Введение
Use this guide to remove or replace the front shell (front cover) on a Steam Deck LCD.
Remember: follow general electrostatic discharge (ESD) safety procedures while repairing your device.
This procedure involves almost a complete disassembly, including removing the display! Know what you're getting yourself into. You'll need replacement adhesives for the display and speakers.
Выберете то, что вам нужно
Power down your Steam Deck and unplug any cables.
Инструмент, используемый на этом этапе:FixMat$36.95
Use a Phillips driver to remove the eight screws securing the back cover:
Four coarse thread 9.5 mm-long screws
Four fine thread 5.8 mm-long screws
Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
Pry up on the back cover to release it from the locking clips.
Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
Remove the back cover.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
Use a Phillips driver to remove the three screws securing the board shield:
One 3.4 mm screw
Two 3.7 mm screws
Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
Place the flat end of a spudger onto the inside edge of the trigger's left clip.
Pivot the trigger clip out, away, and up from the peg to unlatch it.
Use a Phillips driver to remove the three 5.2 mm screws securing the left trigger bracket.
Use the pointed end of a spudger to lift up the small locking flap on the thumbstick cable's ZIF connector.
Use a pair of tweezers to slide the cable out of its connector.
Use a Phillips driver to remove the three 5.2 mm screws securing the thumbstick.
Use the pointed end of a spudger to lift up the small locking flap on the button board interconnect cable's ZIF connector.
If any connectors are covered with tape, use a pair of tweezers to remove it.
Use the pointed end of a spudger to lift up the small locking flaps on the rest of the button board ZIF connectors. Use a pair of tweezers to slide the cables out of their connectors:
Disconnect the D-pad cable.
Disconnect the touchpad board cable.
Disconnect the touchpad cable.
Use the pointed end of a spudger to lift up on the haptics cable to disconnect it.
Use a Phillips driver to disconnect the four screws securing the left button board:
Three 5.2 mm screws
One 3.9 mm screw
Use a Phillips driver to remove the four 4.7 mm screws securing the touchpad board.
Use a Phillips driver to remove the four 4.7 mm screws securing the touchpad.
From the front of the Steam Deck, use your finger to push the left touchpad partway through the front shell to unseat it.
Lift the touchpad out from underneath the overhanging section of the midframe.
Remove the touchpad.
Place the flat end of a spudger onto the inside edge of the trigger's right clip.
Use a Phillips driver to remove the three 5.2 mm screws securing the right trigger bracket.
Use the pointed end of a spudger to lift up the small locking flap on the button board cable's ZIF connector.
Disconnect the action buttons cable.
Use a Phillips driver to disconnect the four screws securing the right button board:
Three 5.2 mm screws
One 3.9 mm screw
From the front of the Steam Deck, use your finger to push the right touchpad partway through the front shell to unseat it.
Use a pair of tweezers to remove the quick access button membrane.
Use a pair of tweezers to remove the quick access button.
Use a pair of tweezers to remove the Steam button membrane.
Use a Phillips driver to remove the 3.4 mm screw securing the SSD.
Grip the end of the SSD and pull it away from its M.2 board connector to remove it.
Use a pair of tweezers to remove the sticker from the top edge of the fan.
Use a Phillips driver to loosen and remove the two screws securing the heatsink to the motherboard:
One captive 3.5 mm screw
One 3.4 mm screw
Use a pair of tweezers to grip the edges of the fan connector and pull up to disconnect it from the motherboard.
Use a Phillips driver to remove the two 3.7 mm screws securing the fan.
Use a pair of tweezers to grip the edges of the speaker connector and pull up to disconnect it from the motherboard.
Use a pair of tweezers to peel up and remove the Wi-Fi shield tape.
Use a pair of tweezers to grip the antenna connector close to its base.
Pull straight up to disconnect the cable.
Repeat for the second antenna cable.
Use the pointed end of a spudger to lift up the small locking flap on the display cable's ZIF connector.
Use the pointed end of a spudger to lift up the small locking flap on the audio cable's ZIF connector.
Carefully peel the audio cable off of the battery.
If the adhesive is stubborn, don't force the cable. Lightly heat the audio cable using an iOpener or a hair dryer to soften the adhesive.
Use a Phillips driver to remove the three 3.7 mm screws securing the motherboard.
Use the pointed end of a spudger to lift up on the mic cable's white locking tab.
Use a pair of tweezers to pull the mic cable up and out of its connector.
Use a Phillips driver to remove the two 3.7 mm screws securing the audio board.
Use a pair of tweezers to grip the audio board by the headphone jack.
Pivot the board up and out of its recess to remove it.
Use a pair of tweezers to peel up the tape bundling the speaker wire to the Wi-Fi antenna cables.
Use a pair of tweezers to peel up the various strips of black tape routing the speaker wire along the bottom edge of the chassis.
Insert the flat end of a spudger between the right speaker and the frame.
Pivot the spudger up to separate the speaker from the light adhesive securing it against the front shell.
Insert the flat end of a spudger between the left speaker and the frame.
Use a pair of tweezers to peel back the sticker covering the display connector.
Prepare an iOpener and apply it to the top edge of the display for one minute.
Apply a suction cup to the top left corner of the display by pressing down on it to create suction, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the display and the frame.
Insert the point of an opening pick into the gap.
Slide the opening pick no more than 3 mm deep across the top edge to slice the adhesive.
Slide the opening pick down the right edge to slice the adhesive.
Slide the opening pick across the bottom edge to slice the adhesive.
Heat the left edge of the display for one minute.
Slide the opening pick across the left edge to slice the adhesive.
Once you have sliced around the perimeter of the display, carefully lift the right edge up, opening it like a book.
Remove the display.
Use a Phillips driver to remove the two 5.2 mm screws securing the left bumper assembly.
Use a Phillips driver to remove the two 5.2 mm screws securing the right bumper assembly.
Use a pair of tweezers to remove the action buttons membrane.
Use a pair of tweezers to remove the four action buttons, A, B, X, and Y.
Use a Phillips driver to remove the six 2.3 mm screws securing the midframe to the front shell, located on the front side.
Use a Phillips driver to remove the four 5.2 mm screws securing the midframe to the front shell.
Use the pointed end of a spudger to lift the rubber flap to the left of the volume buttons up and out of its plastic clip.
Use a pair of tweezers to remove the volume buttons by pulling them up and away from the front shell.
Use the pointed end of a spudger to lift the rubber flap to the right of the power button up and out of its plastic clip.
Use the pointed end of a spudger to lift the rubber flap to the left of the power button up and out of its plastic clip.
Remove the power button.
Insert the flat end of a spudger under the left end of the mic cable and pry upwards to peel it up from the front shell.
If the adhesive is stubborn, don't force the cable. Lightly heat the mic cable using an iOpener or a hair dryer to soften the adhesive.
Insert the flat end of a spudger under the right end of the mic cable and pry upwards to peel it up from the front shell.
Remove the mic cable from the front shell.
Only the front shell remains.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
24 человек успешно провели ремонт по этому руководству.
20 Комментарии к руководству
maybe I don’t need an Atomic Purple replacement shell…
Hahaha. Same
Same, wouldn't have minded a sweet water dipped or translucent outer shell. Bring back that mad catz/third party aesthetic.
I wanted to replace my old shell with a new one cause it got scratches... well, now I feel the scratches ain't that ugly.
Seems to me like a "Welp...I guess if I ever break the screen and have to replace it, that's when I'll get an atomic purple shell...
