement, Remove the lower cable shield: шаг 29, изображение 1 из 1
      • Use tweezers or your fingers to grab and remove the lower cable shield.
      Спросите у FixBot
    3. iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the battery connector: шаг 30, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the battery connector: шаг 30, изображение 2 из 2
      • Use a Phillips screwdriver to remove the 1.8 mm screw securing the battery connector to the logic board.
      Спросите у FixBot
    1. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the display cables: шаг 31, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the display cables: шаг 31, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the display cables: шаг 31, изображение 3 из 3
      • Use the pointed end of a spudger to pry up and disconnect the top two display cables.
      Спросите у FixBot
    2. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the remaining display cables: шаг 32, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the remaining display cables: шаг 32, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the remaining display cables: шаг 32, изображение 3 из 3
      • Disconnect the two remaining display cables.
      Спросите у FixBot
    3. iPad Pro 11" 3rd Gen Battery Replacement, Remove the screen: шаг 33, изображение 1 из 1
      • Grip the right edge of the screen and lift it away.
      • During reassembly, before installing a screen, remove any remaining adhesive from the frame, and clean the glued areas with high-strength (>90%) isopropyl alcohol and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
      • If you plan to reinstall your existing screen, remove any remaining adhesive from the back and clean the adhered areas with isopropyl alcohol.
      • Follow this guide to install pre-cut adhesive strips on your iPad's screen before sealing it up.
      Спросите у FixBot
    1. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the USB-C port cable: шаг 34, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the USB-C port cable: шаг 34, изображение 2 из 2
      • Use the flat end of a spudger to disconnect the USB-C port cable.
      Спросите у FixBot
    2. iPad Pro 11" 3rd Gen Battery Replacement, Separate the USB-C cable adhesive: шаг 35, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the USB-C cable adhesive: шаг 35, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the USB-C cable adhesive: шаг 35, изображение 3 из 3
      • The USB-C port cable is secured to the logic board with weak adhesive.
      • Slide an opening pick between the cable and the logic board to separate the adhesive.
      Спросите у FixBot
    3. iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the USB-C port: шаг 36, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the USB-C port: шаг 36, изображение 2 из 2
      • Use a Phillips screwdriver to remove the two 1.9 mm screws securing the USB-C port to the frame.
      Спросите у FixBot
    4. iPad Pro 11" 3rd Gen Battery Replacement, Remove the USB-C port grounding contacts: шаг 37, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the USB-C port grounding contacts: шаг 37, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the USB-C port grounding contacts: шаг 37, изображение 3 из 3
      • Use tweezers to remove the two grounding contacts from each side of the USB-C port.
      Спросите у FixBot
    5. iPad Pro 11" 3rd Gen Battery Replacement, Remove the USB-C port: шаг 38, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Remove the USB-C port: шаг 38, изображение 2 из 2
      • Lift up and remove the USB-C port.
      Спросите у FixBot
    1. iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the top cable shield: шаг 39, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the top cable shield: шаг 39, изображение 2 из 2
      • Use a Phillips screwdriver to remove the three 1.2 mm screws securing the top cable shield.
      Спросите у FixBot
    2. iPad Pro 11" 3rd Gen Battery Replacement, Heat the top cable shield: шаг 40, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Heat the top cable shield: шаг 40, изображение 2 из 2
      • Apply a heated iOpener to the top cable shield for one minute to soften the adhesive securing it to the logic board.
      Спросите у FixBot
    3. iPad Pro 11" 3rd Gen Battery Replacement, Insert an opening pick: шаг 41, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Insert an opening pick: шаг 41, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Insert an opening pick: шаг 41, изображение 3 из 3
      • Insert an opening pick under the top cable shield and gently pry up to separate the adhesive.
      Спросите у FixBot
    4. iPad Pro 11" 3rd Gen Battery Replacement, Remove the top cable shield: шаг 42, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Remove the top cable shield: шаг 42, изображение 2 из 2
      • Use tweezers or your fingers to grab and remove the top cable shield.
