Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Google Pixel 3a Earpiece Speaker Replacement
Arthur Shi
Arthur Shi и 3 другие участники
Последнее обновление November 14, 2022
20 - 40 минут
Средне
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to remove and replace a broken earpiece speaker for the Pixel 3a.
The procedure is similar for the Pixel 3a XL except this step, where the microphone contacts are on the left instead of the right. If you’re working on the Pixel 3a XL, follow our Pixel 3a XL guides for disassembly.
The Pixel 3a’s unreinforced display panel is fragile. If you are reusing the screen, be sure to pay special attention to the warnings in the opening procedure.
The trickiest part of the procedure is re-attaching the light sensor, which requires some patience and finesse.
Выберете то, что вам нужно
Инструменты
Показать больше…
  1. Google Pixel 3a Earpiece Speaker Replacement, Screen: шаг 1, изображение 1 из 3 Google Pixel 3a Earpiece Speaker Replacement, Screen: шаг 1, изображение 2 из 3 Google Pixel 3a Earpiece Speaker Replacement, Screen: шаг 1, изображение 3 из 3
    • Take note of the two seams on the phone:
    • Screen seam: This seam separates the screen from the rest of the phone. This is where you should pry.
    • Frame seam: This is where the plastic frame meets the back cover. It is held in place by screws. Do not pry at this seam.
    • Before you begin prying, note the following areas on the screen:
    • Screen flex cable: Do not pry deeper than instructed, or you risk damaging this cable.
    • Adhesive perimeter: Prying beyond the narrow perimeter without angling the pick will damage the display panel.
  2. Google Pixel 3a Earpiece Speaker Replacement: шаг 2, изображение 1 из 1
    • Heat an iOpener and apply it to the right edge of the display for a minute.
    • You can choose to skip this step since the Pixel 3a's screen adhesive is not very strong. Heating it, however, will decrease the chance of cracking the screen.
  3. Google Pixel 3a Earpiece Speaker Replacement: шаг 3, изображение 1 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 3, изображение 2 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 3, изображение 3 из 3
    • Place a suction cup near the right edge of the screen.
    • Pull on the suction cup with strong steady force.
    • Insert the pick into the gap, no more than 1 mm.
  4. Google Pixel 3a Earpiece Speaker Replacement: шаг 4, изображение 1 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 4, изображение 2 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 4, изображение 3 из 3
    • This step shows how to insert the pick without damaging the OLED panel. Do this before you slice either long edges of the phone.
    • With the pick 1 mm in the gap, pivot the pick upwards to a steep angle.
    • At this angle, carefully push the pick into the gap about 1/4" (6 mm). The pick should slide in below the OLED panel.
    • Stop if you feel the point of the pick hitting a ridge. The pick may be pressing against the edge of the OLED panel. Angle the pick and try again.
  5. Google Pixel 3a Earpiece Speaker Replacement: шаг 5, изображение 1 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 5, изображение 2 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 5, изображение 3 из 3
    • Slide the pick along the right edge, slicing through the adhesive.
    • Do not insert the pick more than 1/4" (6 mm), or you may damage the screen's flex cable.
    • Leave a pick in place to prevent the adhesive from resealing.
  6. Google Pixel 3a Earpiece Speaker Replacement: шаг 6, изображение 1 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 6, изображение 2 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 6, изображение 3 из 3
    • As you slice around the bottom edge of the phone, do not insert the pick more than 1/4" (6 mm).
    • Slide the pick around the bottom right corner to slice through the adhesive.
    • If the corner feels hard to slice, apply a heated iOpener to the corner for a minute and try again.
    • Continue slicing along the bottom edge of the phone and around the left corner.
  7. Google Pixel 3a Earpiece Speaker Replacement: шаг 7, изображение 1 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 7, изображение 2 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 7, изображение 3 из 3
    • Slice through the left edge of the phone, making sure to properly angle the pick below the OLED panel and insert it in no more than 1/4" (6 mm).
    • To angle the pick below the OLED panel, insert the point of the pick no more than 1 mm in, angle the pick upwards, and then slowly push the pick in 1/4".
  8. Google Pixel 3a Earpiece Speaker Replacement: шаг 8, изображение 1 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 8, изображение 2 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 8, изображение 3 из 3
    • Slice along the top edge while keeping the pick no more than 5/16" (8 mm) in.
  9. Google Pixel 3a Earpiece Speaker Replacement: шаг 9, изображение 1 из 2 Google Pixel 3a Earpiece Speaker Replacement: шаг 9, изображение 2 из 2
    • With all of the edges cut, carefully hinge open the right edge of the screen.
    • Do not remove the screen. It is still attached to the phone by a flex cable near the left edge.
    • Use an opening pick to carefully cut through any remaining adhesive.
  10. Google Pixel 3a Earpiece Speaker Replacement: шаг 10, изображение 1 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 10, изображение 2 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 10, изображение 3 из 3
    • With all of the adhesives cut, flip the attached screen glass side down and rest it on top of the phone. The screen flex cable should be loosely arched.
  11. Google Pixel 3a Earpiece Speaker Replacement: шаг 11, изображение 1 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 11, изображение 2 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 11, изображение 3 из 3
    • Carefully peel the black tape covering the screen connector bracket.
    • If it is in good condition, you can re-use this tape during reassembly. Otherwise, replace it with a piece of electrical tape.
    • Remove the two 4.4 mm long T3 screws securing the screen connector bracket.
    • Remove the screen connector bracket.
