Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
What Should I replace on my IPad?
Hi, I’m relatively new to the realm of Ifixit and am not sure what to replace on my IPad Air. The screen is moderately cracked but ghosting occurs and some areas of the screen do not respond to touch. Should I replace the LCD along with the front panel?
Thanks.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (2)
Выбранное решение
You’ll need to replace the front panel. The LCD is OK as long as it still shows display and no horizontal or vertical lines.
Before installing the new front panel you’ll need to bend back that top right corner so that it sits in properly.
iPad Air LTE Front Panel Assembly Replacement
iPad Air Screen Digitizer
Replace a front panel assembly compatible with iPad Air. Assembly includes the glass touch panel (digitizer), blank home button, camera bezel, and adhesive. Изображение
Продукт
$39.99
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
Also, once I remove the front panel, do you think I’d be a good idea to clean the LCD? If so how?
из
Ok. First of all, this is extremely hard to do. You need to invest in the right tools and other things. Next, iPads are WAY more fragile than iPhones. One wrong move and no more iPad. It would be a little bit more expensive taking it to apple, but there would be NO risk. That’s what I recommend.
Оценка 0
4 Комментариев:
Well, I'd rather attempt to fix it for $50 rather than pay $249 for Apple to do it.
из
@jflys5000 Hey Jackson! I've looked at all your answers. Please just stop, you're helping no one.
из
Look @mayer idc. I’m just throwing out suggestions. Why do u gotta be all up in my business? Jeez dood. Go away.
из
@ronald you could loose your $500 iPad. Your call tho.
из
Добавьте свой ответ
Ronald будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 113