      Спросите у FixBot
    1. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the IR dot projector cable: шаг 43, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the IR dot projector cable: шаг 43, изображение 2 из 2
      • Use the pointed end of a spudger to disconnect the IR dot projector cable.
      Спросите у FixBot
    2. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the camera cables: шаг 44, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the camera cables: шаг 44, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the camera cables: шаг 44, изображение 3 из 3
      • Use the pointed end of a spudger to disconnect the front-facing camera and Face ID camera.
      Спросите у FixBot
    3. iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the front camera assembly: шаг 45, изображение 1 из 1
      • Use a Torx T3 screwdriver to remove the two 2.1 mm screws securing the front camera assembly to the frame.
      Спросите у FixBot
    4. iPad Pro 11" 3rd Gen Battery Replacement, Remove the front camera assembly: шаг 46, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the front camera assembly: шаг 46, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the front camera assembly: шаг 46, изображение 3 из 3
      • Use the pointed end of a spudger to pry up and loosen the front camera assembly.
      • Use tweezers or your fingers to remove the front camera assembly.
      Спросите у FixBot
    1. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the two 5G mmWave antenna coaxial cables: шаг 47, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the two 5G mmWave antenna coaxial cables: шаг 47, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the two 5G mmWave antenna coaxial cables: шаг 47, изображение 3 из 3
      • To disconnect antenna cables like this, use tweezers to grip the connector near the cable and lift it up.
      • Use tweezers to disconnect the two antenna cables.
      • Be careful using tweezers or other pointy metal tools near the battery—a punctured battery may leak dangerous chemicals or cause a fire.
      • To reinstall, hold the connector in place and gently press straight down. The connector will “snap” into its socket much like the metal snaps on a jacket.
      Спросите у FixBot
    2. iPad Pro 11" 3rd Gen Battery Replacement, Separate the 5G mmWave antenna cables: шаг 48, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the 5G mmWave antenna cables: шаг 48, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the 5G mmWave antenna cables: шаг 48, изображение 3 из 3
      • The antenna cables are secured to the logic board with weak adhesive.
      • Slide an opening pick under the antenna cables to separate them from the logic board.
      Спросите у FixBot
    3. iPad Pro 11" 3rd Gen Battery Replacement: шаг 49, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 49, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 49, изображение 3 из 3
      • Use an opening pick to separate the thin foam covering the antenna cables.
      Спросите у FixBot
    4. iPad Pro 11" 3rd Gen Battery Replacement: шаг 50, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 50, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 50, изображение 3 из 3
      • The antenna cables are secured to the mmWave interconnect cable with weak adhesive.
      • Slide an opening pick between the antenna cables and the mmWave interconnect cable to separate them.
      Спросите у FixBot
    5. iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the antenna cable bracket: шаг 51, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the antenna cable bracket: шаг 51, изображение 2 из 2
      • Use a Phillips screwdriver to remove the 1.2 mm screw securing the press connector bracket to the logic board.
      Спросите у FixBot
    6. iPad Pro 11" 3rd Gen Battery Replacement, Remove the antenna cable bracket: шаг 52, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Remove the antenna cable bracket: шаг 52, изображение 2 из 2
      • Use tweezers or your fingers to remove the antenna cable bracket.
      Спросите у FixBot
    7. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the mmWave flex cable: шаг 53, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the mmWave flex cable: шаг 53, изображение 2 из 2
      • Use the flat end of a spudger to disconnect the mmWave flex cable.
      Спросите у FixBot
    8. iPad Pro 11" 3rd Gen Battery Replacement: шаг 54, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 54, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 54, изображение 3 из 3
      • Slide an opening pick under the mmWave flex cable to separate it from the logic board.
      Спросите у FixBot
    9. iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the rear camera shield: шаг 55, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Unfasten the rear camera shield: шаг 55, изображение 2 из 2
      • Some of these screws are the same length but have different thread sizes. Don't mix up the screws or you'll damage the threads in the frame.