  12. Google Pixel 3a Earpiece Speaker Replacement: шаг 12, изображение 1 из 2 Google Pixel 3a Earpiece Speaker Replacement: шаг 12, изображение 2 из 2
    • Use the point of a spudger to pry up and disconnect the screen flex cable.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. Google Pixel 3a Earpiece Speaker Replacement: шаг 13, изображение 1 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 13, изображение 2 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 13, изображение 3 из 3
    • Remove the screen.
    • Carefully compare your replacement screen with your original part. You may need to transfer additional components (such as the speaker mesh) to the new part.
    • To reinstall the screen:
    • Follow this guide if you are using custom-cut adhesives.
    • If you are using double-sided tape such as Tesa tape, follow this guide.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
  14. Google Pixel 3a Earpiece Speaker Replacement, Plastic Midframe: шаг 14, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    • Remove the fourteen T3 screws of the following lengths securing the plastic midframe:
    • Twelve 4.3 mm silver T3 screws
    • Two 4.3 mm black T3 screws
  15. Google Pixel 3a Earpiece Speaker Replacement: шаг 15, изображение 1 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 15, изображение 2 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 15, изображение 3 из 3
    • The midframe is still held in place by plastic clips.
    • Insert an opening pick into frame seam at the bottom of the phone. This seam sits between the plastic midframe and the back cover.
    • Slide the pick along the seam to release the clips holding the plastic midframe.
  16. Google Pixel 3a Earpiece Speaker Replacement: шаг 16, изображение 1 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 16, изображение 2 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 16, изображение 3 из 3
    • Slide the opening pick along the left and right edges of the phone to release the midframe clips.
    • Lift the bottom edge of the plastic midframe up but do not remove the midframe. The midframe is still tethered to the phone by the fragile proximity sensor cable at the top edge.
    • To reinstall the plastic midframe, align the midframe to the back cover, and squeeze the perimeter of the phone with your fingers to snap the clips back into position.
  17. Google Pixel 3a Earpiece Speaker Replacement: шаг 17, изображение 1 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 17, изображение 2 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 17, изображение 3 из 3
    • Use the point of a spudger to carefully pry up and disconnect the proximity sensor connector from the motherboard.
    • Your proximity sensor connector may have automatically disconnected itself when you lifted the midframe.
    • Remove the plastic midframe.
  18. Google Pixel 3a Earpiece Speaker Replacement: шаг 18, изображение 1 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 18, изображение 2 из 3 Google Pixel 3a Earpiece Speaker Replacement: шаг 18, изображение 3 из 3
    • This step shows how to reconnect the proximity sensor during re-assembly.
    • Align the top edge of the plastic midframe with the phone.
    • Use the point of a spudger to carefully align and push the proximity sensor connector onto the motherboard socket.
    • This takes a bit of patience and finesse. Once you have the connector in place, you can also use a finger to gently press the connector onto the socket.
    • Alternatively, you can remove the proximity sensor from the midframe to reattach it to the motherboard first.
    • Use the point of a spudger to carefully pry the proximity sensor out of its recess on the midframe. The sensor is lightly adhered to the midframe.
    • Remove the sensor from the midframe. Attach the sensor connector onto its motherboard socket.
    • Thread the sensor cable through the midframe and reposition the sensor in the recess. Press down with your finger to adhere the sensor back onto the midframe.
  19. Google Pixel 3a Earpiece Speaker Replacement, Earpiece Speaker: шаг 19, изображение 1 из 2 Google Pixel 3a Earpiece Speaker Replacement, Earpiece Speaker: шаг 19, изображение 2 из 2
    • Insert the point of a spudger into one of the four small notches below the earpiece speaker's metal plate.
    • Pry up to release the earpiece module from its recess.
  20. Google Pixel 3a Earpiece Speaker Replacement: шаг 20, изображение 1 из 1
    • Remove the earpiece speaker.
    • When installing a replacement earpiece speaker, be sure that it is properly oriented. The two gold contact springs should be facing up, on same side of the midframe as the copper shield (the right side of this step's photo).
Заключение
Repair didn’t go as planned? Check out our Google Pixel 3a Answers community for troubleshooting help.
5 человек успешно провели ремонт по этому руководству.
Arthur Shi
Участник с: 01/03/18
283 296 Репутация
Автор 587 руководств
Команду
iFixit Участник iFixit
Staff
118 членов
Автор 19 632 руководств
5Комментарии к руководству
Just to report back on this guide, my Pixel 3a XL actually has the gold contacts for the earphone on the opposite side than shown here. Looks to be the reason for it to not work in the first place. Unfortunately I damaged my screen during the repair by pressing too far into the bottom ribbon connector, splitting it, or damaging it in some way it will not function anymore. Just flickers.
Thanks for the guide!
Miguel Higgins-Moy - Ответить
Same problem in my case. I cracked the screen while trying to remove old adhesive one the edges.
Eugeniu Plamadeala -
Same issue on my 3aXL- was confused by this guide as a result, had to take my phone apart a few times for testing before I figured out the problem- I was about to order another replacement speaker.
Overall, great guide- a small note for 3a XL owners would be very helpful! Had i not followed the guide on that one step I’d be 45 minutes ahead haha
Mike Walko -
Thanks for the feedback! Yes, the earpiece contacts for the 3a XL is indeed on the left instead of the right. I’ll add a note in the intro to highlight that.
Arthur Shi -
Hallo, kann mir vielleicht jemand sagen wie die Staub Abdeckung oben beim Display heißt ? Oder als Ersatzteil zu finden ist ?
Vielen Dank
Hansjoerg Hofer - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 7
За последние 30 дней: 51
За всё время: 7,178
