Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
iPhone 11 Rear-Facing Cameras Replacement
Jeff Suovanen
Jeff Suovanen и 6 другие участники
Последнее обновление July 10, 2024
1 - 2 часы
Средне
Use this guide to remove and replace the rear cameras in the iPhone 11. The rear camera assembly consists of one wide-angle module and one ultra-wide angle module. Both are replaced together, as a single unit.
Note: This guide instructs you to completely detach the display cables and remove the display assembly in order to better access the rear cameras—however, it's possible to remove and replace the rear cameras with the display cables still connected. Advanced readers may skip disconnecting the display in order to save time, as long as the display is properly supported and the display cables are not damaged.
Выберете то, что вам нужно
Запчасти
Инструменты
Показать больше…
  1. iPhone 11 Rear-Facing Cameras Replacement, Remove the pentalobe screws: шаг 1, изображение 1 из 2 iPhone 11 Rear-Facing Cameras Replacement, Remove the pentalobe screws: шаг 1, изображение 2 из 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    the right screws wouldn’t come off
    Yusef San Inocencio - Ответить
    ok one came of but my right wont come of either!!!!
    Aisa Jawara -
    Hello guys, I still haven't found away to power off the iphone without using the screen. Cheers!
    danielaguirre93 - Ответить
    You can try this.
    Quickly Press and release the volume up button.
    then Quickly Press and release the volume down button.
    then press and hold the power button and wait until it turns off.
    worked for me :D
    Benóný Egilson - Ответить
    Where does one get replacement seals? Is this the same as the display assembly adhesive?
    Brian Baker - Ответить
    not of the screwdrivers i have seem to be able to turn the screws
    Aisa Jawara - Ответить
    how do you change battery of an iPhone 11 and still the battery health shows, do you use a software for that?
    Great Me - Ответить
    Battery health won’t show on a non Apple battery.
    DON’T forget to discharge old battery before removing it. Very impressive fire (and smoke!) if you puncture it. Ask me how I know
    Doug Harrowing - Ответить
  2. iPhone 11 Rear-Facing Cameras Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 11 Rear-Facing Cameras Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 11 Rear-Facing Cameras Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - Ответить
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - Ответить
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - Ответить
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - Ответить
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - Ответить
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - Ответить
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - Ответить
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - Ответить
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - Ответить
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - Ответить
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - Ответить
  3. iPhone 11 Rear-Facing Cameras Replacement, Tape over any cracks: шаг 3, изображение 1 из 3 iPhone 11 Rear-Facing Cameras Replacement, Tape over any cracks: шаг 3, изображение 2 из 3 iPhone 11 Rear-Facing Cameras Replacement, Tape over any cracks: шаг 3, изображение 3 из 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 11 Rear-Facing Cameras Replacement, Anti-Clamp instructions: шаг 4, изображение 1 из 3 iPhone 11 Rear-Facing Cameras Replacement, Anti-Clamp instructions: шаг 4, изображение 2 из 3 iPhone 11 Rear-Facing Cameras Replacement, Anti-Clamp instructions: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the top, and one on the bottom.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 11 Rear-Facing Cameras Replacement: шаг 5, изображение 1 из 3 iPhone 11 Rear-Facing Cameras Replacement: шаг 5, изображение 2 из 3 iPhone 11 Rear-Facing Cameras Replacement: шаг 5, изображение 3 из 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 11 Rear-Facing Cameras Replacement: шаг 6, изображение 1 из 3 iPhone 11 Rear-Facing Cameras Replacement: шаг 6, изображение 2 из 3 iPhone 11 Rear-Facing Cameras Replacement: шаг 6, изображение 3 из 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Any suggestions if the screen is broken and the anti-clamp just separates the screen from the bezel?
    Nathan Friedly - Ответить
  7. iPhone 11 Rear-Facing Cameras Replacement, Heat the lower edge of the phone: шаг 7, изображение 1 из 1
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute.
    어짜피 못쓰고 버릴 거라면, 이것보다 인두기를 직접 대는 방식을 추천 합니다. 어짜피 유리라 연기나 반응도 없고 무엇보다 금방 열기가 올라와요.
    코딩의달인 - Ответить
    Gut gehen auch Kirschkernsäckchen. Damit hatte ich Erfolg!