      • Use your Phillips screwdriver to remove the six screws securing the rear camera shield to the frame:
      • Two 2.8 mm screws
      • One 1.9 mm screw
      • One 1.9 mm screw
      • One 1.2 mm screw
      • One 1.2 mm screw
      Спросите у FixBot
    10. iPad Pro 11" 3rd Gen Battery Replacement, Remove the rear camera shield: шаг 56, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the rear camera shield: шаг 56, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the rear camera shield: шаг 56, изображение 3 из 3
      • Use tweezers or your fingers to lift the right side of the camera shield up.
      • Slide the shield out horizontally.
      • During reassembly, lower the left side of the shield back into place and make sure the small protruding tab is slotted in, then hinge the shield closed.
      Спросите у FixBot
    11. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the wide angle camera cable: шаг 57, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the wide angle camera cable: шаг 57, изображение 2 из 2
      • Use the pointed end of a spudger to disconnect the wide angle camera cable.
      Спросите у FixBot
    12. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the power button and LED cable: шаг 58, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the power button and LED cable: шаг 58, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the power button and LED cable: шаг 58, изображение 3 из 3
      • Use the pointed end of a spudger to disconnect the power button and LED cable.
      Спросите у FixBot
    13. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the LiDAR sensor cable: шаг 59, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the LiDAR sensor cable: шаг 59, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the LiDAR sensor cable: шаг 59, изображение 3 из 3
      • Use the flat end of a spudger to disconnect the LiDAR sensor cable.
      • Fold the LiDAR sensor cable away from the frame to access the press connectors underneath.
      • Only fold the cable enough to access the connector underneath.
      Спросите у FixBot
    14. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the ultra wide camera cable: шаг 60, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the ultra wide camera cable: шаг 60, изображение 2 из 2
      • Use the pointed edge of a spudger to disconnect the ultra wide camera cable.
      Спросите у FixBot
    15. iPad Pro 11" 3rd Gen Battery Replacement, Remove the rear camera: шаг 61, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the rear camera: шаг 61, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the rear camera: шаг 61, изображение 3 из 3
      • Use the flat end of a spudger to gently pry up and loosen the rear camera module.
      • Use tweezers or your fingers to grab and remove the rear camera module.
      Спросите у FixBot
    1. iPad Pro 11" 3rd Gen Battery Replacement, Logic board removal information: шаг 62, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Logic board removal information: шаг 62, изображение 2 из 2
      • You're about to disconnect many connectors from the top and bottom of the logic board. During reassembly, use these photos as a reference to ensure all cables are connected in the correct locations.
      Спросите у FixBot
    2. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top right speaker cables: шаг 63, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top right speaker cables: шаг 63, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top right speaker cables: шаг 63, изображение 3 из 3
      • Use the pointed end of a spudger to disconnect the two top right speaker press connectors.
      • Don't pry against the short sides of the connector. The socket on the logic board is delicate and may break off if pried against.
      Спросите у FixBot
    3. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top left speaker cables: шаг 64, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top left speaker cables: шаг 64, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top left speaker cables: шаг 64, изображение 3 из 3
      • Repeat the previous step for the two top left speaker cables.
      Спросите у FixBot
    4. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top microphone cable: шаг 65, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top microphone cable: шаг 65, изображение 2 из 2
      • Use the pointed edge of a spudger to disconnect the top microphone cable.
      Спросите у FixBot
    5. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top right sensor cable: шаг 66, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top right sensor cable: шаг 66, изображение 2 из 2
      • Use the pointed end of a spudger to disconnect the top right sensor cable.
      Спросите у FixBot
    6. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top interconnect board: шаг 67, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top interconnect board: шаг 67, изображение 2 из 2
      • Use the pointed edge of a spudger to disconnect the top interconnect board.
      • Don't bend or reposition the interconnect board. It's stiff and will break if overbent.
      Спросите у FixBot
    7. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top left antenna cables: шаг 68, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top left antenna cables: шаг 68, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the top left antenna cables: шаг 68, изображение 3 из 3
      Спросите у FixBot
    8. iPad Pro 11" 3rd Gen Battery Replacement, Peel back the top logic board shielding: шаг 69, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Peel back the top logic board shielding: шаг 69, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Peel back the top logic board shielding: шаг 69, изображение 3 из 3
      • Use tweezers to peel back the logic board shielding tape covering the two antenna cables.
