iPhone 16 Pro Max Earpiece Speaker Replacement
Введение
Перейти к шагу 1This guide shows how to remove and replace the earpiece speaker or top speaker for your iPhone 16 Pro Max.
If the sound coming through your iPhone's top speaker sounds like static or crackling, your earpiece speaker may need to be replaced.
You'll need replacement back glass and antenna adhesive (or double-sided tape for the antenna) to complete this repair.
Выберете то, что вам нужно
Запчасти
Инструменты
Показать больше…
Unplug any cables from your iPhone.
Hold the power and either volume buttons, and slide to power off your iPhone.
If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
Use a P2 pentalobe driver to remove the two 7.4 mm-long screws on either side of the charge port.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Инструмент, используемый на этом этапе:iOpener$12.99
Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
Apply a suction handle to the bottom edge of the back glass.
Pull up on the handle with strong, steady force to create a gap between the back glass and the frame.
Insert the tip of an opening pick into the gap.
A delicate cable connecting the back glass to the iPhone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
Multiple spring contacts around the perimeter of the iPhone.
Slide the opening pick along the bottom edge to slice the adhesive.
Leave the opening pick in the bottom-left corner to prevent the adhesive from resealing.
Use a hair dryer or heat gun to heat the left edge of the back glass until it's hot to the touch.
Insert a second opening pick into the bottom-left corner, close to the existing pick.
Slide your pick along the left edge to separate the adhesive and release the metal clips.
Leave this pick inserted in the top-left corner to prevent the adhesive from resealing.
Use a hair dryer or heat gun to heat the top edge and top-right corner of the back glass until it's hot to the touch.
Insert a third opening pick into the top-left corner.
Slide the opening pick along the top edge and around the top-right corner, stopping above the volume up button.
Leave this pick inserted to prevent the adhesive from resealing.
Use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
Insert a fourth opening pick into the bottom-right corner.
Slide the opening pick around the corner and up the right edge, stopping below the volume down button.
Swing open the back glass to the right of the iPhone to separate the remaining adhesive.
Support the back glass with a clean, sturdy object.
Use a tri-point Y000 driver to remove the three screws securing the battery connector cover:
Two 1.3 mm‑long screws
One 1.0 mm‑long screw
Use the point of a spudger to pry up and disconnect the battery press connector.
Use a tri-point Y000 driver to remove the four screws securing the back glass connector cover:
Two 1.0 mm‑long screws
Use the point of a spudger to pry up and disconnect the back glass connector.
Use the point of a spudger to pry up and disconnect the 5G mmWave antenna connector.
Use tweezers to firmly grasp the adhesive pull tab and pull at a shallow angle.
Use the point of a spudger to pry up and disconnect the earpiece speaker connector.
Инструмент, используемый на этом этапе:Standoff Screwdriver for iPhones$5.49
Remove the six screws securing the earpiece speaker:
One 2.4 mm‑long Phillips screw
Three 1.3 mm‑long Phillips screws
One 1.6 mm‑long Phillips screw
One 3.3 mm‑long standoff screw
Align the top edge of the earpiece speaker with the top edge of the frame
Lay the earpiece speaker into its recess.
Install the six screws securing the earpiece speaker:
Use your finger or a spudger to press the earpiece speaker connector onto the logic board.
Use tweezers or a spudger to remove any adhesive residue from the top of the earpiece speaker and back of the antenna.
If your replacement part doesn't include new adhesive, use a small strip of double-sided tape to secure the antenna to the earpiece speaker.
Align the mmWave antenna over the earpiece speaker. Make sure the antenna's connector reaches its logic board socket.
Press the antenna onto the earpiece speaker to secure it.
Use your finger or a spudger to press the antenna connector onto the logic board.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use blunt nose tweezers or your fingers to remove large pieces of adhesive from the frame perimeter.
Use a spudger to scrape the adhesive residue off of the frame.
If the adhesive feels stubborn, apply some heat using a hair dryer or heat gun and try again.
Инструмент, используемый на этом этапе:Microfiber Cleaning Cloths$3.99
If you're reusing your back glass, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter to prepare the surface for new adhesive.
Wrap a lint-free cloth or a coffee filter over the point of a spudger and apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to it.
Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
Lay the adhesive sheet over the frame to determine its proper orientation.
Grab the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
Carefully align the exposed edge of the adhesive strip with the corresponding edge of the iPhone's frame.
When it's correctly aligned, gently press the exposed adhesive strip onto the frame.
Continue peeling away the liner from the adhesive, gently pressing the adhesive into place.
Use a spudger to press the adhesive around the entire perimeter of your iPhone.
Use a spudger or your fingers to lift the pull tab connected to the large front liner. The pull tab is often in a corner of the liner.
Use the pull tab to peel off the large front liner from the adhesive.
Prop up the back glass along the right edge of your iPhone.
Use your finger or the flat end of a spudger to press and connect the back glass connector onto the logic board.
Use your finger or a spudger to press and connect the battery press connector onto the logic board.
Align the back glass connector cover by its screw holes and lay it in place.
Use a tri-point Y000 driver to install the four screws securing the back glass connector cover:
Use a tri-point Y000 driver to install the three screws securing the battery connector cover:
Use your fingers or a spudger to peel away all perimeter liners, exposing the adhesive.
Check the frame and back glass for any stray liners and remove them. There should be no liners remaining.
Lower the back glass onto the frame, beginning with the top edge.
Press along the edges of the iPhone until the back glass sits flush against the frame.
Use a hair dryer, heat gun, or an iOpener to heat the back glass perimeter until it's slightly too hot to touch.
Use your fingers to firmly squeeze around the perimeter of the iPhone.
Place your iPhone screen-side down on a clean, flat work surface.
Lay a strip of tape around the perimeter of the back glass to protect the finish.
Stack coins around the perimeter of the back glass until you create a wall that's as tall as the rear camera protrusions.
Place 3-4 heavy books squarely on top of your iPhone.
Leave the books in place for about 30 minutes.
Use a P2 pentalobe driver to install the two 7.4 mm-long screws on either side of the charge port.