    Hoetgen - Ответить
  8. iPhone 11 Rear-Facing Cameras Replacement: шаг 8, изображение 1 из 2 iPhone 11 Rear-Facing Cameras Replacement: шаг 8, изображение 2 из 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  9. iPhone 11 Rear-Facing Cameras Replacement, Lift the display slightly: шаг 9, изображение 1 из 3 iPhone 11 Rear-Facing Cameras Replacement, Lift the display slightly: шаг 9, изображение 2 из 3 iPhone 11 Rear-Facing Cameras Replacement, Lift the display slightly: шаг 9, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap under the screen and the plastic bezelnot the screen itself.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    This turned out to be the most difficult part for me. My old ifixit suction cup didn't suck hard enough to generate enough force to pry the display from the case. I ended up applying heat at least a dozen times, and I had to pull up on the suction cup forcefully over and over and over while repositioning it several times. I finally had success inserting my pick into the tiny gap after 30 or so rapid tugs on the suction cup.
    matthew r - Ответить
    I pulled the screen by accident instead of the bottom layer, now what?
    Alvaro - Ответить
    I have the same question
    Konstantinos Solakoglou -
    After heating (I used a hair dryer for 4-5 mins, moving around whole frame, to make sure was pretty hot, then let sit for 1 minute), insert a razor blade between the bezel and the frame, at the bottom edge. Lever upwards, the screen will easily pull away. You won’t even need the suction cup.
    Damian - Ответить
  10. iPhone 11 Rear-Facing Cameras Replacement, Separate the screen adhesive: шаг 10, изображение 1 из 3 iPhone 11 Rear-Facing Cameras Replacement, Separate the screen adhesive: шаг 10, изображение 2 из 3 iPhone 11 Rear-Facing Cameras Replacement, Separate the screen adhesive: шаг 10, изображение 3 из 3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  11. iPhone 11 Rear-Facing Cameras Replacement, Screen information: шаг 11, изображение 1 из 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  12. iPhone 11 Rear-Facing Cameras Replacement: шаг 12, изображение 1 из 3 iPhone 11 Rear-Facing Cameras Replacement: шаг 12, изображение 2 из 3 iPhone 11 Rear-Facing Cameras Replacement: шаг 12, изображение 3 из 3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    Instructions are confusing as the last step says not to insert at certain points, while this says to slide all the way up the right side - is it that sliding is ok but inserting isn't (whatever that might mean) or just not more than 3mm?
    Peter Hill - Ответить
    Just slide slightly and the display will rise without problems on all iPhone models, sometimes if I have long nails I even insert a fingernail and lift the display.
    Tonynox -
  13. iPhone 11 Rear-Facing Cameras Replacement: шаг 13, изображение 1 из 3 iPhone 11 Rear-Facing Cameras Replacement: шаг 13, изображение 2 из 3 iPhone 11 Rear-Facing Cameras Replacement: шаг 13, изображение 3 из 3
    • The top edge of the display is secured with both glue and clips.
    • Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
    • Insert your pick into the top-right corner of the phone.
  14. iPhone 11 Rear-Facing Cameras Replacement: шаг 14, изображение 1 из 2 iPhone 11 Rear-Facing Cameras Replacement: шаг 14, изображение 2 из 2
    • Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
    • Slide the pick to the top left corner and cut any remaining adhesive securing the display.
    • Don't insert your pick more than 3 mm, as you may damage the Face ID sensor array.
  15. iPhone 11 Rear-Facing Cameras Replacement, Remove the suction cup: шаг 15, изображение 1 из 1
    • Pull the small nub on the suction cup to detach it from the front panel.
  16. iPhone 11 Rear-Facing Cameras Replacement, Open the iPhone: шаг 16, изображение 1 из 3 iPhone 11 Rear-Facing Cameras Replacement, Open the iPhone: шаг 16, изображение 2 из 3 iPhone 11 Rear-Facing Cameras Replacement, Open the iPhone: шаг 16, изображение 3 из 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Prop the display up against something sturdy.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  17. iPhone 11 Rear-Facing Cameras Replacement, Display Assembly: шаг 17, изображение 1 из 2 iPhone 11 Rear-Facing Cameras Replacement, Display Assembly: шаг 17, изображение 2 из 2
    • To access the screws in the following step, tilt the display by slightly lifting its lower edge.