      Спросите у FixBot
    9. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the bottom right antenna cables: шаг 70, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the bottom right antenna cables: шаг 70, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the bottom right antenna cables: шаг 70, изображение 3 из 3
      • Use tweezers to disconnect the two bottom right antenna cables.
      Спросите у FixBot
    10. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect bottom interconnect board: шаг 71, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect bottom interconnect board: шаг 71, изображение 2 из 2
      • Use the pointed edge of a spudger to disconnect the bottom interconnect board.
      Спросите у FixBot
    11. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the Wi-Fi antenna coaxial cable: шаг 72, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the Wi-Fi antenna coaxial cable: шаг 72, изображение 2 из 2
      • Use tweezers to disconnect the Wi-Fi antenna coaxial cable.
      Спросите у FixBot
    12. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the Smart Connector cable: шаг 73, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the Smart Connector cable: шаг 73, изображение 2 из 2
      • Use the pointed end of a spudger to disconnect the Smart Connector cable.
      Спросите у FixBot
    13. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the bottom right speaker cables: шаг 74, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the bottom right speaker cables: шаг 74, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the bottom right speaker cables: шаг 74, изображение 3 из 3
      • Follow the procedure in step 65 to disconnect the bottom right speaker.
      Спросите у FixBot
    14. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the bottom left speaker cables: шаг 75, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the bottom left speaker cables: шаг 75, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the bottom left speaker cables: шаг 75, изображение 3 из 3
      Спросите у FixBot
    15. iPad Pro 11" 3rd Gen Battery Replacement, Reposition the bottom right 5G mmWave antenna cables: шаг 76, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Reposition the bottom right 5G mmWave antenna cables: шаг 76, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Reposition the bottom right 5G mmWave antenna cables: шаг 76, изображение 3 из 3
      • Gently pull the antenna cables away from the logic board.
      Спросите у FixBot
    16. iPad Pro 11" 3rd Gen Battery Replacement: шаг 77, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 77, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 77, изображение 3 из 3
      • Continue repositioning the antenna cables until they are clear from the bottom of the logic board.
      Спросите у FixBot
    17. iPad Pro 11" 3rd Gen Battery Replacement, Peel back the bottom logic board shielding: шаг 78, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Peel back the bottom logic board shielding: шаг 78, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Peel back the bottom logic board shielding: шаг 78, изображение 3 из 3
      • Use tweezers or your fingers to peel back the logic board shielding to reveal the hidden press connectors.
      Спросите у FixBot
    18. iPad Pro 11" 3rd Gen Battery Replacement, Remove the cable bracket: шаг 79, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the cable bracket: шаг 79, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the cable bracket: шаг 79, изображение 3 из 3
      • Use the flat end of a spudger to slide out the cable bracket.
      • Use tweezers or your fingers to remove the bracket.
      Спросите у FixBot
    19. iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the left microphone and Apple Pencil charger cables: шаг 80, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the left microphone and Apple Pencil charger cables: шаг 80, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Disconnect the left microphone and Apple Pencil charger cables: шаг 80, изображение 3 из 3
      • Use the flat end of a spudger to disconnect the left microphone and Apple Pencil charger cables.
      Спросите у FixBot
    20. iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol to the left edge of the logic board: шаг 81, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol to the left edge of the logic board: шаг 81, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol to the left edge of the logic board: шаг 81, изображение 3 из 3
      • The adhesive that secures the logic board to the frame is very strong. To remove the board, follow the next steps to weaken the adhesive using high-strength (>90%) isopropyl alcohol.
      • Elevate the left side of the iPad so that it lays down at an angle.
      • Apply a few drops of isopropyl alcohol along the left edge of the logic board.
      • Be careful if you're using a syringe with a needle or other sharp instrument to dispense isopropyl alcohol—a punctured or bent battery may leak dangerous chemicals or cause a fire.
