Taptic Engine
1 ответ 0 Оценка |
Why 16e replacement screen is so expensive? |
1 ответ 0 Оценка |
What is the reason to my phone not turning on? |
Документы
Запчасти
Инструменты
- Clampy - Anti-Clamp
- Spudger
- iOpener
- Tweezers
- iFixit Opening Picks (Set of 6)
- Suction Handle
- FixHub Soldering Toolkit
- Phillips #00 Screwdriver
- Heat Gun
- P2 Pentalobe Screwdriver iPhone
- Lint-Free Clean Room Wipes
- Tri-point Y000 Screwdriver
- Standoff Screwdriver for iPhones
- VoltClip
- IA-3952 - Max Professional Consumable Isopropyl Alcohol
Модели
A3212 US, A3408 CA/MX/SA, A3409 Global, A3410 China
Error
Example:
[document|<documentid>|<optional title>]
Current text:
[document|42838|A3212 A3408 A3409 A3410 Device Comparison V1 0 8024504|display=list]
Background
What would otherwise be the called "iPhone SE 4" or "iPhone SE 2025," the newly-renamed iPhone 16e was announced via press release on February 19th, 2024. The fourth affordable "SE family" smartphone from Apple, the iPhone 16e is a simplified version of the iPhone 16, sporting a single 48 MP 2-in-1 camera module (no ultrawide), USB-C charging, an Action button, the 6.1-inch OLED display from the iPhone 14, a notch instead of a Dynamic Island "pill," and a binned-down A18 SoC. It also lacks MagSafe, but keeps wireless charging.
Notably, the iPhone 16e marks the debut of the Apple C1, the first Apple-designed cellular modem chip, "the most power-efficient modem ever on an iPhone, delivering fast and reliable 5G cellular connectivity."
The iPhone 16e has a starting price of $599, is available in 128, 256, and 512 GB configurations, and comes in either black or white matte aluminum.
Identification
Вы можете определить модель iPhone 16e по номеру модели, напечатанному внутри порта для зарядки USB-C.
- A3212 (США, Пуэрто-Рико)
- A3408 (Бахрейн, Канада, Ирак, Гуам, Иордания, Кувейт, Мексика, Оман, Катар, Саудовская Аравия, Объединенные Арабские Эмираты и Американские Виргинские острова)
- A3409 (другие страны и регионы)
- A3410 (материковый Китай)
Вы также можете найти номер модели в интерфейсе телефона, перейдя в приложение Настройки и выбрав Основные > Об этом устройстве. Нажмите на номер, указанный в разделе Номер модели, и он должен измениться на формат, соответствующий номерам, приведенным выше.
Кроме того, Apple предлагает быстрый онлайн-инструмент, который поможет идентифицировать ваши устройства: Определение модели вашего iPhone.
iPhone 16e оснащен плоским стеклянным экраном с диагональю 6,1 дюйма, тонкими черными рамками, черным вырезом в верхней части экрана, матовым задним стеклом и боковыми гранями из алюминия.
Регуляторы громкости и кнопка действия расположены на левой грани, а кнопка питания — на правой. Один объектив камеры выступает из задней панели корпуса. У этой модели нет кнопки «Домой».
iPhone 16e можно отличить от iPhone 16 по вырезу в дисплее и системе с одной камерой (по сравнению с Dynamic Island и системой с двумя камерами на 16).
iPhone 16e можно отличить от предыдущего iPhone SE по отсутствию кнопки «Домой» и общему дизайну.
Technical Specifications
Dimensions: 146,7 × 71,5 × 7,80 мм (5,78 × 2,82 × 0,31 дюйма)
Weight: 167 г (5,88 унции)
Water Resistance: IP68
Colors: Черный и белый
Operating System: iOS 18
Processor: Чип A18
- 6-ядерный процессор (CPU) с 2 ядрами производительности и 4 ядрами эффективности
- 4-ядерный графический процессор (GPU)
- 16-ядерная система Neural Engine
RAM: 8 ГБ
Storage: 128 ГБ, 256 ГБ или 512 ГБ
Battery: 3561 мА·ч, до 22 часов воспроизведения видео
Ports: 1 разъем USB-C
- Зарядка
- DisplayPort
- USB 2.0 (до 480 Мбит/с)
Display:
- 6,1-дюймовый OLED-дисплей «Super Retina XDR»
- Технология стекла Ceramic Shield
- Multi-touch
- Haptic Touch
- Разрешение 2532 × 1170 пикселей (460 ppi)
- Контрастность 2 000 000:1 (типичная)
- True Tone
- Широкий цветовой охват (P3)
- Максимальная яркость 800 нит, пиковая яркость 1200 нит (HDR)
- Олеофобное покрытие, устойчивое к появлению следов от пальцев
Система камер «2 в 1»:
- 48 Мп, «Fusion»
- 26 мм, диафрагма ƒ/1.6
- Оптическая стабилизация изображения (OIS)
- Автоматическая стабилизация изображения
- Поддержка 12 Мп 2-кратного оптического телеобъектива
- Запись видео 4K60
Селфи-камера TrueDepth с поддержкой Face ID:
- 12 Мп
- Диафрагма ƒ/1.9
- Запись видео 4K60
- Автофокус с технологией Focus Pixels
Sensors:
- Face ID
- Барометр
- Гироскоп с высоким динамическим диапазоном
- Акселерометр высокого ускорения (распознавание аварий)
- Датчик приближения
- Двойные датчики внешней освещенности
Wireless Connectivity:
- Wi-Fi 6 (802.11ax) с технологией 2x2 MIMO
- 5G, sub-6 ГГц
- Gigabit LTE с технологией 4x4 MIMO
- Bluetooth 5.3
- NFC с режимом считывания
- Экспресс-карты с резервным питанием
Additional Information
Особая благодарность этим переводчикам:
100%
Iosif Boukhbinder помогает нам починить мир! Хотите внести свой вклад?
Начните переводить ›