    • Be careful not to strain or tear the display cables.
  18. iPhone 11 Rear-Facing Cameras Replacement, Unscrew the battery connector cover: шаг 18, изображение 1 из 2 iPhone 11 Rear-Facing Cameras Replacement, Unscrew the battery connector cover: шаг 18, изображение 2 из 2
    Magnetic Project Mat
    $19.95
    • Use a Y000 driver to remove the three 1.1 mm-long screws securing the battery connector bracket.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    During reassembly, I had to connect my phone to the charger before it would power up.
    Austin Culberson - Ответить
    Die Schrauben sind wahnsinnig kurz, tatsächlich winzig klein. Nach dem Herausdrehen könnte es im ersten Moment so aussehen, als habe man die Schrauben ausgebohrt anstatt herauszudrehen, sie sind jedoch sehr schnell gelöst und liegen dann entweder im Gehäuse oder sind neben dem Gehäuse herausgefallen. In jedem Fall sollten sie nie auf den Boden fallen, da sie dann kaum mehr auffindbar wären.
    Bernd Sonneck - Ответить
    I got to this point thinking/hoping I could eek by with a Y1 orY0 or even a PH000 driver but no such luck. The Y000 is in fact necessary. Finishing this repair will have to wait for now.
    ALSO thanks Apple, there is ABSOLUTELY no reason AT. ALL. to use so many random, oddball screw heads, BUT to make self repairs more difficult and expensive. A real F-U to the consumer!
    John M - Ответить
  19. iPhone 11 Rear-Facing Cameras Replacement, Remove the battery connector cover: шаг 19, изображение 1 из 1
    • Remove the bracket.
  20. iPhone 11 Rear-Facing Cameras Replacement, Disconnect the battery: шаг 20, изображение 1 из 2 iPhone 11 Rear-Facing Cameras Replacement, Disconnect the battery: шаг 20, изображение 2 из 2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally contacting the socket.
  21. iPhone 11 Rear-Facing Cameras Replacement, Unscrew the logic board cover screws: шаг 21, изображение 1 из 2 iPhone 11 Rear-Facing Cameras Replacement, Unscrew the logic board cover screws: шаг 21, изображение 2 из 2
    • Use a Y000 driver to remove the five 1.1 mm screws securing the logic board cover bracket.
  22. iPhone 11 Rear-Facing Cameras Replacement, Remove the logic board cover bracket: шаг 22, изображение 1 из 1
  23. iPhone 11 Rear-Facing Cameras Replacement, Disconnect the display: шаг 23, изображение 1 из 3 iPhone 11 Rear-Facing Cameras Replacement, Disconnect the display: шаг 23, изображение 2 из 3 iPhone 11 Rear-Facing Cameras Replacement, Disconnect the display: шаг 23, изображение 3 из 3
    • Use a spudger or a fingernail to disconnect the LCD panel cable connector.
    • Disconnect the digitizer connector next to it.
    Be mindful when reconnecting LCD panel connector and digitizer connector. It’s looks very similar. These 2 ribbon connectors a slightly different.
    Pay attention.
    Josmaknolavic - Ответить
    내 아이폰이 디스플레이 분리 단계를 거친 후, 전원이 들어오지 않습니다. 층전기를 꽂아도 배터리에 미세한 전기 반응이 느껴지지 않고, 탭틱 엔진도 작동하지 않게 되었습니다. cpu 온도는 여전히 뜨껍습니다. 내 마더보드가 디스플레이 분리 후 갑자기 고장난건가요?
    Protoncal - Ответить
    Hast Du das Problem gelöst?
    Bernd Sonneck -
    커넥터 핀을 빼거나 다시 넣기 위해 구부러졌을 수 있습니다. 핀이 구부러진 경우 돋보기 등으로 살펴보고, 그렇다면 적절한 매장에 가져가세요.
    Hampter -
    Hier war mein Problem schon gelöst. Durch einen Sturz hat sich der Touchscreen Stecker gelöst. Wieder eingesteckt funktionierte die Touch-Eingabe wieder.
    Hoetgen - Ответить
  24. iPhone 11 Rear-Facing Cameras Replacement, Disconnect the front sensors: шаг 24, изображение 1 из 2 iPhone 11 Rear-Facing Cameras Replacement, Disconnect the front sensors: шаг 24, изображение 2 из 2
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
    There needs to be an extra step between 24 and 25 for reassembly, telling folks to apply adhesive here. I got the thing almost all the way put back together before realizing that the adhesive was a single piece that needs the cables to be disconnected in order to apply it.