      • Let the alcohol soak for one minute to soften the adhesive under the logic board.
      Спросите у FixBot
    21. iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol to the right edge of the logic board: шаг 82, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol to the right edge of the logic board: шаг 82, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol to the right edge of the logic board: шаг 82, изображение 3 из 3
      • Rotate your iPad 180˚ and lay it down with the right side elevated.
      • Repeat the previous step for the right edge of the logic board.
      Спросите у FixBot
    22. iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol to the right branch of the logic board: шаг 83, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol to the right branch of the logic board: шаг 83, изображение 2 из 2
      • Elevate the top side of the iPad.
      • Apply a few drops of isopropyl alcohol to the right branch of the logic board near the rear camera glass.
      • Don't allow isopropyl alcohol to contact the rear camera glass or you'll damage them.
      • Let the alcohol soak for one minute to soften the adhesive under the right logic board branch.
      Спросите у FixBot
    23. iPad Pro 11" 3rd Gen Battery Replacement, Pry up the bottom: шаг 84, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Pry up the bottom: шаг 84, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Pry up the bottom: шаг 84, изображение 3 из 3
      • Insert the flat end of a spudger under the lower edge of the logic board.
      • Don't pry against the bottom interconnect board as this will damage it.
      • Slowly lift up the bottom of the logic board.
      • If the adhesive is still too strong to lift up the logic board, apply some additional isopropyl alcohol and wait one minute.
      • Lift up the logic board and replace the playing card battery blocker with an opening pick.
      Спросите у FixBot
    24. iPad Pro 11" 3rd Gen Battery Replacement, Pry up the left side: шаг 85, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Pry up the left side: шаг 85, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Pry up the left side: шаг 85, изображение 3 из 3
      • Slide an opening pick under the left edge of the logic board to loosen it.
      • Pry against the frame underneath the logic board to separate the adhesive.
      • Don't forcefully lever against the battery—a punctured or bent battery may leak dangerous chemicals or cause a fire.
      Спросите у FixBot
    25. iPad Pro 11" 3rd Gen Battery Replacement, Pry up the top right branch: шаг 86, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Pry up the top right branch: шаг 86, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Pry up the top right branch: шаг 86, изображение 3 из 3
      • Use an opening pick to gently pry up the top right branch of the logic board near the rear camera lenses.
      Спросите у FixBot
    26. iPad Pro 11" 3rd Gen Battery Replacement, Pry up the right edge: шаг 87, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Pry up the right edge: шаг 87, изображение 2 из 2
      • Insert an opening pick under the right edge of the logic board above the left microphone and Apple Pencil charger cables.
      • Slide the opening pick under the right edge of the logic board to loosen it.
      Спросите у FixBot
    27. iPad Pro 11" 3rd Gen Battery Replacement, Remove the logic board: шаг 88, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the logic board: шаг 88, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the logic board: шаг 88, изображение 3 из 3
      • Use the flat end of a spudger to lift the top edge of the logic board.
      • Grip the top and bottom edges of the logic board.
      • Remove the logic board.
      Спросите у FixBot
    1. iPad Pro 11" 3rd Gen Battery Replacement, Battery adhesive removal information: шаг 89, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Battery adhesive removal information: шаг 89, изображение 2 из 2
      • There are 11 stretch-release adhesives that secure the battery to the frame. Each adhesive strip has a black pull tab:
      • Six on the inside edge of the left battery
      • Five on the inside edge of the right battery
      • The remainder of the adhesive is located along the bottom edge of the battery.
      • Use your fingernail or tweezers to peel each pull tab from the edge of the battery without removing them.
      • Be careful not to deform or puncture the battery—especially if you're using tweezers.
      Спросите у FixBot
    2. iPad Pro 11" 3rd Gen Battery Replacement, Remove the battery adhesive: шаг 90, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the battery adhesive: шаг 90, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Remove the battery adhesive: шаг 90, изображение 3 из 3
      • Pull the strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the battery.