  25. iPhone 11 Rear-Facing Cameras Replacement, Remove the display assembly: шаг 25, изображение 1 из 1
    After this step its probably a good idea to test the new screen (you dont have to plug in the front camera assembly)
    Richard Kraus - Ответить
    Not a technician, so correct me if I'm wrong: I think that it's at this step of reassembly (before you reattach the screen) that you apply waterproof glue, if you have it.
    Athanasius Pernath - Ответить
    You are both correct. Testing the screen before putting on adhesive means the screen can be returned if faulty. Many places will not accept a screen return that has adhesive on it.
    So if it works apply adhesive at this point. When testing don’t just rely on Apple logo test touch functionality also .
    Daniel - Ответить
  26. iPhone 11 Rear-Facing Cameras Replacement, Unscrew the rear camera cover: шаг 26, изображение 1 из 2 iPhone 11 Rear-Facing Cameras Replacement, Unscrew the rear camera cover: шаг 26, изображение 2 из 2
    • Remove the two Phillips screws securing the rear camera cover:
    • One 1.4 mm screw
    • One 1.3 mm screw
  27. iPhone 11 Rear-Facing Cameras Replacement, Remove the camera cover: шаг 27, изображение 1 из 3 iPhone 11 Rear-Facing Cameras Replacement, Remove the camera cover: шаг 27, изображение 2 из 3 iPhone 11 Rear-Facing Cameras Replacement, Remove the camera cover: шаг 27, изображение 3 из 3
    • Lift the camera cover from the edge closest to the battery, and remove it.
    • To reinstall the camera cover, follow the images exactly in reverse: first, lower the outside edge until the two protruding tabs on the cover are slotted securely into the bracket on the outer edge of the camera module. Then, hinge the cover closed.
    • The cover only lays flat after the two tabs are seated correctly.
  28. iPhone 11 Rear-Facing Cameras Replacement, Disconnect the cameras: шаг 28, изображение 1 из 3 iPhone 11 Rear-Facing Cameras Replacement, Disconnect the cameras: шаг 28, изображение 2 из 3 iPhone 11 Rear-Facing Cameras Replacement, Disconnect the cameras: шаг 28, изображение 3 из 3
    • Use a spudger or a fingernail to disconnect the two camera cable connectors by prying them straight up from their sockets.
  29. iPhone 11 Rear-Facing Cameras Replacement, Loosen the camera assembly: шаг 29, изображение 1 из 2 iPhone 11 Rear-Facing Cameras Replacement, Loosen the camera assembly: шаг 29, изображение 2 из 2
    • Insert the point of a spudger at the bottom right corner of the camera, between the camera assembly and the iPhone's frame.
    • Gently pry up to lever the camera out of the iPhone.
  30. iPhone 11 Rear-Facing Cameras Replacement: шаг 30, изображение 1 из 1
    • Remove the rear-facing camera assembly.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 11 Answers community for help.
42 человек успешно провели ремонт по этому руководству.
Jeff Suovanen
Участник с: 08/06/13
439 985 Репутация
Автор 259 руководств
Команду
iFixit Участник iFixit
Staff
118 членов
Автор 19 554 руководств
5 Комментариев
hey there
that was very useful guide. Thank you so much
https://paytakhtfanavari.com/home-applia...
fatemeh hosseini - Ответить
i cannot use dark mode on the replacement camera now. it should work shouldn't it?
norman wheatley - Ответить
بسیار عالی بود.
من برای تعمیرات لوازم مرتبط با موبایل به این سایت مراجعه می کنم و برای تعمیرات لباسشویی در مشهد به سایت مشهدتعمیر
هر دو عالی هستند
Saeed Dopamine - Ответить
When I try to use my rear camera now, its black, and I cannot use 0.5x. What could be the problem?
Martin Skugor - Ответить
Hi. hope I'm not left out. You need to change your rear camera. Happened to me once. Rear camera just black . After replace it, its fine now
Nard In -
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 37
За последние 7 дней: 251
За последние 30 дней: 1,207
За всё время: 88,973