      • You can use a spudger to help keep the strip flat while pulling.
      • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but don't pry under the battery.
      Спросите у FixBot
    3. iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol: шаг 91, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol: шаг 91, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Apply isopropyl alcohol: шаг 91, изображение 3 из 3
      • If you removed all of the stretch-release adhesive, good job! You can skip the next four steps. If not, then follow the next four steps to apply isopropyl alcohol.
      • Prop the left side of the iPad up against an object so the isopropyl alcohol can flow under the right battery cell.
      • Apply high-strength (>90%) isopropyl alcohol along the inside edge of the right battery cell.
      • Let the alcohol soak for two minutes to soften the adhesive under the battery cell.
      Спросите у FixBot
    4. iPad Pro 11" 3rd Gen Battery Replacement: шаг 92, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 92, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 92, изображение 3 из 3
      • Rotate the iPad 180 degrees so the inner edge of the left battery is facing up.
      • Repeat the previous step on the left battery cell.
      Спросите у FixBot
    5. iPad Pro 11" 3rd Gen Battery Replacement, Separate the battery adhesive: шаг 93, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the battery adhesive: шаг 93, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement, Separate the battery adhesive: шаг 93, изображение 3 из 3
      Plastic Cards
      $2.99
      • Lay the iPad down flat on your work surface.
      • Starting at the top, insert a plastic card under the right battery cell.
      • Slide the plastic card toward the bottom of the iPad to separate the adhesive.
      • Stop sliding when you reach the Apple Pencil charger cable.
      • Don't force the card or bend the battery. If it's difficult to insert or slide the card, apply more isopropyl alcohol.
      Спросите у FixBot
    6. iPad Pro 11" 3rd Gen Battery Replacement: шаг 94, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 94, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 94, изображение 3 из 3
      Спросите у FixBot
    7. iPad Pro 11" 3rd Gen Battery Replacement: шаг 95, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 95, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 95, изображение 3 из 3
      • Don't try to remove the battery yet – the battery boards are still held in place with adhesive.
      • Lift up the left battery cell.
      • Insert an opening pick under the left battery board and separate the remaining adhesive securing it to the frame.
      • If the adhesive does not separate easily, apply some high-strength (>90%) isopropyl alcohol and wait one minute.
      Спросите у FixBot
    8. iPad Pro 11" 3rd Gen Battery Replacement: шаг 96, изображение 1 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 96, изображение 2 из 3 iPad Pro 11" 3rd Gen Battery Replacement: шаг 96, изображение 3 из 3
      • Repeat the previous step for the right battery cell.
      Спросите у FixBot
    9. iPad Pro 11" 3rd Gen Battery Replacement, Remove the battery: шаг 97, изображение 1 из 2 iPad Pro 11" 3rd Gen Battery Replacement, Remove the battery: шаг 97, изображение 2 из 2
      Tesa 61395 Tape
      $25.95
      • Lift both halves of the battery out of the iPad at the same time.
      • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
      • Remove the old battery adhesive from the frame using tweezers and high-strength (>90%) isopropyl alcohol with a lint-free cloth where needed.
      • If your battery doesn't come with preinstalled adhesive, use Tesa tape to reattach the battery to the rear case.
      Спросите у FixBot
Заключение
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Pro 11" 3rd Gen Answers community for help.
9 человек успешно провели ремонт по этому руководству.
Chayton Ritter
Участник с: 08/21/20
27 165 Репутация
Автор 105 руководств
Команда
Guide Team Участник Guide Team
Staff
10 членов
Автор 35 704 руководств
2 Комментарии к руководству
Do I have to remove the logic and all those components to change the battery. I was thinking just lift it a little and pry the battery out with isopropyl alcohol
CHIMEZIE UKONU - Ответить Поделиться
Hi CHIMEZIE,
Unfortunately you have to do quite a bit of disassembly because the two battery cells are connected by a ribbon cable that is beneath the logic board.
Chayton Ritter - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 30
За последние 7 дней: 228
За последние 30 дней: 1,101
За всё время: 30,758
